Old 06-03-2012, 12:17 PM   #29
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by urnmor View Post
…the noise is nerve wracking…
John
Think of it saying to you in language hard to understand, "I'm doing what I'm supposed to do". Closing the window and turning on the radio also helps.
Gene
Old 06-03-2012, 06:18 PM   #30
2000 25' Excella
Northern , California
The product that I refered to earlier for lubricating the hitchball and weight distribution bars, i.e., Sta-Lube’s SL3174 -- Constant Velocity (CV) Joint Grease, 4 Wt Oz</SPAN>. tube is described as: “A special lithium base grease fortified with molybdenum disulfide and polymers. It is used for the installation & repair work on CV joints. Will extend the life of the CV joint & the additives will sustain the shock loads encountered in the CV joints</SPAN>.”
It’s widely available in auto parts stores, and it works well for lubricating hitchball & WD bars.
Kamiak is offline   Reply With Quote
Old 06-03-2012, 06:44 PM   #31
WBCCI 1024,4CU
shivtik's Avatar
1985 31' Excella
Lake Havasu , Arizona
Images: 84
I took a look at the make-up of the product and compared MSDS sheets and discovered that Sta-Lube has 2-4% Moly and Yamalube 35% Moly, I had used the Sta-Lube product on our boat and pwc's and it did not seem too last too long on the shafts and such (no immersion) switched over to the Yamalube that I had on hand and was surprised at the durability. Honda also provides a similar product but found that it is cost prohibitive!
shivtik is offline   Reply With Quote
Old 06-03-2012, 06:54 PM   #32
dznf0g's Avatar
Oswego , Illinois
I also found CV joint lube to be not long lasting.
-Rich-
Old 06-03-2012, 07:15 PM   #33
2000 25' Excella
Always game to try something better. I see it is $6.99 for the 10oz tube on Amazon...if I picked the right product. I'll give it a try.
Amazon.com: Yamalube Molybdenum Disulfide Grease 10 oz. Tube: Automotive
Old 06-03-2012, 07:32 PM   #34
Maniacal Engineer
barts's Avatar
Menlo Park , California
I use a little motorcycle chain lube that contains molyd from a spray can that I have for our dirt bike.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-03-2012, 08:26 PM   #35
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use an Andersen "no sway" WD system, no grease required as the ball and the trailer move as one. Nice not to be getting grease all over everything every time I hitch up or unhitch.
MICHAEL
