Old 10-15-2007, 11:12 AM   #43
_
welding smelding...
removing your still pictureless bumper and professionally welding a receiver box on the underside would be fine...
but, it cannot be moved or adjusted without more fire....
unless welded by a pro it might weaken the entire hitch set up....
so what's the rating after fire?
bolts can be replaced whenever and for what ever....
basically ALL the same reasons most receivers aren't welded to frames...
unless done at assembly by robots or line pros.
yes some are, i've got a welded receiver on a unibody sports car.
cheers
2air'
Old 10-15-2007, 01:33 PM   #44
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Along the same line as 2airs' comment...the only negative I can think of; while that aftermarket bumper may be rated at 1000/10000, what about the connection?
When you buy a vehicle with the hitch from the factory, we can ASSume the entire hitch system is rated for a certain capacity.
In your case, we do not know the integerity of the fastening...
Most likely it is fine...but then again...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-17-2007, 08:11 AM   #45
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
It Fit!!!!
Apparently it took a whole bunch of work, grunting, and cussing- BUT- the hitch guys were able to get the receiver mounted yesterday-not a bit of room to spare. Another happy note is the tire fits back underneath, I wasn't sure that would be the case.
Time to start working out the settings for the hitch and take it out for a trip. Conveniently, fall break starts this afternoon....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-17-2007, 04:31 PM   #46
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Went with the P3
After a whole bunch of back and forth, weighing pros and cons, I elected to go with the P3 brake controller. The one in my old truck didn't have any problems and it took some thinking to convince myself to take the choice to go with a model that is $150 more. In the end, I like idea of the inertia control doohickey and the diagnostic abilities of the P3. It may not be a difference that matters, but at some point you pays your money and takes your chances.
Tonight or tomorrow morning I will adjust the hitch, and then its off on the maiden voyage to the local wildlife refuge north of town. The receiver and brake controller project went way past what I had planned (receiver $200 + $100 install- apparently that was money very well spent- and basically $200 for the brake controller) but its ready to roll now, I'm pretty psyched.
One can only hope that a new TV and the fofoo brake controller will make a big difference, but you never know.
Rodney
and the
My Blog
Old 10-17-2007, 07:41 PM   #47
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
P3 Question
The installation materials for the P3 indicate that the controller needs to be level. Does anyone know what the tolerances on this are? How level is level enough? Will it give me a warning? If it has to be really level, how steep of a grade can I go down without getting into brake problems?
Rodney
and the
My Blog
Old 10-17-2007, 08:38 PM   #48
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
It needs to be level as in side to side. Front to back the controller has some tolerance and it can be installed with the display tilted up but not down. Hopefully someone who has a better understanding of how they work will speak up, but I've never had a problem with grades around here in Tennessee. I can't recall if it gives a warning, but I've never had it do so.
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 10-17-2007, 09:06 PM   #49
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
WELD vs BOLTS
[quote=BillTex]
Bill[/quote
imho I believe the reason recievers are bolted rather than welded is that a
weld is difficult to inspect for integrity. You can remove bolts, inspect
mount holes and replace damaged/worn components. In fact today we
put the Stream to bed for winter, part of the winterizing
is to remove the reciever, inspect, and store in
the basement. Something not possible with a welded platform.
(sound like too much work,well it may be if the tv is over 2yrs old and you
live in bflo. i got into this habit after watching an sob platform fail while backing into a campsite)
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-18-2007, 06:33 AM   #50
1 Rivet Short
1989 25' Excella
[quote=ROBERT CROSS]
Bill[/quote
Yeah, agreed-but the General had some concerns about an AFTER MARKET hitch or bumper. No one was really familiar with it, so he replaced it...
Old 10-29-2007, 01:32 PM   #51
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Update
Moving along slowly on the project, but no big tows untill around the end of December (well maybe at Thanksgiving..). On the to do list:
1. Find a set of scales and do some weighing. The only local scales I can find cost $12 for each weight which could get expensive.
2. See if the shank of my WD head can be drilled to shorten the length between the axle and trailer.
3. Tweak out the WD system.
Rodney
and the
My Blog
Old 10-29-2007, 03:10 PM   #52
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Rodney,
  1. Many scales charge one price for the first weigh and then only a dollar or two for each one after that. See if yours does that...
  2. Before you cut the shank down consider the tailgate on your truck and if you can open it. Also make sure it isn't so short that you could hit the trailer with the truck on a very sharp turn.
  3. Tweak away!
Richard
Old 11-20-2007, 10:13 AM   #53
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
First Tow
Had the first tow with the new rig last Friday. About 20 miles some four lane and some hills.
I haven't got to the scales yet to play 100 adjustments but:
*I ran with an empty water tank and the Trade Wind only pushed the rear end down slightly (making me think it might be a good idea to stick with friction sway rather than cam).
*That trailer makes the truck ride nicer .
*Not even a hint of sway noticed. Passed by one semi (tanker) which had no effect on my rig that I could detect. It will be wonderful if this holds true over time.
*The distance was to short to make any sort of guess relative to mileage- however when not towing I run about 1,900 RPM at 65MPH in 5th, towing I had very similar results. I think this bodes well for having decent mileage towing.
* This was also the first trip with the P3 brake controller. I had to make one stop faster than I would like, but was satisfied with the controllers performance. Currently I have the output at 7 with the boost at 2, no doubt I will tweak that as I get more experience with the system.
Overall, I am quite pleased with the rig and really look forward to my trip over winter break.
Rodney
and the
My Blog
Gettin to de roof Iver Full-Timing 8 03-10-2007 07:08 PM
Stay hitched or unhitch? starflyte1 Hitches, Couplers & Balls 17 12-11-2006 08:11 PM
theVAP Episode 32: Get Hitched Safari Tim Our Community 4 11-24-2006 10:35 PM
Getting Hitched... Gwen Off Topic Forum 10 03-21-2006 08:21 AM
Accel Extreme Heat 9000 Wires R Not gettin' it! ALANSD Mechanics Corner - Engines, Transmission & More... 6 11-06-2004 05:26 PM
