Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 05-01-2007, 08:32 AM   #1
PoconoAir
PoconoAir's Avatar
Profile:  1965 17' Caravel
Canadensis , Pennsylvania
Images: 26
Friction Anti-sway on '65 Caravel
I intend to install a good new anti-sway setup on my TV when the time comes but right now just I am in the process of rebuilding the trailer and must need to find out if there is any reason to retain this bit of anti-sway hardware on my '65 Caravel. Appreciate any input.
Barry
PoconoAir is offline   Reply With Quote
Old 05-01-2007, 08:47 AM   #2
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
Replace it
All you need on a Caravel is the anti sway. There is not any weight leveling involved if your using an appropriate tow vehicle. Sway units cost about 45.00 ...yours is not worth the time to clean it up. Love those Caravels!!
Old 05-01-2007, 08:48 AM   #3
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Barry
We use one of those in somewhat better condition with our Overlander, it is an inexpensive, old-school sway control.
Old 05-01-2007, 01:22 PM   #4
PoconoAir
PoconoAir's Avatar
Images: 26
Thanks. So I presume somewhere there is a small ball that bolts onto the TV and mates to the socket on the end of the bar with a cross pin to hold it (I see a hole for the pin). Would that part be readily available somewhere? I will clean this up and paint it then.
thanks
Barry
Old 05-01-2007, 02:28 PM   #5
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
That's the same type we use on our caravel. The hitch head has the little ball next to the big ball, which the other end of the friction sway control mounts to. I'm with Melody though, don't bother cleaning that one up, just go buy a new one. That thing looks nasty! Might give you a little more friction than you need. Can you get it to slide in and out at all?
Stephanie
Our family photo blog
Old 05-01-2007, 06:21 PM   #6
PoconoAir
PoconoAir's Avatar
Images: 26
I got it apart and right it is far gone. I'll get it off on weld/torch day. Ordered a new axle from Inland RV this morning. 2.5 weeks. If that POR-15 prevents rust like it stains your fingers it is really good stuff. Going with exterior plywood with Dr. Rot treated edges for the subfloor. Anyone here have a Carvel customized woth a rear bed?
Barry
Barry
another caravel owner davidw 1966-68 Caravel 46 02-03-2005 07:53 PM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches 19 03-19-2003 07:17 AM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 03:15 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 12:01 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 08:55 PM
