Old 12-19-2009, 06:15 PM   #1
frscott's Avatar
1986 25' Sovereign
Wichita Falls , Texas
Grease???
I was taking off my hitch today, and grimaced at the black I got on my hands. But it brought a memory of my helping my dad with the trailer hitch (sadly a Coachman), and he used a tremendous amount of bearing grease on the hitch, when I would grab that hitch I had to wash for days to get that goo off my hands! My question is why did he use it and why don't I? Should I be greasing the hitch and if so why??
frscott is offline   Reply With Quote
Old 12-19-2009, 07:25 PM   #2
SSChanger's Avatar
Louisville , United States
Greasing the hitch seems to me to be a good idea--there is significant metal-to-metal contact, and the grease would prolong the life of the hitch socket and the internal latching mechanisms. That being said, U-hall doesn't do grease on their hitches--they just hook 'em up and wave goodbye.
There is a white silicon grease that I use on the hitch ball and all of the metal-to-metal parts of the Reese Dual Cam system I use. I think it makes sense from a physics standpoint and should prolong the life of the equipment.
To keep the grease away from hands an clothing, I've inserted a 12" long, 1" diameter dowel in the hitch post assembly when I'm ready to remove and carry it. That way I can get both hands on the 40 lb piece of metal and keep the grease away from me.
Good luck!
SSChanger
'94 Excella 1000; '03 Silverado 2500HD
Louisville, Tennessee
SSChanger is offline   Reply With Quote
Old 12-19-2009, 07:26 PM   #3
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Hi Frscott,
My answer would be yes. Its a very high friction point and without grease there is wear. Since your trailer does not depend on that contact for its electrical ground and that is not considered your anti sway device then why not grease it? I dont think you need to use as much as your Dad did but a little inspection and maybe rub the grease back around on the ball would go along way.
One mans opinion..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 12-19-2009, 07:54 PM   #4
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I noticed one long-time Airstreamer not using grease. On each hook-up, he covered the ball with a square piece of aluminum foil. Ever hear of that and what do you think of it?
JStanley is offline   Reply With Quote
Old 12-19-2009, 08:26 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I use the Reese Hitch Grease on mine. It prevent wear on the ball and helps prevent the ball from loosening (I've been told). I clean all of the old grease off when I unhitch, the dirty grease leave an ugly mark on a yellow lab.
Richard
Old 12-19-2009, 08:33 PM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
An ugly mark on a yellow lab...
And if there is grease on a hitch ball anywhere in the park.. this dog will find and bring it home!
Old 12-20-2009, 01:54 AM   #7
Images: 59
Originally Posted by azflycaster View Post
. . . I clean all of the old grease off when I unhitch, the dirty grease leave an ugly mark on a yellow lab.
Yellow is a recessive color.
If you dye him black he would look just like a real Lab and the grease wouldn't show.
Old 12-21-2009, 04:27 PM   #8
SteveH's Avatar
Common Sense , Texas
I've not heard of using aluminum foil, but I have used a square of waxed paper over the hitch ball. Seemed to work OK, and it solved the mess of the grease.
Old 12-21-2009, 06:52 PM   #9
1 vote for no grease. I am sure it is better for your hitch like eating brocoli is better for you, but I hate the stuff on my hands in in the storage compartments when I have to hide the hitch in there.
I have towed a lot with my Equilizer and it is hanging in there with no grease whatsoever!!! It looks like it will last as long as the Airstream.
P.S. You have to ignore the squeaks and groans.
handn is offline   Reply With Quote
Old 12-23-2009, 09:44 PM   #10
frscott's Avatar
1986 25' Sovereign
Great info! Thanks all and Merry Christmas!
Old 12-24-2009, 07:35 AM   #11
Retired.
. , At Large
For grease on the ball and other pivot points, it is needed, or will cause more wear and noise on the parts. A guy at a trailer repair place tried to convince me to go greaseless, citing the fact that the grease attracts dirt and grit, accelerating wear on the parts more than a dry connection. I, umm, disagreed. If you grease the ball, simply put a ball cover over it, either in the form of a purpose-made cover, or simply cut a hole in a tennis ball and slide it on the ball. This will keep most dirt and yellow labs from getting together with the ball. Unless, of course, the lab chases tennis balls...
Old 12-24-2009, 10:55 AM   #12
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I grease my hitch with Chocolate
Different dogs for different lubes...
Tom
Old 12-24-2009, 11:32 AM   #13
Images: 59
Question for the forums:
Has anyone ever know a lab that doesn't?
Old 12-24-2009, 01:17 PM   #14
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
We had the tennis ball fight with our dog at first. Then had to switch to a can coozie made by coleman ( thinner and rubber not foam) It is a little loose but has never blown off when the trailer was not with us but the hitch was.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 35 10-24-2020 08:05 PM
when to grease and with what az-streamer Hitches, Couplers & Balls 13 11-28-2009 09:13 AM
Grease and Reese hshovic Hitches, Couplers & Balls 4 11-21-2009 11:10 AM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
Grease Seals niftypkg Axles 6 03-11-2007 03:02 PM
