Old 10-20-2013, 08:45 PM   #1
Author
2012 23' FB Flying Cloud
Seattle , Washington
Front Mounted Tow Hitches for Ford F150
Hi,
Does anyone have any suggestions for a front-mounted tow hitch for our 2013 Ford F150 so we can maneuver our Flying Cloud 23FB into an awkward space since our back hitch sits too low for the incline we have to deal with?
Thanks for your suggestions!
Tom
tschabarum is offline   Reply With Quote
Old 10-20-2013, 09:01 PM   #2
SteveH's Avatar
Common Sense , Texas
Take a look at this one: Ford F-150 Front Mount Hitch - 2013 | etrailer.com
Regards,
Steve
Old 10-21-2013, 06:51 AM   #3
aquinob's Avatar
Portsmouth , Virginia
Couple of thoughts. For starters, I've had a front mounted hitch on the last three of my trucks. Spotting a trailer in a tight spot off the front of the trunk is almost childs play so you are on the right track going this way.
But keep in mind, the front hitches usually max out at 5-600 lbs hitch weight and if your tongue weight is much higher than that, you may have problems. Also, you can always get an adjustable height hitch for the rear to raise or lower the ball as needed. On my truck, the hitch in the front is lower than the rear which works well since I have a bit of an incline to go up and it raises the rear up some. It probably comes close to scraping on the bottom by the ball, but so far thats never happened.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 10-21-2013, 08:13 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I bought the Curt front hitch for my Dodge from Amazon. It was a bit cheaper than E trailer and free shipping with amazon prime
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-21-2013, 08:47 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have the Draw-Tite. Bought thru Amazon because it was the least expensive place to buy and had free 2 day shipping with Prime. Instal was straight forward and not that difficult. There were no holes to drill. It does appear to hang low but so far no problems with that being an issue. It certainly makes maneuvering my trailer into the backyard much easier.
MICHAEL
Old 10-21-2013, 12:36 PM   #6
emdubyadee's Avatar
2007 27' Safari FB SE
Pottsboro , Texas
Bodiak
I have this one on order:
Ford Pickup Front-end receiver hitch
I did a lot of research on-line and read many good things about it. It is supposed to arrive tomorrow. My truck is a 2005 F-350, 2WD. I don't plan to back my trailer with it but will use it for a font mounted bike rack.
~ Mark
emdubyadee is offline   Reply With Quote
Old 10-22-2013, 07:23 AM   #7
AWCHIEF's Avatar
Images: 33
Mark, I like the higher mounting of that one. Unfortunately it world not work with the Ecoboost due to the inter-coolers location and no double tow hooks.
MICHAEL
Old 10-22-2013, 10:07 AM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Why not just spend $60 and get a 4'inch high low receiver insert with a 2 5/8 ball.Slide it into the rear hitch when your ready to go up that incline and you are good to go.Simple
