08-12-2014, 08:45 PM
#41
Sneedville
, Tennessee
I wish I had known that the Reese hitch had a brain.
08-12-2014, 09:02 PM
#42
2012 25' Flying Cloud
Battle Lake
Rich, good to know. Andy's and your experience matters and builds trust.
But why does Sean at ProPride recommend 1400# bars, and they also work so darn well. Before this I had a light duty hitch with no bars (Andersen) and it did not work well with our rig, poor steering control. And that would be my concern with light hitch bars on a half ton truck and heavy tongue weight.
Doug and Cheryl
08-12-2014, 09:08 PM
#43
Oswego
I, frankly, don't know. I don't know how Sean rates his bars, but I would never put ANYTHING over 1000# bars on my 30'er. It would be interesting to see flex measurements of Sean's bars against some others, like my HAHA 1000#ers. I think my Hensley 1000# bars are a bit too much, but there are no other offerings.
There is no consistency of bar ratings on the market, in my opinion and experience.
-Rich-
08-12-2014, 09:22 PM
#44
Battle Lake
Rich I think your 30 Classic and our 25 FC have similar tongue weights, your truck is a 3/4 ton and ours a 1/2 ton (rear coil springs). A lot of the flexibility I see in our combination is in the truck and Airstream suspensions, especially in the truck.
Andy usually recommends light bars on a heavy duty truck, and heavier bars on a light duty truck. That also makes sense to me and may result in good ride and "enough" weight distribution in either rig.
Doug and Cheryl
08-13-2014, 06:59 AM
#45
Oswego
Doug, I use a bunch of (company) tow vehicles. When I was using the Reese w/800# bars, I also used them on Escalades, YukonXLs, Avalanches, 1500s, etc. They worked very well. This was without a lot of weight in the back, like my scooter, boat motor, SIB, etc. With the 1/2 tons, I had more WD applies and had every bit of 2 - 3" of bar flex. With the 2500s, not so much needed.
-Rich-
08-13-2014, 07:22 AM
#46
Oswego
Here's an example I dug up out of the archives. This is a Yukon XL (2011, IIRC) with actual Sherline TW at 850 - 900#s.
-Rich-
08-13-2014, 08:08 AM
#47
Battle Lake
Here's our ProPride 1400# in Lemoore, Calif last April, heavy load in Airstream.
Doug and Cheryl
08-15-2014, 05:23 PM
#48
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We use the 1400 bars from Pro Pride cranked to 6" with our rig and we ride level without beating up the trailer.
08-15-2014, 05:35 PM
#49
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Don't you have about #1,350 TW? If so, that would be reasonable I'd think.
Doug, Nice rig!
Lance
