Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 09-25-2003, 03:52 AM   #1
boltos
boltos's Avatar
Profile:
Equalizer bars...need one.
I need a replacement equalizer bar for one side. It is the older trundle style with about an 1-1/8" diameter bar that fits up into the trailer hitch on the truck on one end and hooks by chain to the trailer on the other. If anyone knows a source for this item, please let me know. If a picture would be helpful, I can post it.
Thansk in advance
Brian Sawyer
Lexington, KY
Brian Sawyer,
Lexington, KY
boltos is offline   Reply With Quote
Old 09-25-2003, 07:02 AM   #2
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
I may have one
I may have one. I've got a complete trunion set that was on my 1967 Tradewind. You can email me with details if youd' like. I was planning on selling the entire set. Jim
Tin Hut is offline   Reply With Quote
Old 09-25-2003, 06:07 PM   #3
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
banjo music.....
canny bj man,
if you like banjo music, you'll like this....it will have you tappin' yo toe when you're sleep walkin'....dont wait, dont hesitate...go down to the music shop and get:
Natallie MacMaster- Blueprint
Alison Krausse+Union Station-Live
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-26-2003, 10:21 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Brian!
I might suggest that you consider replacing both bars at the same time. When I was faced with a similar situation, technicians at three different hitch shops told me the same thing. It will likely be VERY difficult to get two bars with differing amounts of use properly adjusted (through time, the bars tend to take a set based on the trailer/tow vehicle combination that evidently can interfere with being able to properly adjust the setup when bars from two different setups are mixed), and it can be quite difficult to get two bars with the same weight rating - - especially if the manufacturer didn't clearly mark the weight rating of the bars.
Reese still manufactures the heavy duty "round bar" hitch, so the replacement weight distributing bars should still be available. The hitch is still listed on their site at:
Reese Trailer Hitches
Good luck with finding a solution to your hitch problem.
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Mirrors and sway bars Pahaska Parts Archive 1 03-27-2004 09:31 PM
weight distributing bars/trunnion bars teutonik Hitches 2 12-04-2003 07:58 AM
Do I need to grease WD bars? Stefrobrts Hitches 7 10-26-2003 07:54 AM
Equalizer hitch adjustments Raptorrider2001 Hitches 2 03-25-2003 10:35 AM
