Old 10-04-2017, 06:54 PM   #1
70CT's Avatar
1974 21' Globetrotter
2016 30' International
Houston , Texas
Equalizer Hitch Question
Sorry vintage folks.
Can anyone share the bolt sizes for the equalizer hitch set up (both at the hitch and on the trailer)? In SC for business and plan to set up the TV this weekend when I get back. Want to make sure I have all the tools. Thanks!
70CT is offline   Reply With Quote
Old 10-04-2017, 08:30 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Shank bolts - 1-1/16", you will need a wrench to hold one end and a BIG torque wrench on the other end, 350 lb. ft. IIRC
Bar socket nuts - 15/16", socket only, the bolts are welded to the head
Trailer bracket bolts and nuts - 3/4"
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-05-2017, 11:41 AM   #3
70CT's Avatar
Houston , Texas
Thank you Al!
Old 10-14-2017, 08:33 AM   #4
Mollysdad's Avatar
Save your back.
1/2" drive "breaker bar" from Harbor Freight is about $20.
1 1/8" socket for bolts, I choose a deep socket so I'd clear the bolt threads. (actually, two of these is better, one for each side, or a 1 1/8" box end wrench.) Then, add to your collection a 3' piece of pipe about 1 1/2" ID, enough to go over the breaker bar.
Those nuts holding the shank bolts are tight! Position the hitch in the receiver so you can slip the pipe over the breaker bar and pull away from your vehicle (to avoid bashing the back if it slips)
Old 10-14-2017, 08:47 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I believe that if you are also putting the ball on the hitch you will need a torque wrench that gets up around the 400 to 450 pound range. Needless to say, this is a lot of force.
Old 10-18-2017, 11:42 PM   #6
2016 23' International
Victoria , British Columbia
Trying to choose the 'right' equalizer anti-sway hitch for my 'week old' 2016 23FB (4806 # dry, 6300# GVWR, 440# TW) with a tow vehicle similar to a Porsche Cayenne (6600# maximum towing capacity. Will tow maybe 2000 miles per year. BTW, no towing experience here - new to the 'lifestyle'!
Any help / advice / experience feedback is most welcome. Many thanks.
Greg_Small is offline   Reply With Quote
Old 10-19-2017, 12:07 AM   #7
Mollysdad's Avatar
For a smaller trailer I'd consider this hitch by Fastway.
Fastway is the jr. brand for Equal-i-zer.
https://www.fastwaytrailer.com/e2-hitch
Old 10-19-2017, 01:23 AM   #8
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Greg. We have setup hundreds of Porsche’s and Touareg’s. I would suggest an Eaz-Lift with 800 lb torsion bars. It is much easier on the hitch receiver because the bars are tapered. This gives you more range of motion going through dips etc. If you like send me an email andy@canamrv.ca and I can send you instructions on how to configure it correctly. The 23FB tows best with the fresh tank full.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 10-31-2017, 01:27 PM   #9
70CT's Avatar
Houston , Texas
Fascinating! Curious as to why?
Old 11-03-2017, 04:25 AM   #10
Vintage Kin
Fort Worth , Texas
Look at a schematic. Where is it located relative to axles? Offset, or centerline? Is it above or below floor level?
Old 11-03-2017, 06:52 PM   #11
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Correct. The tank is under the floor between the frame rails just forward of the axles.
Andrew Thomson
London, Ontario
Old 11-04-2017, 08:13 AM   #12
Half a Rivet Short
Hi
Weight distribution / balance / center of gravity matter a lot. It's not just about the total weight involved. That's true in way more than just trailers. Boats and airplanes most certainly get into issues very quickly if things they are loaded poorly.
Equalizer hitch adjustments Raptorrider2001 Hitches, Couplers & Balls 4 09-22-2017 10:45 AM
Installed the Equalizer hitch today....question. Bob McAlice Hitches, Couplers & Balls 14 05-09-2010 04:55 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
