Old 03-17-2012, 07:15 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
First time with an Equailizer
The dealer set up the head with the ball and initial number of washers for the head tilt.
I read the instructions and set the brackets back at the rear setting and lowered the gas line under the bracket bolt on the right side.
The pivot point at the head were very stiff and I had to use the WD bar to move the pivot in the head. If that makes no sense well I am tired.
Once I got the WD bars on the L brackets and the Jack retracted. The distribution was close. A little nose down on the trailer and nose up on the trailer.
Since I was only going a short distance I left it alone.
It towed like silk! I was impressed! I had towed with the Reese Dual cam for nearly 80,000 miles. I am glad I switched.
2006 31 Classic
2006 F-250 Diesel towing package
10,000lb bars
Michelle TAC MT-0
Sarah, Snowball
Old 03-17-2012, 07:18 PM   #2
LFM
LFM's Avatar
2007 19' Safari SE
Laurel , Montana
Which trailer?
LFM is offline   Reply With Quote
Old 03-17-2012, 07:21 PM   #3
Keymar , Maryland
2006 31 Classic
Michelle TAC MT-0
Sarah, Snowball
Old 03-17-2012, 07:24 PM   #4
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
What is your TV & what size bars on the hitch?
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-17-2012, 07:29 PM   #5
Keymar , Maryland
Ford F-250 Towing package.
The bars are 10,000 lb.
Michelle TAC MT-0
Sarah, Snowball
Old 03-17-2012, 08:20 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Me Too
Having towed three Airstreams with Reese Dual Cam Sway Control for 10 years, I thought I was in love.
Then, I bought the new/used 2007 Classic Limited 30' that came with an Equalizer.
I disparagingly used it for "just one trip" until I could switch to Reese.
The Equalizer tows like a dream.
Even out on I-40 running with the big dogs.
I'm keeping it.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 03-17-2012, 09:10 PM   #7
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
I don't understand the basics of equalizers yet, so if anyone wants to elaborate, it's much appreciated. We are about to take delivery of a new 2012 flying cloud that comes with a Reese equalizer hitch. We have a diesel F-250 as our TV, so no problems there.... Our Sport 22 FB didn't need any special towing equipment.
Hibby
Hibby is offline   Reply With Quote
Old 03-17-2012, 10:32 PM   #8
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Just glance at the brackets that clamp your trailers frame when you walk by. Sometimes they pivot.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 03-17-2012, 11:09 PM   #9
1974 Argosy 20
Kooskia , Idaho
The easiest way to think of an equalizer is this: Imagine weight on the ball of your trailer, it will make the rear of the TV drop and the front go up, taking weight off the front steer tires. Now imagine putting two wheelbarrow handles fixed to the TV hitch so you can lift it back level. When you do that, you take weight off the rear axle and put it on the front.
Now tie the wheelbarrow handles to the frame of the trailer to hold them up. That will put the lifting force on the wheelbarrow handles back onto the trailer tires. So, the ball weight is "equalized" between the trailer, the back TV and front TV axles. The sag in the center, caused by the ball weight on the back of the trailer is gone.
Oversimplified, but easy to visualize and may help you understand things.
Old 03-18-2012, 03:37 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
"Equalizer" is a tradename for a form of weight Distribution hitch. "Equalizer" hitch uses friction to damp out sway, once it occurs, and the same friction resists the ability of trailer to move away from being straight behind the TV. "Reese Twin Cams" are also a weight distribution hitch system but uses the forces developed on the cams, when the trailer is not directly behind the TV, to cause the trailer to center behind the TV. There also is some friction on the cams, which acts as a dampening force.
Old 03-18-2012, 05:53 AM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The Dual Cam is still the superior design. But not by much. Key on either it or the Equal-I-Zer is proper set-up. That can take time and is rarely done as well as could be. Experimentation is an acquired taste.
Old 03-18-2012, 06:08 AM   #12
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Make sure you put a little grease ( I use the stuff Equalizer sells) on the pivot points in the head (page 23 or the owner's manual). Don't use it on the L brackets, friction there helps sway control. Also, make sure you check all the bolts every time you tow. They will loosen.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-18-2012, 06:13 AM   #13
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Idroba, thanks! That helps create a clear visual. We are getting a Reese unit...
Hibby
Old 03-18-2012, 07:55 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Reese does not make the Equal-I-Zer hitch. Reese makes the dual cam sway control.
Equal-I-Zer is made by Progress Mfg. Be careful what you order, so you don't get a surprise.
replacing 1141 incandescent bulbs with LED Globie64 Lights - Interior & Exterior 28 07-20-2014 09:09 PM
New LED light kit with sealed lights Dan@LED4RV Commercial Listings 18 08-26-2012 11:18 PM
94 Airstream 190 Class B Van RV Ford with Generator eBay Watch Airstreams on eBay 0 03-16-2012 06:50 PM
Anyone Near Cass Lake to Look at An Airstream for me? Mary Burris Dollars & Cents 6 03-16-2012 04:13 PM
