Old 05-28-2007, 03:50 PM   #15
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
As those charts clearly indicate you can safely go over 65 MPH if you know the weight load and are +10lbs over that.
"Based on industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph, it is necessary to increase the cold inflation pressures by 10 psi above the recommended pressure for the load."
So if your load is say 2,000lbs at 50psi by inflating your tires to 60 psi you can do 75mph.
'77 Sovereign Intl 31' CB
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 04:24 PM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
2002-2003 A/S 25 foot motorhome betteleal Airstream Motorhome Forums 11 11-24-2002 12:44 PM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
Tank sizes in '85 Soverign 25 foot j54mark Waste Systems, Tanks & Totes 5 06-16-2002 08:03 AM
