Old 08-23-2009, 08:02 AM   #15
Cracker's Avatar
Pittsfield , Maine
This has been discussed many times but, in general, I've found that very little weight can be restored to the front axle of my 3500 series TV without requiring excessive loading of the equalizer bars. Likewise, only relatively minor "unloading" of the front axle occurs - even in a "dead load" arrangement. Excessive "hitching" is hard on the trailer - whereas the TV could care less. That's why many of us with heavy-duty TVs have opted to use 600 lb bars and been very happy with the results. Do a search and you'll find a wealth of information about the subject - much of which is in conflict with the hitch manufacturers directions.
Cracker
Cracker is offline   Reply With Quote
Old 08-24-2009, 10:40 AM   #16
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by flmgrip View Post
with all respect... what has this copied text to do with anything talked about here... more than one person mentioned also that measuring the fender height will only get you that far...
From your original post it appeared your hitch was not set up correctly and I was just going some insight as to how to correct your problem.
2004 Excursion 4x4
TV towing question setup Barry Parkof Tow Vehicles 24 10-22-2008 11:54 AM
Hitch height question, is my setup safe? damonbeals Hitches, Couplers & Balls 13 04-16-2008 11:06 AM
I've had it with equalizer! Resorts Hitches, Couplers & Balls 47 08-29-2007 08:59 PM
Equalizer Question Relentless Hitches, Couplers & Balls 72 07-16-2007 08:13 AM
Equalizer FiveGreers Hitches, Couplers & Balls 19 02-02-2006 04:44 PM
