Old 06-21-2010, 10:23 AM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Hensley and Excursion Question
Is there anyone towing a 34 fter with an Excursion 4x4? I am interested in the stinger drop and bars you are using and if the trailer rides level with that stinger.
Also the measurement to the top of the coupler socket while the trailer is off the TV and parallel to the ground would be nice. I mention this because I have heaver axles under my trailer and 16 in. tires
2004 Excursion 4x4
Old 06-21-2010, 11:08 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
2" Drop
I tow the 31'er (45 degree start angle, 15" tires) with a 2005 4 X 4 Ex - 285's on the Ex instead of the stock 265's.
Found that a 2" drop is just about perfect - the upside of a 2" drop is that if turned around (makes it a 2" rise) it's just about right for both a non-4X4 Excursion AND my 3/4 ton Dodge van.
When towing with the Ex I have found that the 1000# bars seem to work well when pulled up to the first (least amount of tension) marker on the screw adjustment jacks.
I have measured the "trailer level" distance from the top of the coupling to the ground to be 20" (as opposed to the 19.5" in the factory specs) with the new axles.
Your trailers specs call for this distance to be 18.75" as it left the factory.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-21-2010, 11:57 AM   #3
_
Originally Posted by HowieE View Post
...I am interested in the stinger drop and bars you are using and if the trailer rides level with that stinger...
basically this question is just gonna yield what OTHER FOLKS are using...
most of which will not apply 2 your rig and will only muddy your selection.
1. measure the receiver box height (upper/inner edge) on a level surface and with the ex' loaded.
2. measure A frame/coupler/cup height with the trailer level.
we can all chime in on the needed stinger drop with that info
but this is covered in the company book and the HAHA users guide.
w/d bars will depend on tongue weight and 34s have a WIDE RANGE over the years of production.
just guessing, 1000 lb bars would be ideal for your combo.
cheers
2air'
Hensley Question for 30ft ? wantostream Hitches, Couplers & Balls 9 12-01-2008 08:09 AM
Hensley Arrow Question toddnich Hitches, Couplers & Balls 14 08-12-2008 11:00 AM
New (to me) '05 Excursion TV panabax Tow Vehicles 2 05-27-2007 12:47 PM
Hensley Question sander17 Hitches, Couplers & Balls 4 10-10-2005 06:48 PM
Hensley Hitch Question Princer Hitches, Couplers & Balls 7 08-27-2003 07:16 PM
