Old 08-27-2017, 02:07 PM   #1
NCMEDIC's Avatar
2010 27' FB Classic
LINCOLNTON , North Carolina
HA Hookup Aid
As a new HA owner, it has taken me a while to get used to just how important the angles are in the hitching process. The stinger and the receiver MUST be in the same orientation vertically, horizontally, and laterally.
To help with this, and to make it easier to see the angular errors, I started using two hitch poles with magnetic bases. On one of them, I put an o-ring to function as a height measure.
I first set the o-ring to the height of the stinger. Then, raise or lower the AS until it matches the height.
Then, I take one of the poles and put it on top of the receiver and put the other on the end of the stinger. This makes it very, very easy to see angular errors between the stinger and the receiver.
ID:	293363   Click image for larger version
ID:	293365   Click image for larger version
NCMEDIC is offline   Reply With Quote
Old 08-27-2017, 02:29 PM   #2
ITSNO60's Avatar
Tucson , AZ
good idea, where did you get the poles?
ITSNO60 is offline   Reply With Quote
Old 08-27-2017, 03:09 PM   #3
NCMEDIC's Avatar
2010 27' FB Classic
Hitchin Rod https://www.amazon.com/dp/B00030LM54..._DtZOzbSXRTD25
Old 08-27-2017, 07:38 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kewl! This shows the geometry quite well!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-05-2017, 11:34 AM   #5
2014 27' FB International
Macon , Georgia
I see how you get the vertical height alignment and the side to side angle alignment. I don't see how you are providing for the up and down angle alignment of the stinger to the receiver.
Roadtech is offline   Reply With Quote
Old 09-05-2017, 01:21 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
What goes around never stays gone
The O-rings were an up-grade
Stream Happy
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-05-2017, 01:25 PM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Your truck has a stinger! Tailgate me and see what happens.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-05-2017, 01:30 PM   #8
Thumbs up
Yep...it stays on while camping.
With a custom......"Shin-saver"
RLC
John Prine
Old 09-05-2017, 02:13 PM   #9
NCMEDIC's Avatar
2010 27' FB Classic
Once I'm squared up to the receiver and get about 6 inches away, then I adjust the pitch of the receiver as needed. As you said, there are 3 different planes you're working with and the poles help you with the first 2. The last one is just the Mark One Mod Zero eyeball.
Old 09-05-2017, 02:28 PM   #10
GCinSC2's Avatar
Nice cone but that yella 5' stinger has the reach!
S/OS #001
Old 09-05-2017, 04:03 PM   #11
Macon , Georgia
OK, I got it, thanks.
Old 09-05-2017, 05:35 PM   #12
Question
Five foot stinger? Just a wimpy yellow rod.
RLC
John Prine
Old 09-07-2017, 01:34 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Want a "stinger"? Try one of Sean's 2.5' 75# adjustable HA pieces. (I don't remember actual dimensions -- exaggerating for effect -- but the HA stinger even with 4" drop is a wimp in comparison).
I've thought about lighting it and placing a bullseye on the business end.
Now that I think of it, I've seen some bullseye changing pattern LED lamps.
As to setting HA, I've been using a tape measure ten years.
Old 09-07-2017, 02:13 PM   #14
2007 22' International CCD
Sigh. Saw what an ordinary 2" bar and ball stinger did to the front end of the guy that ran into it causing a chain reaction accident involving 4 people. And yes, I was the first guy in front of that mess...in a Prius, no less. Had a clean imprint of the car behind me's license plate frame in my bumper.
A ProPride stinger would make a massive mess out of some fool that ran into it... Mine is a bog standard 2" one. A 2.5" would be formidable.
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
rmkrum is online now   Reply With Quote
First Aid Kit overlander63 Community Polls 79 04-14-2011 05:58 AM
Trailer-Aid Devoman Our Community 11 08-25-2006 09:59 AM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 03:37 PM
