Old 06-07-2009, 01:00 PM   #1
SteveH's Avatar
Common Sense , Texas
Equalizer vs Reese Dual Cam
No, I'm not trying to start a hitch "contest", but I am looking for information.
I'm seeking information from people who have actually towed one trailer, or simular trailers with each type of hitch....Equalizer and the Reese Dual Cam, and how each handled sway.
Don't want to hear your opinion of how your hitch does if it's the only one you've ever had, or if your heard such and such about one of them from your brotherinlaw"s second cousin.
I realize there won't be many people who have towed one, or simular trailers with both hitches, but that is what I'm looking for, and I want to know specifically how you rate each hitch ON SWAY CONTROL ONLY.
Thanks, and I look foward to your input.
Old 06-07-2009, 01:14 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I own an Equalizer hitch, a Reese/Drawtite w/d hitch with frictional damper, as well as a Reese Dual cam. I have towed 31 and 26 foot Airstreams with Ford and Dodge vans and now use a Chevy long bed crew cab dually. Set up properly, the Equalizer was equal in performance to the Reese with the frictional dampener. I did not experience any trailer damage from the Equalizer but it looks like it could cause problems. I no longer use the Equalizer. Conditions and driving experience change over time and I think the Reese twin Cam was better that the frictional system when I was towing the 31 with the van. My wife had problems with both of them when she drove in heavy truck traffic. Now that we have the dually, she tows the 26 foot overlander without a problem even without the w/d bars attached. I think it all about the truck size/weight and the stiffness of the sidewalls and lateral stifness of the suspension of the truck as well as the lower weight of the Overlander.
Old 06-07-2009, 07:00 PM   #3
SteveH's Avatar
OK, thanks for your input, but just so I understand correctly, you are rating the Equalizer equal to the Reese/Drawtite with the frictional sway control, and the Reese Dual cam best of the three. Is that correct?
Hopefully there is more input from some others.
Old 06-07-2009, 08:04 PM   #4
JimGolden's Avatar
1977 31' Excella 500
flip a coin
I pulled a 26' Terry with a front slide out using a Reese Dual Cam. I took it across the Chesapeake Bay Bridge when there was some breeze blowing. I was white knuckled (my first time towing a travel trailer) but the Reese did just fine. I don't recall it having much sway at all.
I have pulled my 34' Avion all over using an Equal-I-Zer, and I have noticed no sway whatsoever with it.
I think they're both good hitches. I could argue that the dual cam wants to fight you just as much when you want to make a turn as does the friction type. In actual use, I've seen no real performance advantage of one over the other.
Personally, I find the Eq easier to hitch up. I didn't like the grease and fighting the chains on the Dual Cam. They are both noisy when making tight turns.
Anyway, they're both good.
As for finding somebody who has used both extensively on the same trailer....good luck. I would only consider replacing my Eq with a Hensley or a ProPride, and I would bet you $20 all the Dual Cammers feel the same way about there pick.
Best of luck with whichever one you get.
- Jim
JimGolden is offline   Reply With Quote
Old 06-07-2009, 08:29 PM   #5
SteveH's Avatar
Thanks Jim, and just so you know, I curently own a Reese Dual Cam, and have had others in the past, but never an Equalizer. So, just wanting comments like yours from people who have actually used both.
Old 06-08-2009, 10:40 AM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've had both hitches and currently use the Equal-i-zer. You can't go wrong with either but both have their own traits which one might find a benefit or a liability. The Equal-i-zer has more components that need connection when hitching. Loose one component and you may be in trouble. To that extent Equal-i-zer sells a spare parts box which contains the pins and other small parts that could be left behind or lost. I carry one and have never had to use it. You also have to properly torque a couple of bolts occasionally that provide a friction component to the sway control.
The Reese has a chain type of system that is used to provide the proper amount of lift. Pick the wrong link when you hitch up, or if you don't match the links on both sides, problems may occur. When you set up the Equal-i-zer at installation, it's done forever, unless you change trailers. Typically the Reese's sway control is based on a cam system rather than friction, which is providing force to push the trailer into a straight line behind the tow vehicle. The Equal-i-zer is using a friction based control that is based on hitch weight and two bolts that I talked about in the previous paragraph. Unlike other friction based controls, it needs no adjustments for weather conditions or backing.
The other thing that I like about the Equal-i-zer is the ability to hitch up or unhitch when the tow vehicle is at a bad angle to the trailer. It's not often but I have had to jockey in some back in sites due to narrow roads, trees, other parked vehicles that have caused the tow vehicle to be at a bad angle. The result in some cases was that there was not enough clearance to get the Reese tow bar out of the stirrup that the bar slips through resulting me having to jockey the trailer and tow vehicle enough to get that angle removed. No issue on the Equal-i-zer.
My local dealership owner sells both hitches and based on customer feedback the Equal-i-zer gets great marks from its owners. To be honest I don't believe we've seen any negative feedback on either hitch.
I pulled a 27' Safari with the Reese and a 30' Classic Slide Out with the Equal-i-zer with the same tow vehicle. Quite honestly I've felt that the Equal-i-zer has done a little better job that the Reese did when dealing in heavy cross wind situations. Whether that has something to do with the fact that the Classic outweighs the Safari by 2,000+ lbs. or another 500 lbs of hitch weight may be part of the reason. I just know we drove up to the Moraine View rally a couple of years back with some terrific cross winds in excess of 30 mph hitting us directly on the side. The folks following me on that road noted that the Classic just stayed behind the van without showing any evidence of wind induced sway. That made me a believer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-09-2009, 09:02 AM   #7
SteveH's Avatar
Thanks Jack. I apprecate your input, and is exactly the type I'm looking for.
Anyone else have an input on the subject?
Old 06-09-2009, 09:53 AM   #8
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Steve, there's one other thing to keep in mind as you get info on the Reese Dual Cam hitch... there are several generational iterations of that hitch and it's components floating around out there. While I presume that they all perform similarly, that is solely a presumption on my part.
The variants (at least a partial list) are:
The standard drawbar/ball welded component mount head
The hi-performance forged steel drawbar/ball mount head
The bolt-on two-armed saddle assembly
The bolt-on one-armed 'Reese Straight Line' saddle assembly
And then the trunnion bars have had several iterations themselves...
for quite a number of years, the top of the saddle assembly bolted to the regular WDH trunnion bars. Those were wear items and could be replaced. In later years, the trunnion bars are forged with the saddle top as an integral part of the end of the bar. To further complicate the trunnion bar issues, they've been issued in a number of different weight ratings over the years as well.
Over the years I've used all of the variations in combination to good effect. It's just interesting to know which components, exactly, are being discussed by owners. Also having spoken with various RV dealer's part's counter folks and various Reese dealers over the years, it is a rare individual indeed who understands ANYTHING about the product they're selling, much less how to set it up and use it correctly.
Roger
Old 06-09-2009, 10:12 AM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Roger is quite correct regarding the Reese and it's many iterations. The one I used had the square trunnion bars and was the current model at the time which was at least 10 years ago. I first used the Reese on my SOB 30' trailer. When I got the Safari, I upgraded the trunnion bar to heavier capacity models due to the increased hitch weight of Safari.
I went to the Equal-i-zer since the heavy hitch weight of the Classic slide-out pushed me into the need for a Class V receiver and hitch. I could have gone with the Reese offering but with so much good word out there on the Equal-i-zer, I decided to make the change.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-09-2009, 10:56 AM   #10
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
I have not owned a Reese Dual cam, I do have the Equal-i-zer. Reason I chose it over the Reese, is I also have an enclosed snowmobile trailer with a straight tongue, like a boat trailer, rather than the traditional "V". With the purchase of another set of "L" brackets, I am able to use the same Equal-i-zer head and bars on both trailers. All I have to do is adjust the hitch head height for what ever trailer I need to tow. "L" brackets stay put.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 06-09-2009, 12:11 PM   #11
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
I've had both, although they've been with different trailers. The Dual Cam was difficult to get adjusted at first, but once it was dialed in it performed beautifully. I feel that they both performed equally well at preventing sway, but I tip my hat toward the Dual Cam due to physics.
With the Equal-i-zer it takes just as much effort to get the trailer back in line as it takes to get out of line, or better stated, the Equal-i-zer trys just as hard to stop the movement back to center as it does with the initial sway. With the Dual Cam, the cams are always trying to return to the high point in the trunion bar, thus the Dual Cam is actually trying to return you to center. This can be a life-saver if you find yourself towing in slippery conditions.
I liked the fact that the components on the Dual Cam were bolted into the trailer frame and didn't move or loosen like with the Equal-i-zer. Right now the Equal-i-zer is scraping up my frame and causing some rust.
I feel the Dual Cam was easier to hitch up and it was definitely easier to adjust for those days when you have a bed full of fire-wood and need an extra chain link to make up for the extra weight. That kind of adjustment requires a wrench with the Equal-i-zer. All you need to hitch the Dual Cam is a breaker-bar. The Equal-i-zer requires two bolts, four cotter pins and two L-brackets. It's a little more work to hitch the Equal-i-zer, but not enough to sway one way or the other. Just an observation.
Hope that helps.
Steve
Steve
TinLoaf is offline   Reply With Quote
Old 06-09-2009, 01:38 PM   #12
SteveH's Avatar
Roger
Roger, Yes, I am aware of all the different "generations" of the Reese dual cam hitch because I've owned and used several, and now own and use the latest version with the bent trunion bars (I've tried two different weight's on recommendations from members of this forum :-( ), and the adjustable cam bolts, and quite frankly, it does not perform as well as the older versions I used to have.
Tinloaf,
Thanks, and yes I fully understand the "physics" of the Reese Dual Cam hitch, as I said above, have used them for years. I'm not trying to argue against their virtues or design, I just want a consensus of users that have also had the Equalizer opinons of just how well it stacks up against the one I have. I have not owned an Equalizer and would like to know how they actually work without haveing to go buy one. This is the only way I know of getting the information short of buying one and useing it myself.
Steve
Old 06-10-2009, 09:01 PM   #13
SteveH's Avatar
Anyone else use both hitches?????
Old 06-11-2009, 05:19 AM   #14
85MH325's Avatar
Tipton , Iowa
Images: 37
Steve
Mine have always been the square trunnion bar models which I'm actually quite happy with... and frankly your reasoning is exactly why I've just always stayed with the Dual-Cam... it may be kind of lame, but I have always figured that struggling with the devil I know is better than the one I don't.
Roger
Equalizer vs. Reese Dual Cam for 23' Int'l CCD? mmccurdy Hitches, Couplers & Balls 9 11-10-2007 11:10 AM
new reese dual cam Bing-Bing Hitches, Couplers & Balls 11 05-27-2007 12:40 PM
Reese dual cam HP junbe Hitches, Couplers & Balls 12 04-07-2005 06:10 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
