Old 10-18-2014, 08:22 PM   #1
Newbury Park , California
Help! Broken sway bar
One of the cradles for our right side anti sway bar snapped. Is it safe to drive home with one anti sway bar. We are 135 miles from home. Driving a 2008 land cruiser and towing a 2006 25 ft safari
bunnyfamily is offline   Reply With Quote
Old 10-18-2014, 08:36 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wow.. Are you talking about where the chain connects from the bar??
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-18-2014, 08:37 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pics please. Hitch type, etc
Channing
WBCCI# 30676
Old 10-18-2014, 08:42 PM   #4
Sorry , should have sent pics. It's a Reese hitch circa 2006. I think it could be welded but not sure Click image for larger version
Name:	ImageUploadedByAirstream Forums1413682940.536571.jpg
ID:	224642Click image for larger version
Name:	ImageUploadedByAirstream Forums1413682954.914707.jpg
ID:	224643Click image for larger version
Name:	ImageUploadedByAirstream Forums1413682970.806534.jpg
Old 10-18-2014, 09:16 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If possible, I would find a replacement before towing. While it might be relatively safe, I would not attempt unless necessary. If I did tow, I would reduce speed and begin carefully. There is no telling what might occur so be prepared to react!
Also, tie or Bungie the broken part below where it should belong so that it does not swing into other parts of trailer or car.
Bottom line... Your car...your trailer... Good luck.
Channing
WBCCI# 30676
Old 10-18-2014, 09:34 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
That should be able to be welded to stronger than original. Double V groove weld, probably a 80 or 100 series stick. Not a pipe weld rod.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-18-2014, 09:59 PM   #7
1981 31' Excella II
New Market , Alabama
You should be able to find a replacement part. I would not run with one bar. Those are load bars not sway bars but I believe you have a dual cam setup which also acts as sway control. Running with one bar would be worse than none. I would not weld that piece. It is almost impossible to make a weld as strong as the parent metal.
Perry
Old 10-18-2014, 10:10 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
If you need to get home, you can remove the other cam arm, attach the chain directly to the spring bars using the existing holes. You will now have just weight distribution, but zero sway control. 130 miles is a long way at 45 mph, but at least you're not hanging around for a part!
Old 10-18-2014, 10:13 PM   #9
Ok sounds best to look for a replacement part. Any suggestions other than an rv shop where I might get one? We are in Julian ca. Airstream LA is about 2 hr away I think in worst case scenario. Thanks for everyone's help.
Old 10-18-2014, 10:14 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Camping world, no they don't stock those, google reese/draw tite near you.
An airstream dealer won't help!
Old 10-18-2014, 10:24 PM   #11
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
A 26 footer is delivered by the factory hired drivers without sway bars......all over the country. Many folks tow without as well. For a short trip of 135 miles, at reasonable speeds and conditions I, personally, would not worry a bit.
Old 10-18-2014, 11:47 PM   #12
jspafford's Avatar
San Diego , California
Call Abe Hernandez in Ramona California, just a few miles from Julian. He's the repair expert in So Cal, and he's mobile.
(760) 802-3238
John and Lynn,
Silvia ('06 25' Safari SE FB) and Silvester ('05 Chevy Express 3500)
jspafford is offline   Reply With Quote
Old 10-19-2014, 03:35 PM   #13
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I would do exactly what Atomic 13 said. Take off the other cradle, ( one that's not broken) and put your normal tension on the trunnion bars. drive a little slower, and pay attention to your driving.
The only difference is that you won't have sway control, but you will still have weight distribution....
If you don't feel comfortable with that, see if you can find a local welding shop, and have it welded.
Good luck!
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 10-19-2014, 04:30 PM   #14
I'm doing as atomic 13 and Larry C suggested, also talked to Abe Hernandez who's at Toronto airstream show but verified. Only final question is whether to leave good cam on the other side with less tension to match my broken side setup? Click image for larger version
Name:	ImageUploadedByAirstream Forums1413754191.432281.jpg
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-03-2013 12:17 AM
Airstream newbies need help please - sway bar noise lynnrae General Repair Forum 15 11-13-2012 12:14 AM
Sway bar help for dummies patis Hitches, Couplers & Balls 23 03-22-2010 10:53 PM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 06:02 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 07:11 AM
