Old 12-28-2008, 02:44 PM   #1
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Gorilla Lock
I'm going to try piggy-backing on this thread, rather than start a new one.
I just got a Gorilla Lock for the coupler, but I see that it wasn't designed for my '72's coupler design, because of a large, rolled lip, or flange, all around the socket area of the coupler. The lock has only a rather narrow slot for the coupler flange, and it would have to be just a flat one, not rolled up. So: what to do. Get a different kind of lock? or, would it be advisable to remove that part of the rolled-flange (with hacksaw, grinder, torch, etc.) so the Gorilla works? Is the entire folled-flange necessary for coupler strength? Not too much would have to come off, maybe 2 or so inches from the front. Here's a pic of the lock, showing the slot that slips over the coupler flange. Thanks- tim
tphan is offline   Reply With Quote
Old 12-28-2008, 03:40 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I have a similar situation to yours ... after thinking about it for a bit, I think I'll "split" the part that goes over the flange, with a plasma cutter or metal cutting bandsaw, and then just weld it back together with a spacer in place - all in order to make the "gap" for the lip larger. Shouldn't take too much work. That's at least cheaper than throwing away the lock and buying one with the "correct" opening.
AirsDream is offline   Reply With Quote
Old 12-28-2008, 04:02 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Any cutting on the hitch ball lip will weaken it-no mods. there.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-28-2008, 06:59 PM   #4
Kevin245's Avatar
Smile
Do Not Cut Your Coupler Flange! The rolled lip provides a substantioal strength increase. Get a different type of lock. There are others on the market.
Eleanor Roosevelt
Old 12-29-2008, 07:22 AM   #5
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Thanks all, for the advice. I will take it, and send the Gorilla back, and look for a different kind of coupler lock. -tim
how does this lock go together? BGS Doors & Locks 0 05-01-2008 02:42 PM
Argosy Lock Denise M. All Argosy Trailers 2 05-01-2007 03:33 PM
Help with lock please? centennialman Doors & Locks 10 07-06-2006 05:45 AM
Does anyone use this lock? azflycaster Buyer Guidelines 12 11-24-2005 09:20 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
