Old 06-10-2010, 11:34 PM   #1
2012 27' Flying Cloud
Denver , Colorado
Question Groaning from somewhere down under
After several hundred miles of rainy driving we started hearing "groaning" or stress sounds from what seems to be the hitch/frame/undercarriage of our 2008 23' CCD. It only complains when I turn; all is quiet on the straight aways. But when we turn the trailer's frame seems to be groaning or creaking.
We lubed the ball, leveler bars and anti-sway bars of the Reese hitch. Not much change.
Help? Our Precious One sounds like she's in pain whenever we turn.
Any ideas?
Thanks.
Jim and Marsha
JimmyT is offline   Reply With Quote
Old 06-10-2010, 11:51 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Check your wheel bearings... the wheels are under considerable stress in a turn due to the dual axles, and this is carried by the wheel bearings. Jack up one side (between the wheels is an excellent jacking point) and spin the wheels, listening for any groaning/rumbling/drag, etc. Also attempt to rock the wheel about the vertical axis; there should be no (or virtually no) discernible play.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-11-2010, 04:54 AM   #3
Homewrecker's Avatar
1964 22' Safari
Indianapolis , Indiana
Wondered if you use "load stabilizer bars". (the towing accessory that lifts the tongue of the trailer, in order to reduce the weight on your tow vehicle bumper)
If you DO use load stabilizers, the chains can make the sound you describe when turning.
Homewrecker is offline   Reply With Quote
Old 06-11-2010, 06:11 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The reese straight line is notorious for making groaning noises when making slow turns. If that is what you are using I don't think lubing the friction cams is recommended, but a quick shot of WD 40 would tell the story.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-11-2010, 07:06 AM   #5
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
My chains "groan" in tight turns all the time. If the IP is using one of the friction type anti-sway devices, they groan like crazy.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-11-2010, 07:11 AM   #6
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Those groans may just mean that you are on the road and hitched up right. If you've ever been outside your rig while someone else is driving and making a turn, you'll try to hide so noone will know that crazed noise belongs to your beautiful Airstream! I'll bet that all is well...just part of the joy of hitchin' and travelin'. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-11-2010, 08:00 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
The nubs that fit in the receiver should be greased. All they recommend for the cams is vaseline for noise reduction only -- after all, it is the friction of the spring bars on the cams that makes 'em work right!
From reeseprod.com:
Can I grease the Dual Cam Sway Control?
Do not grease the cam and cam arms. The Dual Cam was designed to use metal-to-metal friction. Heavy greasing of the cam and cam arm surfaces will affect performance. If noise is offensive, a very light coating of lubricant, such as Vaseline, may be used. Tongue weights over 1,200 lbs. may require a light coating of grease to reduce friction and prevent excessive wear. The Dual Cam Sway Control DCSC is not to be lubricated on the cam arms when the tongue weight is under 1,200 lbs. Instead you will want to apply a thin coat of a petroleum jelly, such as Vaseline. This will act as a poor lubricant, but works well to dampen the sound. For trailers with over 1,200 lbs. tongue weight you should apply a couple of drops of an 80/90 gear lube to the cam arm to prevent excessive wear caused by the increased tongue weight.
Yet I would strongly recommend following Bart's recommendation. I run one wheel up on a ramp and check this periodically when something happens that makes me wonder if things are rolling right.
5 meter Langford Nahanni
Old 06-11-2010, 08:03 AM   #8
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Any ideas?
Thanks.
It could be the anti-sway bar friction setting. Try removing the anti-sway bar and driving to see if you can isolate the groaning....
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-11-2010, 09:08 AM   #9
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
I get that in rainy weather too. I have friction type anti-sway devices, and when they're wet, they tend to stutter on turns.
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 06-11-2010, 11:30 AM   #10
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
It's easy to have someone stand outside while on a parking lot and creeping forward turning side to side to listen where the groan or pop noise is coming from. If it's the sway bars it's probably normal. I found mine were starting to make more noise and simply wiped the wear surfaces off with a dry rag to clear debris and it stopped. If the noise is coming from the wheels you have a problem for sure.
arcamedies is offline   Reply With Quote
Old 06-12-2010, 11:56 AM   #11
Denver , Colorado
Wow, I am so amazed at the incredible wealth of experience and information on this forum. Thank you all for your excellent suggestions. You are a life saver to us newbies out here.
I'll lift the rig and listen to the wheels. Thanks for that suggestion, Bart. That was my primary concern after re-greasing all the hitch points. But with fewer than 10,000 miles on the trailer I'm guessing they're okay.
I didn't lube the friction plates of the anti-sway, just the two connecting balls at the ends. Will try wiping the plates and maybe Vaseline.
Yup, we lubed up the nubs of the leveler bars, too.
Listening from outside is a great suggestion, thanks Arcamedies and Maxandgeorgia.
Thanks again.
Jim and Marsha
Old 06-17-2010, 01:20 AM   #12
JFScheck's Avatar
Rockville , Maryland
Images: 33
ProPride Hitch - regardless of weather (55 plus winds, light rains, heavy rains, etc.) no groans in turns...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-15-2010, 09:15 PM   #13
Denver , Colorado
Thanks, John. Good to know for our next hitch.
Jim and Marsha
Old 07-16-2010, 03:04 AM   #14
Airstreamer67's Avatar
JimmyT, if you have the sway bars that connect with the little balls, I wouldn't put any lubrication on the friction brake surfaces. Doing so would be similar to putting lube on the wheel brake linings, with similar results.
With this type of sway control, it is often recommended that the friction level be reduced a bit with the adjustment handle when in very rainy conditions.
Airstreamer67 is offline   Reply With Quote
My Brakes are Groaning Alden Miller Brakes & Brake Controllers 6 08-22-2005 08:32 PM
Groaning Sound from Sway Bars Jenturnr Hitches, Couplers & Balls 7 08-09-2004 01:21 PM
