Old 05-07-2013, 02:33 PM   #1
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
For Equalizer Hitch Users
Could those users of equalizer hitches that are now also using an AirSafe hitch tell me if they had to make any adjustments to their equalizer setups when they installed the AirSafe hitch.
Rick
rperrym is offline   Reply With Quote
Old 05-27-2013, 08:45 PM   #2
bhooves
2013 27' Flying Cloud
Livingston , Texas
A year ago, when we first started looking for an Airstream, the Dealer said that we need an Equalizer hitch for a 27' FB Airstream (7600 lbs Gross). Now that we are purchasing one, they say that the professional drivers who deliver the Airstreams from the Factory to Buda, Texas use no hitches at all. Therefore, the dealer thinks that I don't need one either. In both cases--the earlier opinion and the current one--I told them that I would use a new Ford F-250 to pull the trailer. So, do I really need an Equalizer Hitch; or should I just use the trailer as it comes from the factory?
Thank you in advance for any thoughts on this. --Bhooves
bhooves is offline   Reply With Quote
Old 05-27-2013, 09:47 PM   #3
aftermath's Avatar
Spokane , Washington
bhooves,
I think you just hijacked this thread. But, to answer your question, Yes you need some kind of weight distributing hitch with anti sway. I use the Equalizer but there are others out there that do a fine job.
I would imagine that there are some pretty big trucks out there that might not need the WD feature but everyone benefits from anti sway. I pull my 25FB with a half ton and really like the benefits I get from my Equalizer. I wouldn't pull without one.
aftermath is offline   Reply With Quote
Old 05-27-2013, 10:41 PM   #4
steverino's Avatar
2018 30' Classic
Ivins , Utah
Your F250 probably has a class IV hitch good for 600 lbs tongue weight without weight distribution, and 1000 lbs with. As the 27FB has a hitch weight above 600 lbs, WD is needed.
It's likely the commercial rig that delivered the unit had a class V hitch.
steverino is offline   Reply With Quote
Old 05-29-2013, 07:04 AM   #5
bhooves
Livingston , Texas
Sorry if I hijacked the thread. Actually, I was considering adding only the Equalizer Hitch. Ths was my very first post on Airforums.
