Old 03-30-2012, 07:12 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Question Has anyone worn out their Coupler?
I was having a discussion with my favorite AS mechanic last week. No it wasn't me. As far as I know I don't talk to myself. or do I?
He and I were discussing the fact that when I lifted my trailer the last time take it down to offsite storage at a friends house that I had problems keeping the ball in the coupler. I have a new latch from fall 2006 and a brand new first time use ball.
I am going to try to replace the latch but I think he may be correct that the coupler will need to be replaced since it has 80,000+ miles on it and two accidents.
The coupler socket has remained lubricated the entire time.
So the couple hundred $ question: Coupler replacement or ?
Michelle TAC MT-0
Sarah, Snowball
Old 03-30-2012, 07:44 PM   #2
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
I have not looked real close at mine,, but did test it locked up by raising the jack a bit.. Most of them I have been around can be adjusted as the flipper catcher thingey wares.. The draw system that pulls up on the lock plate is the most important as if it failed it would turn loose the flipper flopper locker plate..
Bet someone comes on behind all this with the proper terms,, and more solid info..
Myself,, lube,, test and always look for cracks or lose bolts and such,
Sodbust
Sodbust is offline   Reply With Quote
Old 03-30-2012, 07:45 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A few months ago a 1986 Sovereign came into the shop with a worn out coupler. The ball sat much too high in the coupler, and the latch wouldn't latch. We attributed this to a lack of lubrication, since it had never seen a drop of grease since 1986.
Old 03-30-2012, 09:13 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
If I ever need to replace the one on our Airstream, I'll consider a Bulldog Collar-Lok A-Frame coupler; I have one on our equipment trailer. It's really tough and there's no way that latch is wearing out - and it's obvious when it is properly latched.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-30-2012, 10:13 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Bart,
FYI...
They are not meant for travel trailers and I have seen them on two trailers and the frame were badly bent! They fit on the ball very tight (toooo Tight) and force the frame to bend rather then pivot on the ball!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 03-31-2012, 12:06 AM   #6
Maniacal Engineer
barts's Avatar
Well, I have no idea why those frames were bent, but color me deeply skeptical that the coupler grabs on so hard that it bends the frame. It is a lot more likely that someone overdid the WD settings and replaced the coupler, or vice versa. The Tin Pickle's frame is slightly bent just ahead of the body - likely a steep driveway and an aggressive WD hitch w/ a PO.
- Bartt
Bart Smaalders
Menlo Park, CA
Old 03-31-2012, 06:38 AM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Even the most expensive coupler option isn't really expensive. So I'd be inclined to replace a twice wrecked one.
I, too, "like" the BULLDOG coupler . . but it's worth asking why it is never used on travel trailers by OEM's.
There "might" be something more to it than cost. After all, a trailer that jumps the ball is bound to have excited some lawsuit or other and have this question raised.
Or, why would it not be an option (is the other)? Far as I can tell the slide/collar lock might just need more oil or grease than the usual coupler type.
Look forward to what someone finds out about it.
http://www.redtrailers.com/images/ac...umbs/21011.jpg
And, here is Mexray on his QUICKBITE coupler. Had a guy pull in next to me two weeks ago with one. The simplicity is appealing.
Ray reports that one need not even remove the old coupler, just cut the "nose" off the end and -- by design -- weld the Quickbite right over it.
http://lh6.ggpht.com/dreamstreamr/SC...jpg?imgmax=512
Old 03-31-2012, 11:52 AM   #8
Keymar , Maryland
- Bart
How do you adapt this to the trailers A frame?
Michelle TAC MT-0
Sarah, Snowball
Old 03-31-2012, 12:04 PM   #9
Keymar , Maryland
The first "wreck" was a seperation. The second one the trailer remained connected. However, the person behind me reported the trailer was swaying plus or minus nearly a full lane.
How I didn't loose it is still a mystery to me.
Michelle TAC MT-0
Sarah, Snowball
Old 03-31-2012, 01:20 PM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It is ok to talk to yourself if no one is listening and if you like the company.
But that probably wasn't your real question—
With two accidents, the damage that the coupler may have experienced would be enough for me to change it. You have also had trouble with your hitch and that may have made the situation worse. There may be an adjustment, but maybe you can't see any damage.
I'd replace it.
I saw some posts on the Quickbite a while ago and it was intriguing. This is an opportunity to find something better than the OEM coupler.
Gene
Old 03-31-2012, 01:42 PM   #11
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
If anyone pursues the Quickbite, I'd be interested in finding out what you find out. When I asked my sales guy about it, he said there was some question as to whether it was really compatible with a proper weight distribution hitch set up. I don't know enough to know if that's code for "we don't deal with it and we don't want to" or if there really is a compatibility issue.
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 03-31-2012, 03:28 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
They have several types with different weight ratings.
BULLDOG A-Frame Couplers
http://www.bulldogproducts.net/content/default.aspx
And, as CrawfordGene indicated above, the "wreck" of your trailer, twice would have been more than enough to have considered the coupler worn out, IMO.
Old 03-31-2012, 03:33 PM   #13
JFScheck's Avatar
Rockville , Maryland
Images: 33
Has anyone spotted any RV'ers using any other type of attachment pieces?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-31-2012, 04:18 PM   #14
Maniacal Engineer
barts's Avatar
They make an A-frame version, so I'd support the tongue under the tanks, remove the tanks & regulator, plug trailer propane line, remove the jack, cache the break-away wiring somewhere safe, grind the welds off on the existing coupler, test-fit the new coupler and remove any paint near where the welds would go, and tack and then weld in place using a high penetration electrode (6010 or 6011); I'd butter pass w/ 7018 as that's much prettier. Clean slag, wirebrush and etch raw metal with phosphoric acid, paint with Aluthane or other polyurethane UV rated paint. Replace jack, break-away switch, tanks, etc. and test.
Likely take several hours + wait time for paint. Any competent weld shop can do this for you.
- Bart
Bart Smaalders
Menlo Park, CA
Drilling out buck rivets PA BAMBI II Ribs, Skins & Rivets 9 04-04-2012 07:58 AM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 09:31 AM
2009 Airstream Classic 30' w/ Slide Out - Price Reduced!!! eBay Watch Airstreams on eBay 0 03-29-2012 09:50 AM
Anyone ever had a misprinted VIN from the Factory? smallville 1961 - 1963 Bambi 6 03-29-2012 06:49 AM
Solarized paint? (wonder if it wears out?) AIR-Quarius Generators & Solar Power 2 03-29-2012 12:23 AM
