Old 06-02-2014, 02:07 PM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
Hensley
lets see….
are there old hensley hitches…….10 years…15 years…
what can go wrong with them??
just curious
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 06-02-2014, 02:32 PM   #2
dznf0g's Avatar
Oswego , Illinois
The serial number label was gone from mine when I got it, but as best Hensley can tell it is a pretty early one. I've replaced the seals, repacked the bearings, replaced the bushings and the grease fitting assemblies and repainted. No major wear (except in the consumables department) and no breakage.
-Rich-
Old 06-04-2014, 07:27 AM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have an early HAHA that I bought used. Ditto's to what DZNF0G said about replacement parts.
One weak area I found is where the strut bars attach to the orange hitch head. The holes elongated and I had to weld some steel in the area for strength.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-04-2014, 07:35 AM   #4
dznf0g's Avatar
Oswego , Illinois
Most of the issues with the strut/head hole elongation I have seen is due to (IMO) imroper strut adjustment. One of two things causes it.
1) the owner mistakenly adjusts the struts to be in tension, rather than compression. The struts should be "pushing" the head forward, keeping the ball pushed to the front of the coupler. And there should be a reasonable amount of compression (tightness) on the strut.
2) Not keeping a substantial amount of compression on the struts will allow for rearward movement of the strut/head pin, relative to the coupler, to move around in the head holes, wollering them out.
I have virtually no wear on the forward head hole edges and none on the trailing edges.
-Rich-
Old 06-06-2014, 06:50 AM   #5
crispyboy's Avatar
1994 30' Excella
Not sure how you could ever have the strut bars in "tension". They can only be used one way and that is compression. The strut bar slides together so there can be no tension.
My guess is that the elongation of the holes on my particular hitch came from a time when my brake controller was not working properly and I was getting the Hensley bump at most any stop. Hensley seemed to drill the holes ever so close to the edge of the steel.
WBCCI # 3072
Old 06-06-2014, 07:08 AM   #6
dznf0g's Avatar
Oswego , Illinois
Yeah Crispyboy, you're right...my thought process didn't take that into account. It's got to be loose struts then. If they're tight enough, even a "bump" won't allow contact with the rear hole edges. They should be pretty tight. My paint is still on the rear hole edges after a repaint 2 years ago.
-Rich-
Old 06-06-2014, 07:56 AM   #7
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
If you give Hensley a call you should be able to get information on purchasing a reconditioned unit - that is how we got ours in 2007 - still an expensive hitch but much reduced in price from new and carries the same 60 day trial period and lifetime warranty.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 06-06-2014, 08:03 AM   #8
crispyboy's Avatar
1994 30' Excella
RangerJ,
You could also buy a reconditioned Pro-Pride which is where I would start if in the market.
WBCCI # 3072
Old 06-06-2014, 08:29 AM   #9
dznf0g's Avatar
Oswego , Illinois
One other thought on the struts. There is quite a bit of side play where they attach to the end pins. I installed nylon washers to reduce the clearance and thus reduce the slight lengthening and shortening of the effective length during turns or hard braking. I also installed these washers on either side of the upper jack mount.
-Rich-
Old 06-06-2014, 09:10 AM   #10
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Chino Valley , Arizona
My Hensley is 15 years old and on it's third trailer. The only thing that I've done to it is normal maintenance and I painted it to match my airstream. It will probably out last me. Great hitch.
AIRTRVL is offline   Reply With Quote
Old 07-20-2014, 01:41 PM   #11
Ed Brownfield's Avatar
2015 28' Flying Cloud
Charlottesville , Virginia
I am trying to decide between an Equal-i-ser hitch and the Hensley hitch can someone tell me the pros and cons of each? I have heard that the Hensley hitch is the best hitch but that it is difficult to hookup. Thanks
Ed Brownfield is offline   Reply With Quote
Old 07-20-2014, 02:02 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Between those 2 I would choose the Hensley- and I own an Equal-i-zer, but if I could have any hitch I wanted I would get a ProPride- similar to a Hensley but "new and improved".
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-20-2014, 04:23 PM   #13
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Old Hensley Continues to Serve
Ours is 15 years old. Only had one problem, a broken weld at the base of the ball. Found it while doing routine maint. one spring. Called Hensley. They replaced the whole Orange Head with a newly remanufactured one for the cost of the shipping. We're good to go for another 15 or more, I suspect.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-20-2014, 05:01 PM   #14
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Our Hensley Arrow is ten years old. It is serial number 8332. It has been in use on two Airstreams and has towed about 130,000 miles. It still works as good as when it was new. I have never experienced the slightest trailer sway, ever.
Brian
SuEllyn & Brian McCabe
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 08:10 PM
Hensley, Pullrite, etc. markjoandall Hitches, Couplers & Balls 28 09-14-2009 08:51 PM
Hensley/Airstream TTs--predominately more? Kistler Hitches, Couplers & Balls 6 07-04-2003 11:26 AM
Is a Hensley overkill for a 22' trailer? Charcigar On The Road... 11 08-07-2002 08:59 AM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
