Old 01-11-2018, 01:42 PM   #1
1984 27' Sovereign
Kenosha , Wisconsin
Front hitch on tv?
Does anybody out there in Airstreamland have a front hitch on their tow vehicle? I have a brand new tow vehicle and I'm seriously thinking about adding one. I want to use it for bike racks and also for a kayak rack over the front with a Yakima hitch mount rack, usually used on the back of the truck with a single roof bar. I also think it would help manuevering the trailer in tight places.
Anybody have experience with one?
leif9016 is offline   Reply With Quote
Old 01-11-2018, 01:47 PM   #2
rperrym's Avatar
2017 28' Tommy Bahama
Hot Springs Village , Arkansas
I am about to purchase and mount the Draw Tite front mount trailer hitch from etrailer.
Just for my bike rack.
Rick
2017 27 Tommy Bahama
2018 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 01-11-2018, 01:53 PM   #3
2018 27' Globetrotter
Dublin , Ohio
I am also following this. I have seen the front hitch hardware. I am not sure I want to block my radiator or expense my bikes to a bug slaughter. I am mainly interested in the potential for navigation in tight quarters. The tongue load rating of the hitch I saw was only 500#. I am not sure if it has enough margin to take 800# in a low speed situation (no 3g inputs from road impacts)
Kodiak2006 is offline   Reply With Quote
Old 01-11-2018, 02:05 PM   #4
Kensington , Maryland
I went with a front hitch and 8" receiver extension with a Kuat 2 bike rack. This is a rock solid setup and I can see the bikes at all times which helps ease my worried mind
Good point regarding tongue weight. I was thinking I'd use the front hitch for tight maneuvers. No clue what the rating is, I'll take a peek at the specs. Thanks for that.
fr2 by , on Flickr
2017 25' FC FB "Buck"
Too tall is offline   Reply With Quote
Old 01-11-2018, 02:07 PM   #5
2017 19' International
Tallahassee , Florida
I had a hitch place install one, but I've not yet given it a try.
I added it to the tow to more easily maneuver the Airstream through a gate.
I'm not worried about the weight limit. It will be hitched up only briefly and in use for a few yards, and, of course, at barely moving speed.
WhereStream is offline   Reply With Quote
Old 01-11-2018, 02:08 PM   #6
rperrym's Avatar
That's the same bike rack I have. Very solid and no movement to speak of.
Old 01-11-2018, 02:30 PM   #7
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have a Curt receiver installed on the front of our 2010 Tundra. I used it with a Thule two-bike rack until I installed the Fiamma rack on the back of our Airstreams.
Here are my comments:
1. Worked well, though the front was a little nose heavy
2. Seemed like I was always taking the rack on and off, putting it on the front or back of the Tundra.
3. the bikes definitely were more exposed to dirt, bugs, highway grim etc. on the front.
4. so my conclusion is that the preference is to travel with the bikes on the back of the trailer, but on some trips, carry the rack on the front receiver empty so that we can use it to take the bikes to a trailhead, probably using the rear receiver.
Steamy1 is offline   Reply With Quote
Old 01-11-2018, 04:15 PM   #8
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
I have a front hitch on my Dodge Ram 1500. I have used it for maneuvering the Airstream in tight spaces, and it works very well. However, the need for a spotter is much greater that way, because the Airstream is so close to the driver that you can't see around it. I don't think the load rating of the hitch is a big factor at the very slow speeds used in such situations.
Old 01-11-2018, 05:38 PM   #9
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
I carry a small motorcycleClick image for larger version
FC7039 is offline   Reply With Quote
Old 01-11-2018, 06:46 PM   #10
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I use mine to carry the generator or a four place bike rack, regards, bobClick image for larger version
bobmiller1 is offline   Reply With Quote
Old 01-11-2018, 07:05 PM   #11
2017 28' International
Baileys Harbor , Wisconsin
Yep.
I have one. Bought it from e-trailer. Had it installed by professional although it wouldn’t be all that hard to do by self if you had access to a lift. Total cost to to buy and put on my 2017 F150 was about $280. We use for bikes, and the only time we don’t is if we travel at night because then it interferes with lights (I think). So then we put bikes in AS with lots of blankets. The biggest negative is you have to look over them, but you get used to it. I looked at all kinds of options and this was the cheapest and best.
Daquenzer is offline   Reply With Quote
Old 01-11-2018, 07:17 PM   #12
1977 31' Sovereign
Sunset Valley , Texas
I have had one on my last 3 trucks and will have them on every truck until the worms poop me out.
Couldn't imagine a handier addition to my vehicle, so many uses.
I've installed them all myself, easy enough if you don't mind getting down and dirty.
Ian
Iansk is offline   Reply With Quote
Old 01-11-2018, 07:30 PM   #13
1977 31' Sovereign
...and yes, with a front hitch one can stuff a trailer into some pretty absurd spots. If you saw where my 31' is right now you'd scratch your head bald wondering how I got it there.
Ian
Old 01-11-2018, 08:52 PM   #14
2003 25' Safari
salem , Virginia
I have a curt hitch as well on my 2500 duramax, I haul a small motorcycle, the max tongue weight on any front hitch I could find was 500# my bike plus the carrier are just under.
One thing to consider is the axle rating on the front and total weight on the TV, etc. Im well within spec on mine but depending on the TV and individual axle load ratings you could easily push the limits depending on what you are planning to haul.
Also it does impact maneuverability and it kills approach angle going up hills. But I love being able to take the bike on trips and would do it again.
Jeremiwvu is offline   Reply With Quote
Front End Hitch centennialman Hitches, Couplers & Balls 14 01-13-2018 09:42 PM
1998 LY 30 front tire wear on the inside edge after two front end alignments? Trident Land Yacht/Legacy Motorhomes 19 08-13-2017 01:06 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Classic FB Limited (Front Bed vs Front Couch) Sky 2006 - 2010 Classic (all lengths) 38 08-07-2011 07:42 PM
Front hitch on tow vehicle????? popeyedoyle1 Hitches, Couplers & Balls 27 06-10-2007 05:39 PM
