Old 09-07-2017, 02:39 PM   #15
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
HA Hookup Aid
I have the 2.5" one - don't recommend leaving it plugged in while driving without the trailer
I do put a blue cut pool noodle over it if I leave it in the receiver while at the Campground. That thing could break a leg if you hit it right!
SteveSueMac is online now   Reply With Quote
Old 09-07-2017, 02:43 PM   #16
W , New England
As for hookup aid - I forget who in the forums taught me this but I have a bright orange and yellow rope about 10' long with a magnet on one end. I put the magnet under the hitch head on the trailer and run a straight line with the rope out towards the truck. In the backup cam of the truck, I can see the stinger "ride the rope" as I back toward the trailer. Works every time. When I get close enough, I get out to check height of stinger and hitch head - adjust if needed - then back in to connect the OCLs.
And if there's tension there and I can't seem to get the stinger in enough for that, simple winding of the WD jacks tilts the head and pops it right on to the stinger.
Once I learned that, I haven't had a problem connecting.
Old 09-12-2017, 03:18 AM   #17
2012 19' International
Southeastern MI , Michigan
Originally Posted by rmkrum View Post
Sigh. Saw what an ordinary 2" bar and ball stinger did to the front end of the guy that ran into it causing a chain reaction accident involving 4 people. And yes, I was the first guy in front of that a Prius, no less. Had a clean imprint of the car behind me's license plate frame in my bumper.
A ProPride stinger would make a massive mess out of some fool that ran into it... Mine is a bog standard 2" one. A 2.5" would be formidable.
Don't you remove the stinger when not towing?
Countryboy59 is offline   Reply With Quote
Old 09-12-2017, 07:06 AM   #18
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I lay an extended tape measure - or one of those yellow hitchin rods - lying on the ground leading right up to the mouth of the hitch at the correct parallel angle.
Then, using a backup camera stuck on the back window of our truck cap and adjusted so that I can see the end of the stinger, I just back up making the stinger end follows the line right up towards the hitch assuring that the horizontal stinger angle matches the hitch.
As for the vertical angles, I have a wooden dummy hitch bar stuck in the hitch so that I can visualise the hitch angle.
When backing the ruck, I stop when close enough so that I can still remove the wooden bar (ie the stinger does not prevent it being removed) and then I go back and using the screw jacks and tongue jack, I adjust the hitch angle so that vertically, it matches the stinger angle.
I the remove the wooden bar and continue to back the stinger in.
Seems like a lot of gadgetry but quicker to do than to explain, and generally it gets me in first try. I also have one of the sidewinder gadgets in case I need a minor adjustment.
Sometimes, if it won't go right in to the wedges on the stinger, you can pull it in the last 1/4" or so using the overcentre latches on the Hensley.
If that doesn't work, then I haven't done things right - I know (from experience!) that I cannot force it in this situation, so I pull head and repeat the process. Not too often i need to do that.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-12-2017, 09:32 PM   #19
2007 22' International CCD
On my personal tow vehicle, yes. The stinger in this situation was on someone else's vehicle, and the one that caused the 4 car Chan reaction hit that stinger. The PU was basically undamaged on the rear. He got pushed into his wife's car, which banged into my Prius. A Charlie Foxtrot of the first order...
First Aid Kit overlander63 Community Polls 79 04-14-2011 05:58 AM
Trailer-Aid Devoman Our Community 11 08-25-2006 09:59 AM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 03:37 PM
