Old 10-01-2007, 05:37 AM   #29
Stray
1987 32' Excella
1978 28' Argosy 28
Springfield , Missouri
Rodney,
At the time I purchased my '87 Excella, I was determined that a Hensley Hitch was for me. However, the unit came with a dual cam system so I decided to try it for a while. I've used it about 3 years now and have been very pleased. I'm not saying a Hensley might not be somewhere in my future, but I certainly feel no pressure (performance wise) to make the change.
Stray
nohillgrish is offline   Reply With Quote
Old 10-01-2007, 08:59 AM   #30
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Hi Stray,
Like I have mentioned previously, if not here then in other threads, I have no plans to go to a Hensley at this time. What I am really looking to do is to optimize the weight distribution set up I have for the best possible performance.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-01-2007, 09:51 AM   #31
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The dual cam works well for my 31. once setup correctly.
Michelle TAC MT-0
Sarah, Snowball
Old 10-01-2007, 09:52 AM   #32
Keymar , Maryland
Hensley? I thought you were not a millionaire?
Michelle TAC MT-0
Sarah, Snowball
Old 10-01-2007, 10:22 AM   #33
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I'm not, and I'm not looking at a Hensley. What I am trying to determine is if there is a functional difference between the friction bar I am currently using and the dual cam friction controls that are available on the newer Reese weight distribution hitches.
hence:
Frankly, the system I have worked excellent on the last truck, this is just a review of things to make sure I have it right.
Rodney
and the
My Blog
Old 10-01-2007, 05:14 PM   #34
Keymar , Maryland
What was explained to me is the size size of thetraielr is the deterniming factor. For the larger trailer the dual cam, for the smaller the friction. I think 24-25 is the cut over.
Michelle TAC MT-0
Sarah, Snowball
Old 10-08-2007, 07:47 PM   #35
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I'm having trouble finding a receiver hitch that will work with the drop bumper on the tow vehicle. Were these previously available and just not carried anymore? I was also wondering what the argument against having an adapter of some sort custom made at the welders would be.
I hate to get rid of the current bumper because a) I like it, b) it would be expensive, and c) it looks like it would stop a train.
btw: the bumper is rated 1000 for tongue weight and 10000 for tow.
Rodney
and the
My Blog
Old 10-09-2007, 10:14 AM   #36
Keymar , Maryland
pictures? I am not sure exactly what you are talking about.
Michelle TAC MT-0
Sarah, Snowball
Old 10-09-2007, 10:44 AM   #37
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Hi Rodney, I've used both the Equal-L-Izer and a Husky Bent Bar WD system and can't tell much difference in the way the trailer pulls. Because the Equal-i-Zer has stiffer bars, the ride is a bit stiffer, perhaps feeling a bit more secure, but the creaking, popping, and groaning those bars make when turning is unnerving! Frankly, I don't see what all the fuss is about with the Equal-i-zer. I coat the ends with parafin wax to reduce the noise, but it doen't last long, and the noise returns. If I had to do it over, I'd likely stay with the Husky I had or switch to a Reese Dual Cam.
So Long!
Bob Thompson is offline   Reply With Quote
Old 10-09-2007, 11:07 AM   #38
1992 34' Limited
Falls Church , Virginia
Road to the Alps?!?
Bob -
What kind of driving do you do - running the roads in the Alps?
Seriously, for most of the driving I do, 97% striaght line, with small deviations, the occational turn into a gas station, park at the campground, enjoy....
For this, the Equal-i-zer is the PERFECT hitch set-up. NO adjustment (Road conditions, weather) or removal required ( backing and other). I hook it up and go. Get to where I am and park the rig, period. Set it, check it at stops and that's it.
Yes, it CAN get noisy. That for me is actually a good thing - this AirStream tows SO well, that I really do sometimes forget that it is back there - A good pop or GROAN from the hitch, is an excellent reminder at the top of the expressway ramp, that I need to think ahead for gas station entry and ease of exit. At my age, reminders are good.
All for a VERY reasonable price. Hitch can be up & down graded to be appropriate for each size, type of trailer.
Safety, cost, ease of use, adjustability, Oh and.... safety!!!
Equal-I-zer system - WD and sway control in a reasonable package that is basically set-it and forget it. Works for the way I use my unit. Now if I was goin' to the Alps....
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 10-09-2007, 11:17 AM   #39
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Ranch Truck?
I still can't figure out the rig you have. I thought ALL F-250's came with a reciever hitch installed. If the previous owner could afford it...the bumper on there is a "Ranch Hand." Their drop center "Cowboy" bumpers were made for a bolt on 2 in inch reciever if it was not ordered with the hitch hole already cut in the center. Look at the trucks in the Lawton area. Also hit the wrecking yards in Lawton and Wichital Falls. Those guys know what you need....and have instantaneous connections to others in the area. Lets get you fixed up. The PPL web site has some good pics of all this stuff.
Old 10-09-2007, 04:43 PM   #40
Images: 67
Axel, yeah at times it seems like the Alps. Our last trip we spent time around Ruidoso, then Sedona and Flagstaff, then in the Sierras just east of LA. Travelled most of the Angeles Crest Highway with it's twisty turny "snakeback" layout. We had the Equal-i-zer creaking, popping, and groaning real good! Seems like they could improve the design by supporting the bar ends on rollers, then using adjustable friction pads to dampen movement. That would eliminate the creaking, groaning and popping, while still providing sway control!
So Long!
Old 10-09-2007, 04:55 PM   #41
Keymar , Maryland
The 250s only come with the hitch if you order the tow package. Most stock 250s will come with that package but you can order it without one.
Michelle TAC MT-0
Sarah, Snowball
Old 10-15-2007, 10:12 AM   #42
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
OK, after consulting with Reeses tech department, I was able to find a hitch that should fit my trucks honking big, 12 inch drop bumper. The race is on to get it installed before the trip I want to take to Palo Duro at the end of the week.
Now here is something for the engineer and/or smarter than me types. The bumper on my truck is a heavy duty, after market deal rated 1,000 lb hitch, and 10,000 lb towing. It is heavy metal and bolted into the frame. What would have been the argument against welding a receiver hitch on to the bumper and using that if I had not been able to find the hitch I did. I wonder if it wouldn't have been better since there wouldn't be bolts to fail. Comments?
Rodney
and the
My Blog
Gettin to de roof Iver Full-Timing 8 03-10-2007 07:08 PM
Stay hitched or unhitch? starflyte1 Hitches, Couplers & Balls 17 12-11-2006 08:11 PM
theVAP Episode 32: Get Hitched Safari Tim Our Community 4 11-24-2006 10:35 PM
Getting Hitched... Gwen Off Topic Forum 10 03-21-2006 08:21 AM
Accel Extreme Heat 9000 Wires R Not gettin' it! ALANSD Mechanics Corner - Engines, Transmission & More... 6 11-06-2004 05:26 PM
