Old 07-27-2016, 07:40 AM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Equalizer height adjustment
Towing my 2014 25FB with an F 150. Buying a F 250. Will the height of my Equalizer need to be lowered due to the difference in receiver height?
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 07-27-2016, 07:47 AM   #2
2015 25' Flying Cloud
Manheim , Pennsylvania
I had a Ram 1500 and bought a Ford 250. I had to buy a different shank to get the right height. I tried every way to make it work with the drop shank, it wouldn't work for me.
Youtube channel "Airstream Adventurers"
https://www.youtube.com/channel/UCW4...NOHJQUM1yyDLAw
Jukeboxfun is offline   Reply With Quote
Old 07-27-2016, 09:15 AM   #3
GoWhereTowed's Avatar
texas , Texas
Probably
If you are reading this, it means I have made it another day!!!
GoWhereTowed is offline   Reply With Quote
Old 07-27-2016, 09:19 AM   #4
paiceman's Avatar
Upper St Clair , Pennsylvania
Most Fords I've had have the same receiver height. But, the suspension on the new F250 will be heavier and might require an adjustment on your part. I went from an F250 to an F350 and no change.
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 07-27-2016, 10:56 AM   #5
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
I needed to get a different shank when I went from a Chevy 1500 to a 2500. The receiver height was higher on the new truck and the suspension was stiffer. I found my best deal on a new shank at Summit Racing. If you have hole positions lower on your existing shank, you may be fine, but start off by measuring the height difference between the 150 and the 250 and see if there is much difference. If not, you may just need to play around with the head pitch based on the suspension stiffness.
rdepas is offline   Reply With Quote
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 04:24 PM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 06:50 AM
Torsion axle adjustment question, height, possible or not? redneckhippy Axles 13 12-22-2007 09:25 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 08:47 PM
