Old 06-06-2005, 11:58 PM   #1
Bradjun1's Avatar
1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
equalizer bars
I am towing a 74 tradewind with a 02" 2500HD Duramax. Needless to say I have all the power I ever wanted. This is also the tow vehicle for my 99 34 Limited. My Problem is the hitch. The hitch that came with the Trade Wind is a draw tite and it has 1000 pound bars with it. Aren't these too stiff. Should I be looking for a 500# set. Can I damage the trailer with these heavy bars. Where is the best place to get 500# SET.
Bradjun1 is offline   Reply With Quote
Old 06-07-2005, 05:53 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Yes, the lighter the better on that vehicle. Especialy if you are using a Reese Dual cam. The coach likes a shofter suspension tow vehicle.
Search "over hithched", "overhitched". There are several long threads on towing with a 3/4 ton and 1 ton.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Equalizer hitch adjustments Raptorrider2001 Hitches, Couplers & Balls 4 09-22-2017 10:45 AM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Need for Equalizer?? smallfry Hitches, Couplers & Balls 10 01-24-2003 08:43 PM
