Old 07-17-2006, 02:02 PM   #1
1965 20' Globetrotter
Calgary , Alberta
Help with Towing
hello all,
I have:
- 1999 Jeep Grand Cherokee V8
- 1965 AS Globetrotter
what do I need to tow the AS
I have so far:
trailer hitch class III
receiver and 2" ball
brake controller in truck
transmission cooler
do I need anything else?
what is the WD??? how doesit work? do I need it?
what is the Sway Control? how does it work? do I need it?
thanks for your help
anybody with pictures of these devices?
cheer
Carlos
CAAR is offline   Reply With Quote
Old 07-17-2006, 02:58 PM   #2
bfk
1961 16' Bambi
Eugene , Oregon
Welcome,
When you hook your Globetrotter to your Jeep you are adding 300lbs or more to the back of the vehicle. Like putting half a dozen 50lb bags of sand in there. If you look from the side, the tow vehicle will be low in the back and high in the front. This has a bad effect on steering and stability.
Using a properly adjusted weight distributing hitch shifts the load such that the front and back axles, and that of the trailer share the load.
Your vehicle is now even front to back and much more stable.
You need it.
Certain conditions, gusting crosswinds for example, can cause the trailer to be pushed to from one side to the other and back again. This can set up an oscillation where the side to side movement self-reinforces. This is no fun for the driver. In bad cases it's no fun for the screaming passengers either.
Sway control makes it harder for the trailer to swing from side to side.
You want that too.
The Equal-i-zer is a popular hitch which includes sway control. See more at http://www.equalizerhitch.com/.
Another popular one is from Reese, at http://www.reeseproducts.com/.
If you are feeling spendy there are several more expensive options, The Hensley Arrow and the Pullrite, but then you are into four figures.
Hope this helps,
Brian
bfk is offline   Reply With Quote
Old 07-17-2006, 05:15 PM   #3
TIMEMACHINE's Avatar
Huntington Beach , California
One word
Carlos,
Brian's summary is on target. I would second one of his suggested hitch systems, the Equal-i-zer, it is reasonably priced, uses a simple theory of operation and are easily obtained and serviced.
Consult a pro at a dealer to make sure you get the right system for your tow vehicle and trailer. You can always have the forum confirm the dealers recommendation.
John
TIMEMACHINE is offline   Reply With Quote
Old 07-18-2006, 02:42 AM   #4
Calgary , Alberta
Thanks, Very Helpful!
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
towing with Roadmaster/ Fleetwood Cruiser On The Road... 1 09-26-2002 04:14 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Towing COArgosy78 1969 Overlander 5 09-05-2002 10:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
