Old 08-28-2007, 04:06 PM   #29
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
if i get around to it i plan on welding some expanded mesh over the opening.
john
you call them ferrets, i call them weasels.
Old 08-28-2007, 04:17 PM   #30
Originally Posted by thecatsandi
Nick,
I do not know of any plastic that I can get that I can bend at a 90 degree angle. As far as Al verses Fe. I could use some 24ga galvinized steel sheet metal Paint it and RTV it in place.
I was imagining a flat piece of plastic. A stainless steel self tapping screw near each corner could act as locator spigots inside each tube, and a good blob of RTV would seal all the circumference. Your idea of the galvanized sheet would certainly work. I like the simplicity of the stainless pot scourers, and they allow the tubes to breath.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-28-2007, 06:37 PM   #31
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A Little breathing may be good but I want to treat the inside so it does not rust any more. Since it has already strated rusting LPS 3 or equilvent is what I would use. Under coating would allow it to continue rusting under the coating.
I was thinking of modifying the plate to have some open space at the top behind the coupler. That way it is protected and allow it to breath.
Welding? I want to be able to remove it reasonably easily and insepect.
Michelle TAC MT-0
Sarah, Snowball
Old 08-29-2007, 07:08 AM   #32
Central , Mississippi
caplugs
How about one of these? I'm not near my trailer so I can't measure the opening. If they are available the minimum order would do 10-20 trailers.
ID:	44023   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 08-29-2007, 09:18 AM   #33
2005 34' Classic
Richmond , Virginia
A frend of mine who is a welder told me that if you seal tubing up to tight it can sweat from changes in humidity and temp. Might be somthing to think about but greasing the inside sounds good to me.
Resorts is offline   Reply With Quote
Old 08-29-2007, 03:35 PM   #34
Keymar , Maryland
I like the idea. the ones in specs re too small but I like the thinking.
Michelle TAC MT-0
Sarah, Snowball
Old 08-29-2007, 03:40 PM   #35
Keymar , Maryland
this can happen if you trap moisture inside the frame. Here in Idaho it is soo dry that this not a problem. If you are worried about that you can fill the frame with inert gas, nitrogen, argon.... You would have to seal the other ends as well.
Michelle TAC MT-0
Sarah, Snowball
Old 08-29-2007, 09:28 PM   #36
Fenghuang's Avatar
2007 23' Safari SE
San Diego , California
nylon fabric frame bar cover
Here are pictures of the cover that I made for our trailer.
Name:	HPIM1137 tonuge project components.jpg
ID:	44072   Click image for larger version
Name:	HPIM1138 tongue project pieces.jpg
Name:	HPIM1139 tongue rail cover.jpg
1767 Spanish scribe:"Rash judgments are always accompanied by ignorance and absence of light." (Learn all the facts before making a judgment)
Fenghuang is offline   Reply With Quote
Old 09-03-2007, 01:23 AM   #37
SilverGate's Avatar
2007 23' Safari SE
The photos above show what is described in post #22 on page 2
Originally Posted by Fenghuang
Has anyone tried a sewn nylon fabric (e.g., rip stop nylon) cover casing opening reinforced with a wire frame, and fastening it in place with a Velcro strap? There is a upper anterior lip that the bent wire frame can hook onto. A Velcro strap can slip around the posterior medial bar hole opening to secure it. This would allow ventilation, limit wildlife/water/debris access, and permit periodic inspection.
In addition, a stainless steel pot scrubber was placed just inside the
opening of each rail.
SilverGate is offline   Reply With Quote
Old 11-23-2007, 10:13 PM   #38
Keymar , Maryland
Caps installed
A little update. Tomorrow I hit the road for the winter. Yesterday I took measurements layed out, bent up the edges, primed and painted the Caps. I sanded and primed the inside of the box frame where I could reach. I sprayed the inside of the box frame as far as I could see with corrosion inhititor. This afternoon I installed the caps. Black RTV before and after the the caps were installed.
This should keep the weather at bay.
The first picture is caps preped and ready.
The second picture is the frame ends preped and ready.
The third picture is the supervisor watching over me.
The forth picture is the caps installed.
ID:	49818   Click image for larger version
ID:	49820   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 06:26 AM   #39
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
You are too clever. Probably all Sarah's idea and you're taking the credit. Now, of course, Vincent thinks I need to go out and crawl under both trailers to look at the tongues. Thanks Michelle. By the way, we still have room for you and Sarah in the yard if you stop by.
juel is offline   Reply With Quote
Old 11-24-2007, 09:04 AM   #40
Keymar , Maryland
You caught me. It was her idea and she did all the design. She just made sure I did the job properly.
Thanks, My plans at the moment are to head east on I-80 again. I will have freind with me on this trip. The troute can change depending on the weather.
Headed back west. I am planning on I-10.
Michelle TAC MT-0
Sarah, Snowball
Old 11-24-2007, 10:07 AM   #41
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Have a safe trip. You need to be especially careful now that you have Sarah with you. What out for black ice
Security lock for the tongue? Diana Langley Hitches, Couplers & Balls 11 11-19-2002 11:01 AM
Tongue Tied CHRIS CANNON Jacks, Stabilizers, Lifting and Leveling 0 09-30-2002 08:44 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
So I looked at a trailer today..... Chuck Our Community 6 06-05-2002 06:43 PM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
