Old 09-07-2011, 06:40 PM   #1
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Front hitch/Receiver - 4x4 only?
okay fellow 'streamers, here's the question:
i want to add a front receiver to my 2009 f-150 crew-cab.
i plan to use is either to transport a bike rack or [rarely] to help in
parking my 22' ccd.
there are plenty of good-looking bolt-on options out there.
but it seems that all the sites refer to the need for a 4x4 TV - which mine isn't. some don't even list a option for just the 2 wheel drive.
so - is a 4x4 TV necessary for a front hitch/receiver add-on?
do any of you have a front hitch/receiver on a 4x2?
any input welcome!
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 09-07-2011, 06:44 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have them on at least 3 4x2 trucks. Not sure why they wouldn't list one, unless it needs part of the 4X4 components for mounting?
Ours were all welded up and installed by us for farm use.
Aaron
WBCCI #XXXX AIR #2495
Old 09-07-2011, 09:37 PM   #3
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
I've been considering this front mounted hitch. From the reviews, it appears to have been installed on both 4x2s and 4x4.
Hidden Hitch FRONT-MOUNT CLASS III 2" RECEIVER HITCHES - JCWhitney
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 09-08-2011, 05:27 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
...there are plenty of good-looking bolt-on options out there.
....any input welcome!
I know that this question was 2009 4X2 specific, but I found a great product here:
Front Hitch for 2005 - Draw-Tite 65022
During the mounting I saw nothing that appeared to be linded to a unique 4X4 installation, nor is there anything in the write up about installing only on either 2 or 4 WD.
This is one hell-for-stout hitch, best part is that everything fit...I did have to "rearrange" the factory mounted fog lights.
Stock
Front Bumper Removed:
Hitch Installed:
Buttoned Back Up:
The Fog Lights required a new mount location and the front license plate holder was sacrificed.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-08-2011, 11:38 AM   #5
Images: 20
thanks for all the quick replies. in response -
"I have them on at least 3 4x2 trucks. Not sure why they wouldn't list one, unless it needs part of the 4X4 components for mounting?"
- i am looking at bolt-on. maybe it has something to do with the add'l weight on the front end suspension? -
"I know that this question was 2009 4X2 specific, but I found a great product here:
During the mounting I saw nothing that appeared to be linded to a unique 4X4 installation, nor is there anything ...about installing only on either 2 or 4 WD."
- that's a great looking hitch, probably over-kill for what i need. when i checked it out for the 2009 f-150 i foundthis:
" Curt Front Mount Trailer Hitch Receiver - Custom Fit - 2"
4WD Models only "
" I've been considering this front mounted hitch. From the reviews, it appears to have been installed on both 4x2s and 4x4."
- according to the site they do not have one for the f-150 -
i guess for some odd reason there is no standard option for a front hitch. i might just be SOL. i may check directly with ford or one of their forums.
i sure don't want to buy one that looks okay and then find out that it just won't fit because there is an extra flange or off-set bolt holes.
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 01-09-2012, 04:32 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Just a note of caution ... my 4x4 front hitch receiver will not handle the AS TW without a large amount of flex ... check the specs before buying.
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 01-09-2012, 05:29 PM   #7
2000 25' Excella
Northern , California
I have a front-hitch mounted on my 2003 Yukon, and I use if for bikes, not for positioning my AS. I don't think it would handle the tongue weight of the AS. My particular brand is a "Hidden Hitch", and it bolted into position with no drilling, using existing bolts/holes, etc. It only took a few minutes. I do have a 4x4, but I just checked with AutoAnything (where I purchased mine), and the question of 4x4 or 4x2 doesn't come up. Frankly, I can't see how it would matter.
http://www.autoanything.com/Accessor...HICLE_SPECIFIC))
Kamiak is offline   Reply With Quote
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 10:10 AM
Front plate/tag holder t7389sg Classic Motorhomes 13 06-15-2011 08:24 PM
Front sway bar, Part number for Bushing ? John H. Mechanics Corner - Engines, Transmission & More... 5 06-09-2011 12:27 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 05:23 PM
64 globetrotter front sofa bed Airstream76 1960 - 1964 Globetrotter 26 02-11-2011 04:42 PM
