Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-27-2016, 06:40 AM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Equalizer height adjustment
Towing my 2014 25FB with an F 150. Buying a F 250. Will the height of my Equalizer need to be lowered due to the difference in receiver height?
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 07-27-2016, 06:47 AM   #2
2023 25' Globetrotter
Manheim , Pennsylvania
I had a Ram 1500 and bought a Ford 250. I had to buy a different shank to get the right height. I tried every way to make it work with the drop shank, it wouldn't work for me.
Jukeboxfun is offline   Reply With Quote
Old 07-27-2016, 08:15 AM   #3
GoWhereTowed's Avatar
texas , Texas
Probably
If you are reading this, it means I have made it another day!!!
GoWhereTowed is offline   Reply With Quote
Old 07-27-2016, 08:19 AM   #4
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Most Fords I've had have the same receiver height. But, the suspension on the new F250 will be heavier and might require an adjustment on your part. I went from an F250 to an F350 and no change.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 07-27-2016, 09:56 AM   #5
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
I needed to get a different shank when I went from a Chevy 1500 to a 2500. The receiver height was higher on the new truck and the suspension was stiffer. I found my best deal on a new shank at Summit Racing. If you have hole positions lower on your existing shank, you may be fine, but start off by measuring the height difference between the 150 and the 250 and see if there is much difference. If not, you may just need to play around with the head pitch based on the suspension stiffness.
rdepas is offline   Reply With Quote
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Torsion axle adjustment question, height, possible or not? redneckhippy Axles 13 12-22-2007 08:25 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
