Old 11-08-2016, 03:54 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Conroe , Texas
Grease on the hitch ball - is this safe?
Probably a dumb question - we have had are 2015 27FB FC for about 1.5 years now with 10 trips under are belt. I have an equalizer weight distribution / anti sway setup. My question is should I be putting grease on the hitch ball ( which cuts down on the grinding sound) or am I making an unsafe situation where the trailer could pop off the ball ??
Glenn
PSU1981 is offline   Reply With Quote
Old 11-08-2016, 04:08 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Applying a light film of grease will help everything work together and will not make the trailer disconnect, too much grease in not good!
vintagemotor is offline   Reply With Quote
Old 11-08-2016, 04:11 PM   #3
Rich W's Avatar
I'm In , Kentucky
I grease my ball, always have. If the coupler is secure it's not going to jump off. For every trailer I've ever pulled, I've greased the ball.
Maybe here, maybe elsewhere, I saw a post about someone who said they never did and once the ball ate its way out of the top of the coupler. If I can lift the back of the TV to get the Equalizer bars hooked up I doubt that it's going to jump off on the road. Besides, I hate the squeaking. If you don't have the bracket jackets, I highly recommend them. No grease, no squeak, just grease the head and spring arm sockets.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 11-08-2016, 04:18 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
"Grease on the hitch ball - is this safe?"
Yes
MICHAEL
Old 11-08-2016, 04:37 PM   #5
Journeyman
2016 25' International
Amherst , Massachusetts
Equalizer makes lube and also something called a "bracket jacket" to keep down the noise.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 11-08-2016, 06:23 PM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Even with a Hensley hitch where there is little movement n the ball grease is recommended.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-08-2016, 07:08 PM   #7
2015 25' FB Flying Cloud
Eugene , Oregon
Yes to grease!
Meeks is offline   Reply With Quote
Old 11-08-2016, 07:25 PM   #8
1973 31' Sovereign
Middletown , California
Grease is needed for a few reasons and many people cover their ball with a sliced tennis ball or something when not hitched so you are less likely to get grease on your clothes.
ijustlee is offline   Reply With Quote
Old 11-08-2016, 07:32 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think not putting grease on it would be more likely to cause an unsafe condition eventually. I use a plastic ball cover when the trailer is not hitched.
Old 11-09-2016, 10:06 AM   #10
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Folks, grease question well lubed by now but I'd like to add an additional inspection point.
Is the ball tight?
Don't fret even non mechanical types can look for stuff like this.
Ball wiggles while hitching up.
Ball shows it has been turning on the hitch it leaves a ring mark
You can slide a dollar bill under the ball flange to hitch and it slides in easily
The lock washer is spread, shows a gap, doesn't look compressed.
I've lost count of how many loose hitch balls I've spotted and helped tighten.
One was so loose the owner used a pair of pliers to snug it up before I came back with a BIG wrench.
GCinSC2 is offline   Reply With Quote
Old 11-09-2016, 10:12 AM   #11
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
Tow Ball Welded
I solved this problem by having the hitch installer tack-weld the nut to the tow ball threads so it wouldn't loosen.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 11-09-2016, 10:53 AM   #12
1955 22' Safari
Laredo , Texas
Try wax paper
Fold up a piece and place it between the ball and the coupler. Lubricates without the mess.
55AS is offline   Reply With Quote
Old 11-09-2016, 11:30 AM   #13
1977 31' Sovereign
Lynnwood , Washington
To ensure smooth operation, and to ensure the ball locks properly, I've always lathered greased inside the coupling mechanism.
Tom
TomKirk is offline   Reply With Quote
Old 11-09-2016, 11:42 AM   #14
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
The mechanics of greased balls makes them easier to slide into the cavity where, when locked in place, are very unlikely to pop back out no matter how much pushing or pulling is performed. So feel safe in the action.
Cheers....John
1977 24ft Argosy - sold.
Picinisco is offline   Reply With Quote
Old 11-09-2016, 11:45 AM   #15
2012 27' FB Eddie Bauer
Laguna Niguel , California
Grease is lubrication to limit wear and should be applied on the ball and up inside the hitch itself. Please just remember to install a rubber ball cover onto the ball while not towing. re: If you rub or lean up against a greasy uncovered trailer hitch ball and get grease on your pants and then come inside the trailer and sit on the couch like I did you will get a vicious tong lashing from your spouse . Remember ""Happy wife - Happy life""
TSOMMY is offline   Reply With Quote
Old 11-09-2016, 11:49 AM   #16
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
When we picked up our AS from Colonial RV in NJ, they greased the ball.
StreamDog is offline   Reply With Quote
Old 11-09-2016, 12:16 PM   #17
Journeyman
Did they give you a hitch ball cover? I hear they include a fair number of little extras in a get started kit or something.
Old 11-09-2016, 12:22 PM   #18
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Is the ball tight?
Amongst a many and varied career over my life, I was a Sales Agent for Premier Fasteners from Cleveland. (In the Rexdale office)
I learned an awful lot about using threaded fasteners. Allow me to pass one on:
When a fastener is tightened down, only 10% of the applied torque is actually used to tighten the bolt, to 'stretch it'. The rest is used to overcome friction; 50% on the threads, 40% on the nut face. So.......
A hitch ball that comes with a 1 1/4" shank usually calls for 450 ft. lb. of torque. This is 'dry torque'. dry threads,
Many mechanics, (me included) have torque wrenches that max out at 250 ft. lb. well short of the requirement. However.........
By using an 'extreme pressure' grease, such as 'Colloidal copper, C-5,'
'Never seize' or similar on both the threads and nut face, you reduce the friction by a lot.
According to Premier, by using those lubes, you reduce the applied torque by 35-40%.
40% of 450 is 270 ft. lbs. pretty close to the max of the torque wrench.
So... I set my wrench at max 250, sit on the ground with my foot against the car bumper, (so that I don't slid under the car), and while someone holds the ball, I pull the wrench, on the nut until it 'clicks.'
270 ft. lb. is pretty close to the spec, that will stretch the bolt to design tension.
If you are fussy enough to want that extra little torque, then use a 'Johnson' bar and turn the nut a further 5-8 degrees of turn. There you have it.
That nut should never loosen, because when the bolt tension is greater than the working load, it will never fail.
If you STILL want an extra safety, put a large 'Pal Nut' on the exposed thread, and snug it up to 1/4 turn.
Trailer Trash squatting in a Tin Can Shed.
MelGoddard is offline   Reply With Quote
Old 11-09-2016, 01:31 PM   #19
GCinSC2's Avatar
Mel,
Thanks for the tech side comments about this critical fastener.
What bugs me is the number of loose ones I've detected by EYE!
Come on folks check it or ask for help.
John Denver did a concert at the (Mel was it the coliseum south of Cleveland out in the country) back in the late '70's and a guitar player was tuning his strings and John told him when you get it right, weld it.
I think when you get the hitch ball nut tight correctly ya don't need to weld it. They come with big split lock-washers. Just check periodically. And welded may not mean it was correctly tightened before welding.
But when by eye you can see a problem somebody ain't doing inspections.
I did buy a 40" 3/4" breaker bar just for these jobs and spark plugs. JK.
My mileage ain't your mileage.
Old 11-09-2016, 03:39 PM   #20
Rich W's Avatar
I'm In , Kentucky
When unhitched, I use the bottom third of a water bottle to cover the hitch ball. I just use my pocket knife to cut off the top and push the bottom over the ball. The contour keeps it from coming off. When I hitch up again I toss it away, hitch up and drink a bottle of water on the way to the next stop.
-Rich
Rich & Yvonne
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 35 10-24-2020 08:05 PM
Grease your Ball for wear and tear? Ray Eklund Towing, Tow Vehicles & Hitches 113 04-02-2015 08:55 AM
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 12:24 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
