Old 03-31-2012, 05:19 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a Bull Dog coupler on my hay mower. It has been there for 10 years. When I am mowing the 62 acres on the farm I make a 90 degree turn to the right and then another 90 degree turn to the left. This operation occurs about every 2 minutes all day long for about 16 days a year. So in 10 years it has gone thru this operation 48,000 times. It shows no sign of significant wear. I do grease the mechanism regularly.
I can't see any reason why this ball coupler would not be a safe device on a travel trailer. It certainly has a very positive lock mechanism.
Old 03-31-2012, 05:59 PM   #16
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Welding
Originally Posted by barts View Post
Likely take several hours + wait time for paint. Any competent weld shop can do this for you.
- Bart
Bart,
A competent welder will do this for me. I won't do any welding that is critical. That is left to the professionals.
Michelle TAC MT-0
Sarah, Snowball
Old 03-31-2012, 08:50 PM   #17
r carl's Avatar
Lin , Ne
FYI, I torched off, ground off slag and remaining weld, and welded on a new stamped A-frame coupler on a boat trailer the other day. I used 1/8 6010 rod. Everything went well and it took a half hour.
Old 03-31-2012, 11:30 PM   #18
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
I've had a coupler wear out on a utility trailer... just poor maintenance because I didn't care about it. Moved from a 1 7/8 to a 2 inch ball and that fixed it.
My Basecamp had a 2 inch coupler that was really nice.. very easy to tell if it was engaged. My Intl has the old-school flip latch, which I think is the crappiest design ever...
Oh well...
Friday is offline   Reply With Quote
Old 04-01-2012, 12:44 AM   #19
Maniacal Engineer
barts's Avatar
Menlo Park , California
Originally Posted by thecatsandi View Post
Bart,
That call is one you have to make yourself. I don't get paid for welding, but I've welded my own boat trailer from scratch, as well as the boiler that's in that boat . Coupler are actually a low stress situation because there's so much space for welds - many inches long. If you do the math, a small fraction of the welds on the coupler will suffice to hang the Airstream in mid-air! Tricky bits are when there's very little metal thickness/area to carry the load, or if you have to do it upside down, blind and in a box like those Navy certified welders.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-01-2012, 08:30 AM   #20
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here's a users opinion on Quick Bite:
Dreamstreamr Odyssey Chasing 75 Degrees
Old 04-01-2012, 11:31 AM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Every time we drop the tongue on the ball, we then raise the jack to make sure it is engaged. Seems like this is a good practice to follow, but maybe some aren't doing this.
Gene
Old 04-01-2012, 12:27 PM   #22
Baltimore , Maryland
Now you have a chance to turn it into a real Airstream by upgrading to a 2" coupler
I better add that is a joke us vintage snobs like to make, someone lacking a sense of humor will not get it. Sorry on advance.
Old 04-01-2012, 01:09 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Real trailers take a 12k 2-5/16's ball.
(Who needs humor when oneupsmanship is a long RV tradition?)
As to welders: In this park, out of almost 90-spaces, are at least fifteen welders certified in refinery & pipeline work. I barely can keep up with the above, but the guys around here are really something as their work related conversations get going.
Old 04-01-2012, 01:29 PM   #24
Why would anyone want to tow 12,000 pounds when you can achieve the same with 4100? Not sure more weight one-ups ya
Old 04-01-2012, 01:46 PM   #25
Master of Universe
Gene's Avatar
I use a bowling ball and a custom made coupler. My ball is bigger than yours.
Gene
Old 04-01-2012, 02:46 PM   #26
You guys know it is not how big your ball is, it how you use it.
Old 04-01-2012, 02:54 PM   #27
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
I am SO impressed you guys had self-control for this long...
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 04-01-2012, 02:55 PM   #28
Master of Universe
Gene's Avatar
Must be April Fools Day.
Gene
Drilling out buck rivets PA BAMBI II Ribs, Skins & Rivets 9 04-04-2012 07:58 AM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 09:31 AM
2009 Airstream Classic 30' w/ Slide Out - Price Reduced!!! eBay Watch Airstreams on eBay 0 03-29-2012 09:50 AM
Anyone ever had a misprinted VIN from the Factory? smallville 1961 - 1963 Bambi 6 03-29-2012 06:49 AM
Solarized paint? (wonder if it wears out?) AIR-Quarius Generators & Solar Power 2 03-29-2012 12:23 AM
