Old 07-10-2009, 03:10 PM   #1
2009 30' Classic
Salem , Alabama
Question Front hitch
Question: Is it possible to use a front mounted hitch on a HD TV to move or back a 30 C AS. Or? Would the weight factor be a problem, for a front mtd system. This question should probably have been posted in the dolly thread. Sorry, I could not locate that thread. Woppa4
woppa 4 is offline   Reply With Quote
Old 07-10-2009, 03:27 PM   #2
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
Yes. I have used it on the 34' with a 900 lb. tounge weight. it will squat the front. I would not go fast enough to bounce the springs, just like I would not without distribution bars on the back.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 07-10-2009, 03:27 PM   #3
Kevin245's Avatar
Sure it can be done. Not sure what size TV you're referring to, but I used to have one on a 3/4 ton Ford years ago. The PO put it on for mounting a winch, but I used it a few times to move the TT. My rig at the time had a tongue weight of approximately 750 lbs.
The problem for me that I'm so used to backing a trailer from the rear that it really messes with my brain because the steering inputs are different when manuvering from the front. And rearview mirrors don't work worth a crap this way!!!
I use a forklift at work to move mine around at times and it's always comical.
Eleanor Roosevelt
Old 07-10-2009, 03:56 PM   #4
2009 30' Classic
Salem , Alabama
Kevin: TV is 2007 Dodge 2500 HD mega C cumins tubo 6.7. woppa4
Old 07-10-2009, 04:09 PM   #5
Kevin245's Avatar
I'm not a Dodge man, but it would seem to me that you're TV has more than enough backbone for the task.
Just curious as to the reason why you're considering this option. Can you share more detail?
Regards,
Kevin
Eleanor Roosevelt
Old 07-10-2009, 04:37 PM   #6
richinny's Avatar
2011 34' Classic
just for fun, see what the door tag says about the front axle capacity.
Ricky
Old 07-10-2009, 04:40 PM   #7
2009 30' Classic
Salem , Alabama
Kevin: My previous TT was 8' wide, also 30' and my storage shed was built accordingly. I am concerned that my tolerance for error in backing into the same area with my new AS is intimatedating (using a mega cab TV). That is why I was considering the possibility of pushing it in. woppa4
Old 07-10-2009, 04:44 PM   #8
2009 30' Classic
Salem , Alabama
Ricky: 4750 Front, 6010 Rear.woppa4
Old 07-10-2009, 04:48 PM   #9
2009 30' Classic
Salem , Alabama
Kevin: TW 690 # + gas,( 40 lb bottles).woppa4
Old 07-10-2009, 05:21 PM   #10
richinny's Avatar
2011 34' Classic
4750 Front, 6010 Rear TW 690 # + gas,( 40 lb bottles)
from the tongue weight i don't think you'd have a problem, after all, they put plows on them don't they. i seem to recall that some diesels don't have much reserve capacity due to the weight of the engine. when you get some scale weights, you'll know exactly where you're at both axle wise and weight distribution wise for the rear hitch.
Ricky
Old 07-10-2009, 05:51 PM   #11
Kevin245's Avatar
woppa,
I understand your reasoning, but remember that your visability will not be as good when you use a front hitch on a TT. The absense of of sideview mirrors is a real visability issue. If your AS is of similar size, I'd use the back in method with a good spotter.
Check out ROBERTSUNRUS's avatar photo for an example of tight parking.
(Ths Small Picture on the Right)
http://www.airforums.com/forums/memb...rus-12144.html
Best of Luck,
Kevin
Eleanor Roosevelt
Old 07-10-2009, 06:01 PM   #12
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I know you don't want to DING your new AS and I don't blame ya. If you practice it becomes easier. If its dark in your storage , use a drop cord lite on the drivers side of the trailer where you want the back corner of the trailer to be and back to the lite. I in my 45 yrs with big rigs saw lots of lite bulbs mounted under docks where it was dark and the tractor was outside in the lite and its impossible to see where the back corner of the trailer is. Also those GMRS two-way radios are invaluable and inexpensive compared to a panel repair, but you will need a helper for guidence.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-10-2009, 06:08 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi,
Tight fit? Back it in slow and easy.
Name:	IMG_0699 (Large).JPG
ID:	83767   Click image for larger version
Name:	My Picture CD 196 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-10-2009, 06:16 PM   #14
2009 30' Classic
Salem , Alabama
Thanks guys. The front issue is dead. Back-in it will be. If needed; I will widen the building rather than damage my pride and joy. Tomorrow! My wife will start training as a back-in spotter. If damage occurs, divorce is also an option. woppa4
Front End Hitch centennialman Hitches, Couplers & Balls 14 01-13-2018 09:42 PM
Classic FB Limited (Front Bed vs Front Couch) Sky 2006 - 2010 Classic (all lengths) 38 08-07-2011 07:42 PM
The No# on the front... AIR-Quarius Title, VIN & Registration 31 05-06-2009 12:04 PM
Front hitch on tow vehicle????? popeyedoyle1 Hitches, Couplers & Balls 27 06-10-2007 05:39 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
