Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 01-20-2011, 07:48 PM   #1
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Ford hitch 2.5" to 2" adapter
There was an earlier thread wherein someone had experienced a poor fit using after market adapters to reduce the 2011 Ford Super Duty 2.5" hitch to 2". Some may have received the adapter when they purchased the truck, but I as others did not. I too had problems with after market adapters, one bought from a truck supply center, one from a national brand auto parts store, and one bought from Uhaul. All three were very poor fits resulting with a very sloppy connection. I had mentioned I had found a brand that worked well in that thread, but couldn't remember the brand name at the time. I went to my shop and still had the box. It is a Cequent Performance Product #58102 and fit very snugly both in the receiver and around the stinger. Google it and you will find it. Hope that helps. hal
hhendrix is offline   Reply With Quote
Old 01-20-2011, 08:13 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Thanks for the tip!
I've got several brands lying around, after some guy (not sayin' who!!??) after unitching at home and putting the stinger and all away, forgot that he still had the adapter in place but no lock pin in place ... this guy drove off down the road in my nice GMC 2500 ... and somewhere along the way, the adapter fell out. So I started buying them, but none fit real well. Glad to hear of one that will fit.
AirsDream is offline   Reply With Quote
Old 01-20-2011, 08:21 PM   #3
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
My hitch fits perfectly from the factory.. I have a job 1 truck with the 3.31 rear end. Maybe thats the reason I don't need an adapter.
Shane
https://i52.photobucket.com/albums/g...h_postcard.jpg
Tow Vehicle" 2023 F250 Azure Gray!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 01-20-2011, 08:26 PM   #4
AirsDream's Avatar
1999 23' Safari
Mine fit perfectly from the factory also ... but if you're gonna' tow with a 2.5" receiver and a 2" stinger, you have to use the (factory supplied) adapter. So: if you manage to lose the adapter (or um, ah, er, have some guy lose for you!), you'll need a new one.
Old 01-20-2011, 08:30 PM   #5
_
the early 11s had a 2 inch receiver, while waiting for the mid year UPgrade...
to the higher rated 2.5 inch version.
check your window sticker/invoice,
there was a 125 ??? dollar discount for the older receiver, on those 'job 1' trucks.
dually trucks have come equipped with the 2.5 inch receiver 4 a long time.
and the oem sleeve/adapter fits nicely, at least mine does.
the 2 inch receivers ford uses have been very good for many years.
my guess is the op is referring to this thread and posts #19-21
http://www.airforums.com/forums/f463...ast-72877.html
cheers
2air'
Old 01-20-2011, 09:01 PM   #6
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
2air' - any chance I can get a picture of your stinger so when I order my 2.5"er from Sean I can have a starting point?
Pretty Please?
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-20-2011, 09:21 PM   #7
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
The guys on a major ford forum are all over the map on this topic. With the ford part, a lot (like 2air) say it fits perfect. Mine and others are too small and sloppy, others say it fits perfect if you hammer it in.
newroswell is offline   Reply With Quote
Old 01-20-2011, 09:54 PM   #8
_
Originally Posted by JFScheck View Post
...a picture of your stinger...
pictures ?
how about 50 of them...
post #18
here http://www.airforums.com/forums/f464...tml#post756150
and then continously from ~ posts 90-130, lots of stinger shots.
the only difference IF opting for the 2.5 inch without adapter (not my recommendation) is this piece...
here http://www.airforums.com/forums/f464...tml#post775220
which will be 2.5 inch stock, all the others pieces are the SAME size as original and totally interchangeable.
cheers
2air'
Old 01-21-2011, 07:19 AM   #9
SteveH's Avatar
Common Sense , Texas
Just one question....why on earth do manufacters put a 2 1/2" receiver on these trucks? Have you ever seen a 2 1/2" drawbar on a WD hitch? I have not. (sorry, I guess that's two questions)
My 3/4 ton GMC came with the same sloppy adapter, and between it's slop, and the natural slop needed for insertion and removal of the WD hitch drawbar, it was just too much. My solution to the problem was to weld a 2" receiver into the 2 1/2", and the problem was solved.
I understand they want a higher weight rated hitch, but why don't they just use thicker 2" ID receiver material?
Regards,
Steve
Old 01-21-2011, 08:59 AM   #10
Chief Chili Cook
newroswell's Avatar
I guess the engineers said they needed a larger size in addition to making the tube walls thicker. Yes, I have seen a 2.5" drawbar on a WD hitch, mine!
Old 01-21-2011, 09:14 AM   #11
ProPride Industries, Inc.
Sean Woodruff's Avatar
Holly , MI
Good question. I don't have the answer but it does make one wonder.
When I make the 2.5" receiver end of the hitch bar for the 3P it adds 5lbs to the piece. 19#(2x2) to 24#(2.5x2.5). The sleeve is a lot lighter but we do whatever makes our customer happy and the 2.5" is what some want.
Curt Mfg. does make a high rated receiver with a 2x2 opening.
ProPride Hitch
"The Most Advanced Generation in Trailer Sway Elimination"
Holly, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 01-21-2011, 09:33 AM   #12
Portland , Oregon
Originally Posted by AirsDream View Post
Thanks for the tip!
I keep a stinger in at all times as a bumper protector.
Old 01-21-2011, 11:23 AM   #13
SteveH's Avatar
OK, now I've seen one.
Regards,
Steve
Old 01-21-2011, 02:33 PM   #14
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Originally Posted by 2airishuman View Post
pictures ?
cheers
2air'
(Slaps self in face with open mouth) Dugh...
How could I have forgotten....
**I Love U.S.A.**
Old 01-21-2011, 05:26 PM   #15
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Oh, and Sean, that reminds me... I need to order MY 2.5" stinger for the new truck - will call you latter next week!
**I Love U.S.A.**
Old 03-28-2011, 08:32 PM   #16
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Just picked up the Ford 2.5 to 2 inch hitch reducer...
Yes- it was costly but fits perfectly...
Although I have a 2.5 stinger ordered from Sean - still nice to have the reducer if ever needed...
**I Love U.S.A.**
Equalizer hitch benefits Moonstruck Hitches, Couplers & Balls 34 01-19-2011 08:03 AM
Hensley Hitch Value Jerry Knowlt Hitches, Couplers & Balls 5 01-18-2011 08:05 PM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 07:22 AM
How and When to Measure Hitch Height lcurrie Hitches, Couplers & Balls 9 12-30-2010 01:59 PM
