We had this put on our tow vehicle at the dealer-even though we had already purchased a weight distribution hitch and the dual cam sway control. They told us that the Equalizer would do the job of both of those, and we are true believers after driving 8+ hours home. We never felt any sway the whole way, and the 18 wheelers did nothing to us. I immediately felt comfortable on the interstate towing-which I was nervous about. The 22' Safari tracked very well! Made me feel I could tow something even longer- .
So if you're thinking about the Equalizer, I'm convinced it's great! Can't compare it to anything else, because my 10' pop up didn't require anything like this!!
We have an Equal-I-Zer too, and we love it as well.
For some reason, they don't seem to be as popular as those of us who have them expect them to be with others. I think there are several reasons:
1. People are confused about the difference between the Eqaul-I-Zer brand hitch, and the use of the generic term "equalizing hitch," which describes a broad category of different things.
2. They look sort of crude and simple. It's hard to believe something that plain could be as effective as the more complex and attractively finished alternatives.
3. People that buy the most exensive trailers made are probably more likely to buy expensive hitches to go with them. Heck, if you're buying a large Airstream, a couple grand more for the "top of the line" hitch seems appropriate, and relatively insignifcant in terms of additional cost.
A year or two ago, there was a thread here by a gentleman who actually tested an Equal-I-Zer hitch and one of the others (can't remember if it was a dual cam or a Hensley), with the same trailer and tow vehicle. As that was the only reasonably direct comparison of any two hitches I could find, I gave it a lot of weight in my decision making. If I remember correctly, he said the Equal-I-Zer was lighter, simpler and cheaper, and he could detect pretty much no difference in handling between the systems.
But until I try a different hitch on my rig (while changing nothing else), I guess I really won't know. I can tell you this story though. The day we brought our Airstream home from the dealer, we gave the hitch the worst test we've ever put it to. Because it took so long for the dealer to go through all the systems with us, we didn't get finshed there until it started to get dark. So we left for home (at the time, we lived just outside the DC beltway) headed north on I-95 just before the evening death rush began.
I had never towed anything that big before, and I was pretty anxious about driving in traffic, so I wanted to make good time. I was in the middle lane of three, probably going about 65. Cars and trucks were passing on both sides at much higher speeds. I would have gotten into the far right lane, but I didn't think I could stop in time if the maniacs merging in from the numerous on-ramps failed to yield.
Then as we got to the bottom of a long shallow grave, a semi tanker snapped into my path from the right. He was going at least 90, and as I saw him come into view on my right, I could tell he was going to clip the right front of my truck with the back of his trailer as he came into my lane. I slammed on the brakes and flung the steering wheel to the left hoping to avoid the collision.
Miraculously, he missed us by inches. The Airstream never swayed at all, and just tracked into the lane right behind my truck. Perhaps a different kind of hitch could perform better under some combination of circumstances, but after that scare, I've been a huge Equal-I-Zer fan. The nice thing is that it's all been smooth sailing since then. Even after nine months of full timing, that was the scariest incident we've encountered. And it happened when we'd put maybe 10 miles on the trailer!
FiveGreers good choice in hitch! That is what we are/were using to tow our 31' with a 1/2 ton pickup. And yes you probably could have gotten away with the 25, if the weight wasn't too high. I have seen Suburbans pulling some big Airstreams!
I did quite a bit of reading before buying and ended up with the Equalizer Hitch. I like the simplicity of it. I considered the Reese Strait Line dual cam, but couldn't find a dealer with one for me to look at. I have been happy with it and would reccomend it to anybody.
AgZep, I know exactly how you feel about DC traffic...I avoid that stretch of I-95 like the plague. I will look for any alternative route I can if I have to go to or thru that area.
Aaron
WBCCI #2449 AIR #2495
well worth the price. I spent about $375 for mine and the price has been well worth it. Don't forget about properly inflated tires, too. That also makes a big difference in how your rig handles during towing.
__________________ 2003 Ford Excursion (6.0L PSD) Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10 U.S. Navy (Retired) Airstream Life Contributor Air#5661 / WBCCI#--
I studied alot to when I bought mine, really wanted a Hensly but out of my price range, so I bought a Reese weight distribution and dual cam HP, toung weight 1000 lbs. Nice thing about the dual cam is you can back up while turning with out having to get out and dissconect your sway control.
We just went from a WD hitch and friction control to a Reese Dual cam. The difference is night and day!!! I can't believe anything could be easier to hook up that this dual cam.--Pieman
We also have the eqal-i-zer too, and it has functioned without issue. Only pointers I can offer are:
keep the head well greased, and optional to lube the "L" bracket to reduce/remove the "popping" noise on certain turns.
Get yourself a "lifesaver" pack with extra pins. You never know if you might need it. Losing a pin in the middle of a nowhere campsite would be real bad....
I also have an Equal-i-zer hitch and I'm a believer also. I used a Reese dual-cam for 25 years and its an excellent hitch. The Equal-i-zer is just much easier from a hookup and unhitching standpoint when the tow vehicle and trailer are at extreme angles. In the case of the Reese you need to get that bar out of the cam loop bracket. When you are at an extreme angle, the bar on the inside of the angle can't get enough clerance to allow the loop to drop over the end of the bar. Not an issue with the Equal-i-zer.
Also for those of you with the heavy hitch weights, Equal-i-zer does make a model that can handle up to 1,400 lbs. I'm using that on my hitch heavy Classic slide out.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Nothing but praise from me as well about the EQ. I agree with Kevin and Jack: buy the spare cotter pin/accesorie kit. It would just take one stormy, dark evening and a lost retaining cotter to really get the profanity going and blood presure rising.
We bought the spares and figure now that we have them, we probably will never have to use them. If we didn't have them, well you know 'ol Murphy...
A year or so ago, Equalizer was working on some new "L" bracket thingies that were supposed to be coated (teflon?) so that operation is a little quieter.
That's my only beef with the EQ: Sometimes when making certain turns, it sounds like the AS is bending in half!!! I do keep movable parts of the hitch head areas greased lightly, as well as "L" brackets.
I wipe off excess grease and road gunk on occasion before re-greasing.
Jonathan
I'm out of my mind right now, but will be returning shortly......
Got my Equalizer as part of the AS deal. Knew nothing of these kind of hitches since the biggest thing I have towed before was a 14ft fishing boat. Also have nothing but good things to say about it. Never used a Hensle before but can't see the Hensley being $2700 better than the Equalizer.
I was told to grease the hinged part a little if I want but not to grease anything else. What is the scoop on greasing?
You can grease the saddles where the bars pass through, and also the L-shaped retainers that hold the bars on. If you do that, the whole thing is much, much quieter. And there is no loss of sway control because the bars are under so much torque from the weight of the trailer. I re-grease ours about every other time we tow. Make sure you wipe the areas to be greased first, as other have said, or the grit will stay in your grease and grind down your hitch parts.
On the Equal-I-Zer, the friction control is a side benefit of the way the weight distribution bars mount to the frame, so there's nothing to disconnect while backing. Backing is as easy as putting the tow vehicle in reverse gear.
Jonathan
Someone at a rally had the teflon coated bracket. Its the bracket that the bar rides on. As a matter of fact at one point I heard that they were supplying these for free upon request. That may have been for beta testing, who knows. I think I'll give them a call and see what the story is. I'll report back!
Regards,
Jack
Jack Canavera
STL Mo. AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
