Old 01-08-2009, 10:13 PM   #1
Augie R.
1960 22' Safari
carlsbad , California
Found Original Hitch
Hi there folks,
So as I was gutting my AS I found this Travel-Lite Reese products tow distribution hitch thing wonder if its safe to use. What do you guys think?
Name:	OG trailer hitch.jpg
ID:	73541   Click image for larger version
Name:	OG trailer hitch3.jpg
Name:	OG trailer hitch5.jpg
augier is offline   Reply With Quote
Old 01-08-2009, 10:18 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Cool find! Fun to talk about and show off but i would go with newer technology and a little more flex in those bars. Who knows what story they have to tell.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-08-2009, 10:21 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If you don't want it, I will take it.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 01-08-2009, 10:49 PM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Hummm. Kinda looks like ours.
Lynn
WBCCI 21043
Old 01-08-2009, 11:29 PM   #5
Ifihadtime's Avatar
1981 27' Excella II
Lynnwood , Washington
Looks like ours, works great!
Ron
81 Excella II
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 01-08-2009, 11:33 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, with a little bit of paint and some grease it should work just fine. Use it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-08-2009, 11:40 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
The only issue that I can foresee is that the drop may not be correct for your current tow vehicle -- particularly if you are towing with a truck based vehicle. From the drop it looks like it was probably welded up for a large family sedan -- the one for my Cadillac has comparable setup -- probably a little more rise.
If the drawbar drop is correct, I see no reason not to use it. It is a Reese Trunion style hitch and it should accept current trunion weight distribution bars as well. Someone with knowledge of Reese products should be able to help you identify the rating of the bars -- if the setup was for a large family sedan my guess would be 750 to 800 pound rated bars. On edit -- Travel Lite bars could be as little as 350 pound rating -- I have a set of those that I use when towing my Minuet with my Suburban.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 01-09-2009, 06:36 AM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
For your S-10 Chevy tow vehicle the hitch may be adequate but you will have to pull it a while to tell. From the looks, the bars have a 750 pound rating. These may be adequate for your 22 foot trailer with only one set of wheels. Measure the bar size where it goes into the trunnion and the trailer tongue weight to see if you are in the right ballpark. Hook it up and see how level the trailer is and whether it can be adjusted to transfer the proper amount of weight to the front wheels of the truck with the proper amount of deflection. Then, you have to find out if it has adequate sway stability. You only can tell this by some time on the road at your usual tow speeds. This hitch does not have the self centering capability or the later Dual- cam hitches. If it is not stable enough for you, you could buy new frame brackets and cam adapters to make it work like a later model Twin- Cam.
Old 01-09-2009, 06:46 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Original hitch...
Looks a lot like the one that came with our 63 Safari.
Ours did have an adjustable drop and friction sway control. Worked great for us for 18 seasons, but then again that was long before we knew anything, (like the Forums), ignorance is bliss I guess.
Don't know exactly what the #s on the bars mean, but I thought it might help.
Name:	63 Safari Hitch 003.jpg
ID:	73554   Click image for larger version
Name:	63 Safari Hitch 004.jpg
Name:	63 Safari Hitch 001.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-09-2009, 06:59 AM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
With a little paint and cleaning, the hitch "could" be usable. The hitch ball height is important as Kevin already mentioned. When stripping the old paint from the hitch head, look for cracks in the "welds" or for any signs of metal fatigue. And for sure, replace the hitch ball and torque it properly.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-09-2009, 07:03 AM   #11
Originally Posted by augier View Post
Hi there folks,
The ball height must match the trailer.
That ball mount can be cut apart and rewelded, 3 times.
The rating of the bars, may or may not be correct, depending on the exact tow vehicle you have.
You can measure the top of the square bar, as it enters the trunion, to determine it's rating.
1" = 500#
1 1/8" = 750#
1 1/4" = 1000#
Your hitch is load leveling only. You can add the dual cams, to include the sway control setup.
Old 01-09-2009, 07:08 AM   #12
Crusty's Avatar
1992 34' Excella
Looking for cracks in your hitch
An easy way to find cracks is to pour some liquid WD-40 into a small can and mix some Rit black or red powdered dye into it. Paint the solution onto the part, let it sit for a while and then wipe off any on the surface. Cover the part with talcum powder and let it sit for 30 minutes or so. Any cracks will be visible as a black or red line in the powder.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 01-09-2009, 08:33 AM   #13
Road Ruler's Avatar
Images: 38
There are a number of advantages to the old style, welded ball mounts. The first is that there are no nuts/bolts to come loose.
The 2nd and big advantage is the compact WBM has the ability to get the ball as close to 3 inches from the back bumper of the tow vehicle. This reduces stress on the vehicles hitch and reduces flex.
Having the ball close to the back bumper improves the wheel base to overhang ratio. This makes the TV act as if it had a longer wheel base.
One of our ball mounts is a 35 year old Reese WBM. Works great and is preferred.
Old 01-09-2009, 10:26 AM   #14
Kevin245's Avatar
Valid points about inspecting the welds and hardware. We check the welds for cracks and fatigue, and we check the equalizer bar cups on the hitch for work hardening. Stress cracks caused by flexation, or work hardening are typically tight and shallow and can be difficult to see with the naked eye.
We use magnetic particle, or liquid penetrant test methods. In the absence of NDT equipment use eye magnification and supplemental lighting to assist you.
It looks like your hitch has the original paint, which often indicates little use.
If you were closer I'd gladly test them for you.
Good Luck With Your Project,
Kevin
Eleanor Roosevelt
I Found The Original Owners!! centennialman WBCCI Forum 26 04-19-2008 06:11 PM
What have I found? juel 1966-68 Caravel 20 10-04-2007 11:22 AM
Look what I found! Minnie's Mate Off Topic Forum 4 05-25-2007 05:24 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Found One- 1973 Ambassador! Rivetedude 1970 -1973 Ambassador 27 05-11-2005 04:11 PM
