2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Go to Youtube.com and type in Hensley hitch - I don't know whether you have the newer snap up brackets or the older style that are tightened with a wrench but you ought to get a lot of information as there are many videos available.
Paula
2000 25' Safari
Davidson County
, NC Highlands County, FL
What I do:
On a level surface, before hooking the trailer to the tow vehicle, measure the height of the fender openings at the center of the two front wheels of the tow vehicle.
After hooking up the trailer to the tow vehicle the measurement will be slightly higher. Adjust the bars, each being equally tensioned, until the measurements returns to approximately to the unloaded height.
Some people use more tension, to add additional weight to the front axle. Your tow vehicle owner manual may indicate which is correct for your vehicle.
Alan
Socool69, if you are still having a problem after following the excellent advice from A W Warn, try to contact Tino643. He is from the Montreal area and most likely will be able to help. Jim
