I have the heavy duty Reese Strait-Line Trunnion Bar Hitch and Dual Cam HP Sway Control.
I have been getting annoying squeaks from that system when turning. Especially in campgrounds. I put some Silicone on it, but no help. Having then taken all the silicone off (I understand you are not supposed to grease the hitch cams). I then tried putting a piece of duck tape below each bar cradle (where the bar pinion sits on the hitch)
Voila! No more squeaks! Replace the tape every 2000 miles as it gets worn.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
Interesting. wonder what Reese would say about that?
They (Reese) recommend using vaseline, which is what I do, and it works great. seems counter-intuitive, but apparently, its not that "slippery" that it would affect the performance of the hitch.
I don't use anything and I seldom get noise except for the first tight turn after hooking up.
The ends of ny brass arms that sit in the cams are starting to wear quite a bit after 5 years of use. The Reese rep told me to simply swap the arms right for left to get new wearing surfaces. I hadn't thought of that.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
I was wondering how long the cams would last. Mine have over 25k on them and looking well worn. I always mix up the bars with no dedicated right or left so that should help. Do you ever have t replace the cams?
