Old 02-11-2006, 03:22 PM   #15
Grand Rapids , Michigan
Originally Posted by goldwing70
HA = Hensley Arrow, about $3K
Wow, a tad pricey for me. Thanks for the heads-up!
Double D is offline   Reply With Quote
Old 02-11-2006, 03:25 PM   #16
Originally Posted by 85MH325
Either the Reese Dual Cam or the Equalizer will do you fine for a Bambi 19' behind a Yukon. The HA is a superb hitch, but won't do any better job controlling a trailer of your size and weight than the other two, and it weighs significantly more.
Sway is caused by inappropriate weight loading, tongue weight that is less than 10-15% of the total load weight, low or unbalanced tire pressures, and either warn suspension parts or good ol' design flaws in the suspension on the tow vehicle. Once you eliminate those as causes of sway, your trailer shouldn't, and your sway control hitch will just be an added measure of safety.
Roger
Thanks. I appreciate the positive reinforcement. It boosts my confidence in my TV.
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
