Old 02-17-2013, 04:02 PM   #1
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Ford Hitch Weld Question
We have a 2012 F250 6.7 Diesel. The truck came with a Class V receiver bolt on. Our trailer is away for the winter, however, while washing the truck I noticed a BB size hole in the weld holding the actual receiver on the bar which bolted to the truck.
I am going to take the truck in for an inspection by our Ford dealer, which through the years has been fair, but wanted to see what some of you might think before she goes in for the look see. Under magnification I don't see any other faults in the weld, but obviously there could be.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-17-2013, 04:12 PM   #2
Connellsville , Pennsylvania
Could you post a picture of the weld?
Midnightmoon is offline   Reply With Quote
Old 02-17-2013, 04:24 PM   #3
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I would recommend taking it to a welding shop and have them die test the weld.
I believe a welding shop would be better qualified than the Ford Dealer.
It wouldn't hurt to take it into the Ford Dealer. The repair should be covered under warranty.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 02-17-2013, 04:32 PM   #4
paiceman's Avatar
Tried to post picture, but the forum asks for the pictures URL? No idea
SAFE TRAVELS
Bud
Old 02-17-2013, 05:19 PM   #5
paiceman's Avatar
Pictures attached
ID:	179193   Click image for larger version
SAFE TRAVELS
Bud
Old 02-17-2013, 05:46 PM   #6
It doesn't look like that is in a location where it will cause any structural issues. But, since it is such a new truck, I would certainly see what Ford can do for you.
Old 02-17-2013, 06:05 PM   #7
1965 30' Sovereign
Ottumwa , Iowa
i would take it to the ford shop its under warranty they should replace the hitch since thats not a stress fracture its a flaw in the weld if they wont then go to a weld shop they will redo the welds but i worked for ford and if you ordered the truck with it it should be covered and thats what i would do. try and get a new one
cjohnson is offline   Reply With Quote
Old 02-17-2013, 06:10 PM   #8
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I am of the opinion that you should ask Ford to replace it as well. That looks like a great place for corrosion to get started and possibly weaken the hitch. Play it safe.
Old 02-17-2013, 06:17 PM   #9
Kevin245's Avatar
What you see is the end of two welds occurring on opposite sides of a common plane. Welds in this configuration are not typically joined at the ends due to stress concentration considerations. The gap is a function of the joint geometry.
Eleanor Roosevelt
Old 02-18-2013, 05:02 AM   #10
paiceman's Avatar
Thanks all, going into the Ford dealer later this week.
SAFE TRAVELS
Bud
Old 02-18-2013, 06:05 AM   #11
Kevin245's Avatar
See what Ford says. If they replace it that is great for you, but the hole left between the weld end appears to be a cosmetic issue. At a minimum I would suggest you rinse the area free of any road salt/brine, then let the area dry and seal the opening with caulk.
Hope it works out to your satisfaction.
Eleanor Roosevelt
Old 02-18-2013, 08:06 AM   #12
dznf0g's Avatar
Oswego , Illinois
I agree 100% with Kevin245. Not a big deal.
-Rich-
Old 02-19-2013, 04:56 PM   #13
paiceman's Avatar
Thanks all. Took the truck to a welder, over 30 years in the business he echoed what Kevin and DZN said. Cancelled the special appointment with Ford. Will have them look at it when it's in for service. But we are no longer concerned.
Thanks again
SAFE TRAVELS
Bud
