08-06-2007, 02:03 PM
1977 Argosy Minuet 6.0 Metre
Albuquerque
, New Mexico
Getting started with WD hitch
So, years ago I used a heavy duty Reese trunion bar WD hitch on a cargo trailer I put 50k miles on behind a Class C RV. Loved it. Now I will be using a Nissan Xterra and Toyota Tacoma to tow a 20' Argosy. I'm looking into what hitch to get, reading posts, and such and find that there are so many options it's bewildering.
I was wondering if there are, say, a top 5 most-used/mentioned/loved by airstreamers. Also wondering if the round bar vs trunion bars makes much difference. There are also some single-bar options.
Also, I had a super heavy-duty one before. What are the advantages/disadvantages of using one that's heavier-duty than you need? For the Argosy, I could probably get away with a 3500# unit, but why not get something rated for 5000 or 6000. That said, would it be a bad idea to get a 10k or 12k unit? I suppose they're bigger and heavier so they might be less desireable than one more suited to my lighter trailer?
I'm sure there's a tiresome number of threads on this topic, but here's my effort to narrow down the choices a bit up front. Thanks.
08-06-2007, 03:15 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings zimbop!
Welcome to the Forums and the world of Vintage Argosy ownership!
Your Argosy 20 (or it may be a 6.0 Metre Minuet as they debuted in 1977) is likely to have a loaded hitch weight of approximately 525 pounds. Unless you want to deal with popped rivets, excessive cracking of interior plastic panels (interior end caps), you don't want a hitch with spring bars that are rated significantly higher than the hitch weight -- and possibly less if you tow with a heavy duty tow vehicle such as my K2500 Suburban. When towing with my Suburban, I utilize 350 pound Reese light-weight-special spring bars (trunion style); but when I tow with my Cadillac, I utilize 600 pound Reese trunion bars.
Everyone on the Forums has their favorite hitch, but for the smaller trailers the Reese Strait Line hitch and Equal-I-zer are probably among the two most popular choices. I utilize the Reese Strait Line hitch (it includes the Dual Cam Sway Control) with both my Minuet and Overlander. After towing with this setup for nearly ten years, I am totally pleased with its performance under all conditions -- I wouldn't however, recommend friction type sway control as it requires too much attention while underway -- changing settings when wind, traffic conditions, or road surfaces change -- I had this with my first travel trailer and for a very brief time with the Minuet.
Good luck with your Argosy!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
08-06-2007, 08:48 PM
Albuquerque
, New Mexico
Could you please explain a little more about the consequences of not having the proper spring bars? I understand the concept of WD hitches, but curious about your concern with popping rivets and such.
Most of the time this will be towed by an Xterra or Tacoma, both lighter-duty pickup frame vehicles with ratings of 6000 and 5000 pounds respectively. I will occasionally pull it with a dodge Ram 2500 which is heavy duty enough to not need WD for this trailer.
08-06-2007, 10:16 PM
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
You will want anti-sway even with your Dodge 2500. For that reason you will be using the WD hitch with it, too. The two most popular hitches on this forum are the Equal-i-zer brand and the Reese Dual Cam. I have the Equal-i-zer and am very pleased with it. It is the only WD hitch I have ever used so I can't tell you if it is better or worse than any other; only that I am satisfied.
My trailer loaded weighs about double what your trailer weighs dry. It is OK to use a slightly higher rated hitch than required and it is better to go higher rated than lower rated, but you don't want to go too much higher. For your 3,500 LB Argosy, a 5K hitch would be about as high as you should go. A 10K hitch is WAY too heavy and would not give you satisfactory towing over time. It could possibly damage your "A" frame/tongue and put too much stress on the front section of the trailer and could damage that area of the trailer as well.
There are "experts" on this forum that would tell you it is better to go with a lighter duty hitch than a heavier duty hitch. They may be right and they may have the experience to back it up. I can only base my opinion on the advise I was given by my local hitch dealer and by Equal-i-zer's factory rep. The Equal-i-zer factory rep knew I was going to buy their product at that point so he had no reason to not give me his best advise. The local hitch dealer knew I was going to buy my hitch through my Airstream dealer so he had no financial stake in what I bought. So I think they were giving me straight information.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
08-06-2007, 11:54 PM
Albuquerque
, New Mexico
The straight line and equal-i-zer definitely have their differences. It all looks so rigid the way they're configured, do they really work well when turning and backing in tight spaces? The Reese trunion system I had before introduced no hassles that way. For some hitches to you need to disconnect the WD/sway components for particular maneuvers? Are there other differences that have a practical impact?
Also, the equal-i-zer and reese both seem to come in 6000/600# as the lowest rating. Is that light duty enough?
08-07-2007, 12:07 AM
Moderator Emeritus
1964 26' Overlander
Anna
Greetings zimbop!
Depending upon the degree of over-hitching, the damages can vary. In the case of my Overlander (during my first year of ownership in 1995), I averaged five or more new popped rivets after every trip regardless of miles traveled (usually a minimum of 125 miles). In addition, I began noticing new cracks in the fiberglass endcaps -- particularly the front endcap. In the case of my Overlander, I was utilizing 1,000 pound bars with a 1/2-ton pickup that had very stiff offroad suspension including factory overloads. When I took the Overlander to an Airstream dealer with experience setting up hitches for Vintage coaches, I learned about the problems with over-hitching. In addition, I learned that this was also likely why it didn't seem like my Dual Cam Sway Control was fully functional.
To nearly eliminate popped rivets, reduce or eliminate additional cracking of interior fiberglass or ABS components, and insure proper functioning of my Dual Cam Sway Control, I have found the following combinations to work well with my coaches: - When towing with the Suburban, I utilize 350 pound weight distribution bars to support the Minuet's approximately 525 pound loaded hitch weight (I always try to travel with a full fresh water tank to maintain good towing manners). When the Suburban is mated to my Overlander, I utilize 600 pound weight distribution bars.
- When towing with the Cadillac with its softly sprung boulevard ride, I utilize 600 pound weight distribution bars for the Minuet. When mated to the Overlander, I utilize 700 pound weight distribution bars.
Even with the 3/4 ton Suburban, I find that the Strait Line hitch is desirable for either coach as it increases the stability while giving a more controlled ride and handling in the Suburban.
Part of the attraction of the Reese Dual Cam System or the Equal-I-zer hitch is that it is not necessary to disconnect anything for maneuvering -- the need to remove the friction sway control prior to backing the coach was another reason I was pleased with the conversion to the Dual Cam Sway Control system. Once the hitch is properly configured for the tow vehicle/trailer combination further adjustments isn't necessary unless there is a significant change in loading of either the coach or tow vehicle.
The 350 pound weight distribution bars that I utilize with my Suburban were manufactured in the early 1980s as part of a light-weight receiver hitch package for the "new" intermediate class cars, and has not been in the catalog for quite some time. The 600 pound hitch is about the closest match out there, and may be near ideal for either your Xterra or Tacoma. They may be a bit heavy for the 3/4-ton Dodge, but may be workable.
By utilizing knowledge gained from towing my Overlander, I began towing the Minuet with a properly matched hitch (the original owner also was cautious about matching the hitch). I have been able to totally avoid cracks in the front interior endcap ABS while I have been able to avoid adding to the existing cracks in the rear endcap.
Admittedly it is inconvenient to store three sets of weight distribution bars (actually four as I still have the 1,000 pound bars stored somewhere in the barn). The difference it makes in reducing required maintence of the coach, and the increased effectiveness of the Dual Cam system the inconvenience is a small cost for the benefits provided. Actually it is more inconvenient to store the four hitch heads to accomodate towing in any of the four possible combinations of tow vehicle/coach on a moments notice.
Good luck with your Minuet. I am sure that you will enjoy its unique character.
Kevin
Kevin D. Allen
AIR #827
08-07-2007, 12:13 AM
Albuquerque
, New Mexico
Ok then, it seems the best advice is to find a good dealer to help me do it right. Not sure where to go but I'll be working on that. Is there a "favorite dealer" list somewhere on this site where users share comments on dealers in each locality?
08-07-2007, 04:15 AM
My 1998 Dodge 2500 Cummins Diesel Quad Cab Owners Manual states that a weight distribution hitch and sway control are both REQUIRED with tongue weights over 350 pounds. If I failed to do this, I would not expect my insurance company to cover any resulting accident. Your model may vary.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
08-07-2007, 07:25 AM
Albuquerque
, New Mexico
Nick.
Mine is 500/5000, but it's a standard cab, maybe that's why.
08-07-2007, 11:16 AM
2006 30' Safari
Orlando
My recommendation for advice on hitches from this point would be to take your Minuet and go to a livestock trailer dealer...specifically someone who sells horse trailers. You'd be surprised how knowledgeable they are about hitches, especially those that deal to the hobbyist. They are used to dealing with light trailers and light SUV's and 1/2 ton trucks and such.
Another good source would be a utility trailer dealer. That is where I got a ton of information. When I met the guy face-to-face, he looked about 17 (he was older) but he really knew his stuff when it came to hitches. Didn't know anything about Airstreams, but knew hitches for everything from hauling lawn equipment to horses to multiple car trailers. He took one look at my set up and told me exactly how it needed to be "tweaked" to perform perfectly and he was spot on. He seemed to know more about Equal-i-zer hitches than my Airstream dealer's shop foreman did.
WBCCI# 4821
08-08-2007, 06:09 PM
Albuquerque
, New Mexico
Ok, so I visited the local dealers today and here's what I found:
Equal-i-zer: Found one in the 1000# setup for $550 or so. The only one I saw today that has true anti-sway built in. That one looks quite a bit harder to lock in the bars. There doesn't seem to be a lever-operated mechanism like the chain-type bars have. How do you spring up the bars? With the trailer jack or something?
Valley: Found a valley round-bar setup with chains in the 400-600# setup for $313 including drawbar. Seems similar to all the other round bar types with chains.
Curt: Very similar to the Valley setup, 1000# bars, $280. Don't know much about this one but one dealer said he'd choose it because it's as good as a valley or reese and cheaper (half as much as a reese).
Pro Series: Never heard of this brand but it's a WD/antisway system similar to the Equal-i-zer, though I'm not sure exactly how similar it really is. $550.
Reese: Nobody had a straight-line, but somebody offered to order it for me for $575, no drawbar included (extra $100 or so). They also showed me the dual-cam in a catalog and advised me to stay away from it without a real compelling reason.
Blue Ox: This looked like dort of a cross betwee the standard trunion and round-bar types with chains, though they claimed it has anti-sway control by adding a bracket around the chain so that it can't move laterally as far. This seems more like sway limiting than sway control. Seemed pretty hokey. It also seemed like the bars could not be disconnected easily.
Husky: Looked like standard roundbar/chain setup. $247 for 550# version.
So that's what I learned, Having read the responses above I wanted to see the Equal-i-zer and the Straight-line [though now that I re-read some of those I guess I meant to look for the dual-cam, which I did not find except for the catalog view at one dealer who suggested I stay away from it]. Seems as though I should really get a look at the trailer tongue and be sure the positioning of the attachments for each hitch will work before I go buy one I guess.
How hard is it to set up and connect/disconnect the Equal-i-zer? For half the money there are several round bar and chain type options. Also the Reese trunion bar type. I certainly like the anti-sway simplicity on the Equal-i-zer as opposed to the relatively clumsy-seeming friction sway control bars that can be added on to the chain type, but I'm unsure if it's much harder to deal with.
There's a lot of options, and oh yeah, gotta get a brake controller too, gee whiz. Comments welcome. Thanks.
08-08-2007, 07:44 PM
Nipomo
Just slide the bars in place...no effort involved
With the Equal-i-zer you drop the tongue over the hitch ball and close the clamp. Then, with the bars in place raise the tongue while relieving the weight on the tow vehicle. Once the tongue is high enough, you simply slide the bars over the L-brackets and insert and pin the retainers.
Oh, don't forget to retract the jack before taking off. I know from experience leaving the jack down is way, way bad!!!
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
08-08-2007, 07:56 PM
Albuquerque
, New Mexico
Well, for better or worse, that's a lot more messing around than standard bars where you just lever the chain up and you're done.
08-08-2007, 09:49 PM
1994 34' Excella
Fulltiming
, Out West
We just bought an equilizer for our 34 footer and its so easy to hook up even my 60 year old wife can do it. And she could not hook up the lever and chain type..We have the 1000 lb bars and the 18 wheelers blow by us and dont bother us at all. It's very simple to adjust. We also got the Prodgy controller and that was very simple to operate. Nothing to it. Good luck in your quest.
08-08-2007, 10:00 PM
2002 25' Safari
Dewey
I don't think any of the hitches are that hard to hook up. I use a Reese with chains on the bars. I elevate the rear of my truck with the hitch jack to help get the chains on as well. I think the HA-HA has the highest level of challange, the hardest part getting the stinger into the back of the truck. I watched the Silverbacks hook theirs up this year at a rally and they made that look pretty easy as well.
Richard
08-08-2007, 10:08 PM
Moderator Emeritus
1964 26' Overlander
Anna
Greetings zimbop!
A hitch rated at 10,000 pounds would put tremendous stress on your coach. Equal-I-zer offers weight ratings down to 600 pounds -- I haven't heard whether they offer a special "light-weight" model for smaller coaches.
It is not unusual to find this situation with the typical dealer. For some reason, the typical (non-Airstream) dealer is most likely to offer the same response to the Straight-Line request -- it doesn't, however, take too long to get one from the factory or the dealer's distributor. The advice to "stay away from the Dual Cam" is another example of a dealer who's personnel have not received adequate training on the installation and setup of the hitch -- it took me multiple tries to find a dealer who understood the hitch and ordered the Straight-Line that I needed for my coach. Another oft repeated but non-factual statement is "you cannot use the Dual Cam with coaches under 4,000 pounds" -- I had heard this several times so I contacted Reese customer relations and received a message from someone in their engineering department stating that "gross weight isn't the greatest determining factor -- the most important determining factor is the gross hitch weight must be at least 400 pounds for an effective Dual Cam installation."
A photo of my '75 Eldorado Convertible with Minuet show the Reese Straight-Line hitch as I have it configured for this towing pair.
The Dual Cam is a standard part of the Straight-Line Hitch. Reese also offers the Dual Cam as a separate package that can be added to a Reese hitch at any time. Today, there are two versions of the Dual Cam -- the original that bolts to the hitch via a bracket setup (requires no drilling of the frame) -- the new version Dual Cam HP is permanently mounted to the hitch (requires drilling of frame). I am utilizing the older clamp-on style for both of my coaches and am a fan of this setup as it allows for easier adjustment if multiple lengths of spring bars are utilized to tow the same trailer (something that I experience when utilizing my Reese Light Weight 350 poun trunion bars from my first RV -- a 1980 Nomad).
Utilizing the clamp-on style Dual Cams, no modifications were necessary on my Minuet -- for easier adjustment, the LP tank mounting hardware needed to repositioned on my Overlander. It is necessary to special order the clamp-on style Dual Cam with special shorter U-Bolts to facilitate attachment to the smaller frame utilized with the Minuet (an Airstream dealer typically stocks them, at least in my region).
Can't be of much help with the Equalizer, but thought that I might clarify that the Reese Straight-Line hitch does utilize chains (in fact the clamp-on style Dual Cam uses the same chains that are removed from your weight distribution bars -- at least mine did). The chains remain on the trailer tongue rather than with the weight distribution bars. Once the Straight-Line hitch is properly installed and adjusted, hitching up is a simple task of locking the coupler on the ball and then raising the tongue with the jack to make locking the chains in the snap-up brackets a simple affair that does not require a cheater bar.
In my experience, it is very difficult to find a hitch dealer who is familiar with properly sizing and setting up a hitch for an Airstream, particularly a Vintage coach. My first 10,000 pound Reese Trunion hitch was sold to me by the most respected hitch installer in the region, but he knew nothing of any unique considerations for Airstreams being towed by heavy duty tow vehicles; and he only sold Dual Cam systems by special order.
Good luck with your hitch selection, it is indeed a perplexing arena out there with all of the new "low-cost" competitors in the market.
Kevin
Kevin D. Allen
AIR #827
08-08-2007, 10:42 PM
Albuquerque
, New Mexico
Thanks for the responses all.
AZFLYCASRTER: What is "HA-HA"?
OVERLANDER64: Great detailed info, thank you.
First of all, I wasn't planning on purchasing the 1000# equal-i-zer, specifically because of the over-duty concerns you mentioned. If I were to get the Eq I would order the 600# version, though I think they're priced the same.
On closer inspection of the Reese catalog, I understand now that the Straight-line and Dual cam are the same thing in different packages. However, the straight line pakages seem to come with a different cam bafr with an adjusting nut that is missing in the "dual cam" model. Of all the ones I've seen, these one look to be the least friendly to backing and tight maneuvering, is that a fair conclusion? They make it in trunion and round bar styles, what's preferred? For my Minuet I assume I would use the 550 or 600# models? I sort of like the idea of using a reese hitch and adding the dual cam later if I need it. Or maybe its best to just start with the whole set.
You're right about finding a dealer. There's a trailer supply house in Albuquerque who is good and I trust, but nearly all the RV dealers were mostly useless, especially the airstream dealer. They weren't helpful at all. All the guy there did is point at the one they had on dislplay and stood there with his hands in his pockets. They didn't have anyone who knew anything. In fact, that's what I got at most places. A couple had someone who had at least used one or two of them, but still couldn't offer much advice on how to set it up (which is what I used as a test to see if they really knew from experience or not).
08-08-2007, 10:50 PM
2002 25' Safari
Dewey
HA-HA is the Hensley Arrow
Great hitch at a great price. They retail for $3,000.
I can not explain how they work, I did not go to MIT.
Richard
08-08-2007, 10:54 PM
Albuquerque
, New Mexico
That's a little scary looking to me, and I AM an engineer. Is this a popular model?
08-08-2007, 10:56 PM
Albuquerque
, New Mexico
Originally Posted by overlander64
Dude, if you can tow an airstrem with your Caddy, then I'm totally done worrying about whether my Xterra can hack it. :-)
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hitch height
Chuck |
Hitches, Couplers & Balls |
20 |
04-09-2016 10:21 PM |
Hensley Arrow Hitch
Les |
116 |
12-14-2015 07:41 AM |
Hitch problem
wyhjr |
8 |
07-22-2002 05:29 PM |
Hitch inspections
83Excella |
3 |
07-09-2002 03:05 PM |
Handy hitch step
Pahaska |
Our Community |
0 |
06-26-2002 05:44 PM |
