07-24-2016, 06:57 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Friction Anti Sway Bar Supports Slip
I have an EZ Hitch which is very similar to an Equalizer. It has heavy weight distribution bars which bear down on a friction support that is bolted to the A frame.
This friction support slips and cocks as the clamp force is less than the force the bar puts on the friction pad. The friction support is just two pieces of steel clamped with two bolts to the A frame. The installation instructions are clear that you don't want to over tighten the bolts as it will bow the clamp pieces creating less clamp.
Maybe it is common for the friction supports to move on these types of hitches. Mine moves maybe 5 to 10 degrees from vertical.
Maybe some of you have figured out a way to keep it from moving.
David
08-10-2016, 05:49 PM
1986 34' Limited
1975 27' Overlander
Conifer
Well, this isn't the most popular topic on Air Forums! But I know someone out there knows how to fix this problem.
My e2 hitch by Progress Mfg, Inc has a problem. It is similar to an Equalizer hitch. The weight distributing spring bars rub on the L brackets as they are designed to do, but the L brackets move. They won't stay clamped to the frame.
I see there is a lot of load on the L brackets during a turning maneuver. My installation instructions caution against over tightening the L bracket clamps so as not to bow them.
The hitch is mounted to my 66 Trade Wind. We tow it with a 09 Grand Cherokee. I have the hitch head angle and spring bars set to roughly level the Jeep. The tongue weight is estimated at 450 lbs and the trailer at 4500.
I wonder if anyone else has solved this problem and can help me out.
David
08-10-2016, 05:59 PM
Mantua
, Ohio
I've never seen an Eaz lift hitch that attaches like that. Must be knew? They always have separate sway controls. Do you maybe have a different brand like anE2. I referring to post one.
08-10-2016, 06:57 PM
1986 34' Limited
1975 27' Overlander
Conifer
Thanks for the reply. I wanted to post some photos but my supporting membership expired. Surprise! So now I'm back in good standing.
Here are some photos of my e2 hitch L brackets.
This his how the bracket moves after a 30 mile tow:
Here are wear marks on the L bracket "friction pad". It has displaced metal. I have observed that when the hitch assembly is in a sharp turn, the square spring bars rotate and do not lay flat on the friction pad. I think this accounts for the wear marks.
David
08-10-2016, 07:12 PM
1986 34' Limited
1975 27' Overlander
Conifer
Here is a website describing the e2 hitch sold by Fastway.
http://www.fastwaytrailer.com/e2-hitch
The friction sway control L brackets are simply "sandwiched" on the sides of the frame rails and clamped with two bolts. The instruction say not to get too tight to bow the side pieces, and I can understand that.
My old Trade Wind A-frame is a 5" by 1 1/2" boxed channel. The top bolt rides on the frame member, the bottom bolt has clearance between it and the frame member. This clearance allows the L bracket to pivot. Maybe if I could find the right sized bushing to take up this clearance, the L bracket couldn't rotate.
David
08-11-2016, 05:48 AM
Mantua
, Ohio
It appears the bolts used to attach the WD brackets to the aframe are too close together. Looks like you could separate them one hole. Also, putting a dimple in the frame where the bolt goes against will stabilize it. I assume the bolts are semipolnted in contact with the frame. You can also drill the frame and use through bolts to stabilize it. Do this only after you are sure the brackets are where you want them. A spot weld would also work. I've seen it done each way, your choice. Maybe someone else will have a better idea. Good luck.
08-11-2016, 07:34 AM
1991 25' Excella
Sioux Falls
, South Dakota
I too have an EQ2 WD hitch. I paid $100 for a hitch that was only used twice, truly like new.
My biggest grip is the bend in the WD bar support arms. The 90 degree bend in the metal is just too sharp. The sharpness of the bend destroys the integrity of the metal itself. I had one support arm fail on a Sunday 2000 miles from home. Found a friend of a friend who was able to do a temporary repair. He only had a stick type welder and the wrong welding rod, but I was able to make it home with his repair. Once home I had a local pro welder work on the brackets. He ground V shaped reliefs in both sides of the bend and then welded the reliefs. After welding, the inside was ground back to the 90 degree configuration. The outside of the bend was built up sightly with weld as a reinforcement. I believe that this is much stronger than the factory bends. I have not yet traveled with this mod, so therefore I reserve the right to be wrong.
And yes my brackets moved also. I intend to have the brackets tack welded to trailer frame next. If and when I upgrade the hitch the tack welds are easy enough to grind off. Drilling the frame is okay if this style hitch is the last you will ever use. Me, I am on the lookout for an upgrade at a great price.
There are a lot forces at work when the hitch is in action. While the clamp design is cheap to make it is just that.
08-11-2016, 06:03 PM
1986 34' Limited
1975 27' Overlander
Conifer
I should have removed the L brackets from the frame clamp for the photo. The two nuts shown in the photo hold the L bracket to the clamp. There are several "height" adjustments available by moving the L bracket up or down. The exploded view of this hitch is shown in the website link I provided.
There are two larger bolts that actually hold the sandwich clamp to the frame. They are not visible in my photo. The top bolt rests on the top of the frame. The bottom bolt is about 1/2" below the bottom of the frame. This bottom bolt clearance allows the clamp to pivot like a pendulum about 20 degrees clockwise or counterclockwise. I can actually hit it with a hammer (about the impact of driving a #4 finishing nail) and pivot the clamp after I tighten the bolts.
I think if I did not have any clearance of the bottom bolt to the frame, the clamp could not pivot. I may look for a thick walled bushing that would slip over the bolt and take up some of this 1/2" clearance. Or I may look into some metal "shim stock" that I could put between the clamp bolts and the frame to take up the clearance. If the L bracket was tight top to bottom between the frame rail, it could not pivot.
The first photo shows the top clamp bolt resting tight on the frame rail, and the second photo shows the clearance (about 3/8") between the bolt and the bottom frame rail.
I have also thought about drilling the frame and installing bolts or roll pins to act as a "stop" or "stay" preventing the clamp from moving. Tack welds are another option which I could grind flush if I changed hitches. Tack welds don't require holes.
My clamps are located the specified 30" from the front of the coupler. The hitch distributes the tongue weight just fine, and sway control is evident. It ain't a ProPride, but it is better than nothing.
Thanks for the feedback on a broken L bracket. Mine are also bent very sharp with little bend radius. That will cause high stresses and possibly a fracture like you experienced. I'll inspect mine for cracks.
These combination WD and friction sway control spring arms really "saw" back and forth on the L bracket while making turns. And when you turn, the spring bars do not stay aligned to the L bracket; they get cockeyed, and they actually rotate axially. It is no wonder the L bracket clamps pivot.
This pivot movement concerns me as the hitch was designed with the L bracket friction pad being in square contact with the spring bar. The wear marks I see on the L bracket can't be normal.
I'm interested in anyone else who has had trouble with the L bracket frame clamps moving on them.
David
08-11-2016, 06:37 PM
1991 25' Excella
Sioux Falls
, South Dakota
I don't know
Are you sure that the clamp brackets are supposed to pivot?
I think that the clamps are meant to fit a range of frame heights. The way I see it they should not move. Thus keeping the fiction surfaces square to each other.
08-11-2016, 07:33 PM
1979 23' Safari
Wayland
, New York
David
You have pretty much figured out the problem and the solution. The fact that there is a gap between the bottom bracket bolt and frame is what allows the pivot. The only thing trying to stop the pivot is the friction between the side plates and frame, and that will not be enough.
You can try to get a bushing or some shim material on there to eliminate as much of the gap as possible, which should stop the pivot, at least the majority of it.
08-12-2016, 05:27 AM
Mantua
, Ohio
Agree with post ten. Seems like a bushing could be used. Maybe a bunche of washers and lock washers like what is used on the hitch ball?
08-12-2016, 07:33 AM
2019 27' Globetrotter
Missouri Valley
, Iowa
David, I did what you are describing to both my Equalizer 600# and 1,000# hitches. I put a SS Tek self drilling, top and bottom of the hitch frame, on the rear edge of the "L" bracket. On the "Equalizer Hitch Thread" posts #17 and #50 is the description with some pics on #50.
Dan
08-12-2016, 06:59 PM
1986 34' Limited
1975 27' Overlander
Conifer
Thank you kindly farmer dan. I grew up and lived in Iowa for 40 years before moving to Minnesota, and now finally Colorado. I have a lot of respect for you agro businessmen. There is lots of risks and you can't set the price of your products.
I'm going to try to "box in" the L bracket clamps taking away any "pivot" clearance between the bottom bolt and the frame. I'll try that first. Then I'll try installing "positive stops" on the rear sides of the L bracket clamps like you did.
I see the Equalizer hitch folks have also had problems with the L bracket clamps moving. And like you, they have developed solutions.
David
08-12-2016, 08:13 PM
Missouri Valley
, Iowa
David, thank you for the respect compliment!!! It is quite an adjustment to go from years of $2.50-$3.00 / bu corn prices and then have a few years of $6.00-$8.00 / bu and now back in the $3.00 / bu range again. Glad I retired at the end of '09! But my son and brother-in-law are still running the family farm - so I am certainly not out of the loop yet! I am very busy at harvest time driving semis or tractor / auger wagon to help out. Where in IA were you?
Dan
08-13-2016, 06:25 PM
1986 34' Limited
1975 27' Overlander
Conifer
Farmer Dan, I have the steel shims I need to eliminate the gap between the bottom bolt and the frame. Then I need to tow it and see if the whole L bracket and clamp can slide straight back. If so, I will resort to the positive stops. I'll post the results of my test when completed. It may be a little while.
I grew up in Des Moines, then my family moved to Clarion where Dad was involved with Hagie Mfg. Then I moved to Ames for engineering college and stayed there to work for Sundstrand. Finally I found a better job in Spencer and we stayed there for 10 years.
Dad was from Lamona, Mom from Marshalltown. Dad was involved in agra business his whole career. Iowa is all about the ups and downs of farming. I worked in factories, but often dreamt of farming and being my own boss. It takes a million bucks or more just to get started. The return on investment is iffy at best.
David
08-14-2016, 05:47 PM
1986 34' Limited
1975 27' Overlander
Conifer
I was installing the shims to take up the clearance between the bottom bolt and the frame. I measure this clearance at 5/32" and maybe less with my new 1/2" grade 5 shoulder bolts.
Here is the amount of pivot that can happen with just 5/32" clearance. Backward pivot is shown in the first photo below, and forward pivot is shown in the second. It doesn't take much clearance for the L bracket clamp to really swing on the frame.
And the third photo shows the wear marks on the inside surfaces of the L bracket clamp pieces. You can see where the hitch L brackets are moving, likely during turns. There is a lot of back and forward forces on the L bracket since the spring bars rub hard on them. My bracket plates did not show any visible "bow" due to over tightening of the bolts. I see scuffed paint in the middle of the brackets, not just the ends.
However, this is one application the screams for a torque spec on the nuts. There is none in my installation instructions. The instructions say "fairly tight, but not too tight." What a spec!
I'll let you know of the shim idea eliminates this back and forward pivoting of the L bracket clamps. If not, I'll get the drill out and install positive stops.
David
08-14-2016, 06:12 PM
Salem
, Oregon
David
Hi, go to the Equal-I-zer hitch thread and you will see how I fixed this problem on my hitch and my brackets never slipped again. Buy a piece of 1/2" copper tubing, cut four pieces 2"s long, buy a third set of nuts and bolts for the frame bracket. Now install the top bolt with the piece of copper tubing between the brackets. Install the second bolt as close to under the frame as possible. Install the third bolt in the lowest hole in the brackets; Install the third bolt with the piece of copper tubing between the brackets. Snug up all of the bolts and then tighten them. The copper tubing on the top bolt will help prevent the bending/bowing of the frame brackets. The copper tubing on the third bolt will hold the brackets out so when you tighten the second bolt, the brackets won't bend or bow.
On the Equal-I-zer hitch thread there are pictures of what I have done.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-15-2016, 06:31 PM
1986 34' Limited
1975 27' Overlander
Conifer
Hi Robert. Thank you kindly for your reply. I have read the Equalizer hitch thread and the solutions to L bracket movement.
I understand the copper "bushings" cut to the width of the frame rail. (In my case, it's 1 1/2"). That would prevent any bowing of the L bracket clamp pieces. The clamp pieces are about 3/8" steel on my e2 hitch. My frame rail is 5" by 1 1/2" square channel. It's an old Airstream Trade Wind.
If I mistakenly cut the copper slightly shorter than the width of my frame rails, I may still get some bowing and thus less clamp force. And if I cut them too long, I might not even touch the frame rails. The whole hitch anti sway mechanism depends on the friction of the L bracket clamp being considerably greater than the friction of the L bracket pad to the loaded sway bars. Both my old Reese dual cam and my ProPride have spring bar supports that actually are designed to "pivot" during a turn. Sway control is not based on friction on these two hitches.
I have observed that the "pivot" does not happen if there is zero clearance between the top and bottom bolts in the clamp. My clearance is real close to 1/8". When I stick an 1/8" drill between the bolt and the frame, I can not pivot the clamp with the bolt nuts just finger tight. The photo below shows a 1 1/2" by 1/8" steel shim that I intend to install between the bottom bolt and the frame. The extra steel will give the frame a little reinforcement down there where the action is. I'll give it a try.
David
08-16-2016, 12:00 AM
Salem
, Oregon
David
Hi, David; The second set of copper tubing that I made were about 1/16" too short, but still worked great. If you did cut them no more than 1/16" too long, they would still work because the copper tubing will compress slightly. Let us know how the steel shim works for you.
08-16-2016, 05:15 PM
1986 34' Limited
1975 27' Overlander
Conifer
Hi Robert. I think I could cut copper tubing to 1.5 inches +/- 1/16". I imagine you have copper "bushings" on both the upper bolt and the lower bolt. I have a couple of questions if I might.
1. What torque in foot pounds do you use when tightening the 1/2" bolts with the copper bushings in place?
2. What clearance do you have between the copper bushings and the frame rails on your trailer? I wonder if the copper bushing take up come of the clearance between the bolts and the frame, thus preventing any pivoting movement.
David
