01-17-2011, 02:57 PM
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English
, Hampshire
Equalizer hitch benefits
Hi from the UK!
I have a 1972 23ft Safari with a gross weight of 3600lbs
The tongue weight is 450lbs
I have a guy who wants to tow it with a 530 BMW Touring
The "Beamer" has a max hitch capacity of 220lbs
I want to know what difference an equalizer hitch would make?
What percentage advantage would be gained with the hitch?
Marc
01-17-2011, 03:09 PM
1974 Argosy 26
Morrill
, Nebraska
TOOOO! Much trailer for the BMW. Especially if the hitch on the car is not rated for an equalizer hitch. It should say on a label on the hitch or in the owners manual. I certainly won't do it.
01-17-2011, 03:19 PM
Retired.
, At Large
Tongue weight doesn't change with a wd setup. All the wd does is move the weight through the tongue to the front of the tow vehicle.
The only way to reduce tongue weight is to make the tongue weigh less.
01-17-2011, 03:38 PM
2005 30' Classic
Burlington
, Ontario
Hmmmmm.
Not meaning to argue, but I always thought that the way an equalizing hitch worked was by removing a portion of the load off the hitch and throwing some up to the front axle of the TV and some back to the trailer axles and that it did this by making the trailer and tow vehicle frames more or less "one."
It seems to me I read someplace that compared to the initla load on the ball without an equalizer, with an equalizer hitch properly set up, you would have 1/3 of the hitch weight remaining on the ball, 1/3 transferred up to the TV front axle, and 1/3 thrown back to the trailer axle(s).
Wouldn't be the first time my understanding was all wet but that is what I thought.
If that is correct, wouldn't it put the tongue weight within the acceptable range in the original poster's example?
Off course there would still the the issue to address as to whether the BMW's
hitch is rated to handle a trailer with the GVW of the AS in question.
Also, the BMW's wheelbase might not be my idea of the best for a tow vehicle, but then the trailer he is considering is pretty short.
I'm sure someone more knowlegeable will correct me if I have made any incorrect statements - I certainly don't want to spread bad info, especially with an important subject like this!
Brian
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-17-2011, 03:59 PM
Corona
Originally Posted by Wingeezer
Hmmmmm.
Brian.
Brian.
The formula for weight distribution is easy, provide certain requirements are met.
A proper rated, properly installed, properly adjusted weight distribting hitch, by actual measurements, will transfer 2/3 of the tongue weight to the tow vehicle and 1/3 of the tongue weight back to the trailer axle/axles.
Again, if everything is correct, 1/4 of the weight that is going to the tow vehicle, will go to each wheel.
Back in the days when most of used cars for tow vehicles, the hitch would also transfer "trunk" weight as well.
When the trunks were heavily loaded, that weight could also be transfered to the front axle of the tow vehicle, as well as some of it would go back to the trailer axle/axles. How much was a function of the setup and adjustments.
Having a good load equalizing hitch setup, however, does not correct for a poor tow vehicle.
Physics still rules out.
01-17-2011, 04:08 PM
Oswego
However, application of the spring bars to "move" weight creates an incredible amount of torque or twist through the receiver into the "frame" of the TV. If the TV isn't robust enough, it'll distort the chassis and pull out/break the mounting bolts. Another thread discusses just such an occurrence. Only the beginning, me thinks!
01-17-2011, 04:17 PM
2008 30' Classic
Tampa
Load transfer and tongue weight.
I have measured and the bumper of my truck rises as I tighten my load transfer bars. That indicates to me that I'm moving weight off the hitch. I've got a Hensley, 2008 30' Classic and a Dodge 2500 2008 diesel. I have verified on the scales that I'm moving about 400# to the front axel by weighing with the bars adjusted to where everything appears level and then pulling back onto the scales with all tension on the bars released. I'll have to go back to my paperwork to see if there was any change in the trailer axel weight.I see a corresponding transfer from the rear truck axel to the front axel. Do I understand that if properly adjusted, all tongue weight is moved to the tow vehicle and the trailer axels? Would this result in no weight on the hitch? Jerry.
Jerry, Irene & Clancy
01-17-2011, 04:24 PM
Oswego
No it doesn't. In a perfect world, you would move the tongue weight equally through the AS and TV chassis to have it equally distributed along that plane. Never happens in the real world due to many variables....and maybe shouldn't.
There will still be some tongue weight on ball and a very high clamping force between ball and coupler.
Port Orchard
Weight vs Force
The problem is the choice of the word weight when talking about the tongue of a trailer.
The scientific definition of weight is the mass of an object times gravitational acceleration. Gravitational acceleration can be accepted to be constant at a give location for this purpose. So tongue weight is always constant once the mass of the tongue has been determined.
However what is important here is not the weight of the tongue. What is important is the downward force being exerted by the trailer hitch cup on the ball of the trailer.
As we all know, this downward force can be changed by a number of things, including trailer loading and angle of the trailer frame in relation to level.
A weight distribution system is a system of levers that causes this force to be distributed over the length of the TV/Trailer system.
It is as if you were standing the trailer , reaching down, and lifting up on the rear of the TV. As you lift up on the rear of the tow vehicle, you will be removing some of the downward force. Since this force is pivoted around the TV rear axle (fulcrum) it will produce a downward force on the front axle. However as you are lifting, you are also increasing the force with which your feet are pressing down on the trailer. This force is what appears as increased weight on the trailer axle.
Maybe it would be clearer if they were called force distribution hitches.
Yes, I have too much time on my hands.
Regards,
Ken
Hmmmmm.
Brian
Brian.
01-17-2011, 05:00 PM
_
first let's answer the OP needs specifically.
the 530 touring is the euro version of the 5 series station WAGON...
and it can be used for towing a 70s 23 footer, with minor tweaks.
the 220LB (100 kg) rated receiver is with ON THE BALL TOWING...
IF the receiver isn't rated for w/d gear that's it.
OTOH if the receiver has 2 ratings (which is doubtful)
as in with/without w/d, the rating WITH w/d will be higher.
IF the receiver is NOT rated for w/d of any sort,
the OP needs to buy an aftermarket replacement receiver rated 4 at least 500lbs or ~class iii in north american parlance.
the aftermarket receiver might carry that 500 lb rating WITH or withOUT w/d depending on model.
using w/d WOULD be useful since it would help to REload the bmw steering axle,
which will be LIGHTENED 150 lbs or so without w/d.
there are class iii receiver versions compatible with the OEM holes on the bimmer,
or a welding shop (visavis caNam) could fabricate the connections onto the unIbody.
__________
cheers
2air'
01-17-2011, 05:05 PM
Port Orchard
After rereading my previous post, I think the below quote should be changed to read:
As you lift up on the rear of the tow vehicle, you will be applying upward force that will counteract some of the downward force.
Regards,
Ken
01-17-2011, 05:07 PM
Oswego
using w/d WOULD be useful since it would help to REload the bmw steering axle.
their are class iii receiver versions compatible with the OEM holes on the bimmer,
__________
cheers
2air'
However, if BMW doesn't have the dual rating (I assumed not) there is a reason. If BMW does not recommend a "Weight distributing" tongue weight spec. there is a reason probably having to do with the chassis/suspension construction. I would not add a different receiver to accomodate a higher distributed load without BMW's blessing. I believe ignoring this will result in eventual substantial repairs and perhaps safety issues.
01-17-2011, 05:09 PM
_
yes ken that's better.
________
the op appears 2b confused a bit about what w/d does (as many here are)
there is no "percentage advantage" gained and no alteration of WHAT the tongue weighs using w/d gear.
there are 100s of posts in other threads that coherently splain this,
but posts #3 and #9 get right to the pith and core.
________
along with the confusion related to the terms weight vs force,
the term 'load equalizing' should be trashed.
it's intentionally confusing and serves almost NO modern towing need or discussion.
except for the 'brand name with the Eq' term, all other use of this confusing term should be banned...
along with the folks using it.
cheers
2air'
01-17-2011, 05:12 PM
Oswego
Ya know...after giving this some thought.....with global companies, there may be a "communication" issue here. I gather, from this forum, that trailers in Europe are not typically of the size to require weight distributing hitches. BMW of Europe may not publish specs for weight distributing hitches while BMW
USA may for the very same vehicle. If you call BMW Europe, they may not even know what the heck you are talking about. Try BMW USA for a spec.
01-17-2011, 06:21 PM
2005 30' Classic
Burlington
, Ontario
Originally Posted by Moonstruck
Hi from the UK!
Marc
So, it seems as though your potential buyer can tow this trailer with his present vehicle as long as he can obtain a suitable wd hitch rated at max 500# hitch load and 5000# GVW for his BMW.
The trailer GVW is however getting close to the top of the tow rating for his vehicle, and many folks would prefer to see a little larger margin of rated capacity vs actual GVW. 75-80% is an often quoted rule of thumb.
I suppose the relevance of that would depend on how often he intends to tow and over what sort of terrain & operating conditions.
A good anti-sway bar would also likely be a worthwhile investment depending on the type of hitch selected.
Brian.
2005 Classic 30'
01-17-2011, 06:28 PM
Oswego
Wait a minute here. Do we have another problem? Doesn't Europe require surge brakes? I thought I read that somewhere. You can't use a weight distributing hitch with surge brakes, can you?
01-17-2011, 07:56 PM
2005 30' Classic
Burlington
, Ontario
Surely the electric brakes with which the AS should be equipped would only be an improvement over surge brakes wouldn't they?
Do you mean that European regs would specifically require surge brakes rather than just specifying that "brakes are required" over a certain trailer weight?
I had surge brakes on our first travel trailer (very light weight, no equalizing hitch).
They did work ok, but on the setup I had, it was a pain in that every time you wanted to back up you had to get out and throw a lever on the hitch to stop the brakes from activating, otherwise the trailer wheels would lock up when you tried to reverse!
Brian
(PS I'm not 100% sure, but I think I have read of some designs of hitch/brakes that will permit use of a surge brake hitch with an equalizing type hitch.)
2005 Classic 30'
01-17-2011, 08:02 PM
Oswego
Brian
Yeah, I'm not sure. I agree that electric or electric over hydraulic is superior to surge, but I thought I read that and I thought the AS's built for Europe had surge brakes.
01-17-2011, 08:16 PM
Oswego
A lot of info here. Can't find anything specifically on brakes, but loo at #3 below.
FAQ < Airstreamer | Airstream Europe : FAQ, frequently asked questions, how, where, and what
3. Buy new for Europe – Can't I import from the USA? Some people do, but the majority of units offered 2nd hand in Europe are those built after 1969, with wider (8ft or 8ft 6") bodies and relatively heavy gross weights and nose weights. This makes them illegal in some countries and a poor/ potentially unsafe match for most EU tow cars.
US origin units are not compliant with UK/ EU requirements, they may need repairs (which can be difficult to cost) and will need the gas, electricity, axles and brakes changed before they can be used safely. They are sold without manufacturer's warranty; appliances are not EU origin making service & spare parts hard to obtain, and insurers may decline to provide cover etc. Maintenance, especially of vintage vehicles can be expensive and very time consuming.
Even fully converting a US model, the one thing almost impossible to do is change the axle position. US axles are set further back than EU models and therefore the nose weights are way in excess of what EU tow cars are manufactured to be able to manage safely.
01-17-2011, 08:22 PM
Oswego
Boy! If some of us have issues with friction sway control, we'd really not be comfortable with this!
http://www.winterhoff.de/Bilder/WS3000-02_GB.pdf
This Winterhoff gizmo is required in Europe.
