Old 06-04-2014, 05:48 PM   #1
airstreampek's Avatar
Westminster , California
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro
Don't know if this has been asked before or not but just like the title says, for those of you who have used or know someone who used both the Equal-I-zer Sway Control Hitch and the Blue Ox Sway Pro, what are the likes and dislikes for both in terms of reliability, pricing, availability, style, loudness, etc. All opinions would be greatly appreciated. And if you have other brands you prefer, the likes and dislikes of that brand would be appreciated also.
Pek Chhoeuy
Internet Parts Representative
Airstream Orange County
Phone 714-650-8595
pek@airstreamoc.com
airstreampek is offline   Reply With Quote
Old 06-04-2014, 10:45 PM   #2
Mixter's Avatar
1976 27' Overlander
Here we go!
Mixter is offline   Reply With Quote
Old 06-04-2014, 11:05 PM   #3
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Interested in this conversation....
Photobum is offline   Reply With Quote
Old 06-04-2014, 11:11 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have owned and used my Equal-I-zer brand hitch for nine years now. Only two concerns for me. (1.) "L" brackets moving; I made my own fix and never looked back. (2. Noise; When set up properly and lubed in the correct places, the noise is livable. I have towed in all kinds of weather conditions, some where others would have stayed home. For many, many thousands of miles. "In all of this time, my trailer only once swayed violently out of control; It was parked in my driveway during a 5.0 Earthquake."
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-05-2014, 10:36 AM   #5
SteveH's Avatar
Common Sense , Texas
Don't think you'll find many people that have experience with these two particular hitches because the Blue Ox Sway Pro is relatively new. However, by it's design, the Equal-I-zer will be more noisy, and rougher riding. Also by design, the Blue Ox will not have as good of sway control as the Equal-I-zer.
In the end, however, most any weight distribution hitch on the market today will do a good job for you assuming it is sized correctly for the weight of the trailer, and installed/set up correctly.
Regards,
Steve
Old 06-05-2014, 01:56 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Equal-i-zer.
Keep it greased.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-05-2014, 02:02 PM   #7
SteveH's Avatar
Originally Posted by m.hony View Post
Equal-i-zer. Keep it greased.
Yea, but the sway control works on friction, and a lot of it. If you grease it, that reduces friction, so wouldn't that also reduce effectiveness of the sway control?
Regards,
Steve
Old 06-05-2014, 05:34 PM   #8
m.hony's Avatar
2013 30' Classic
It's not that part that is noisy, really.
Most of the noise comes from the hitch head/ball.
They make an accessory called sway brackets jackets that cuts down noise where the spring bars move back and forth on the brackets. This only slightly effects the sway control.
When I lubricate it, I lubricate the moving parts of the hitch head and the ball. This cuts down noise tremendously.
TAC #MS-10
Airforums #70955
Old 06-05-2014, 05:39 PM   #9
SteveH's Avatar
Sorry, don't believe that because I've had one of them, and I've watched them when people are parking at rallies. The majority of the noise comes from the bars sliding in the frame side brackets, and the "L" latches binding and popping on top of the bars, which is where most of the friction occurs creating the sway control. Lubricate them there to reduce noise, and you also decrease the sway control.
Regards,
Steve
Old 06-05-2014, 09:27 PM   #10
m.hony's Avatar
2013 30' Classic
Do Hensleys and ProPrides pop and moan and groan?
I promise mine is a lot less noisy after lubricating the hitch head.
I never grease it where the bars slide back and forth in the L brackets.
I know when it is time for more grease because the noise comes back.
My EazLift made a bunch of racket, too.
I think they all do.
I hear everyone else driving through the campground and backing in. Theirs are noisy, and they have all brands and styles.
Anytime you have metal on metal friction you have an opportunity for noise.
TAC #MS-10
Airforums #70955
Old 06-05-2014, 09:29 PM   #11
m.hony's Avatar
2013 30' Classic
Squeeeeeeeaaaaaaaal...
Pop, pop, pop...
Squaaaaaaaaaaawk....
Tick, tick...
TAC #MS-10
Airforums #70955
Old 06-05-2014, 09:37 PM   #12
SteveH's Avatar
Actually, the ProPride's do not make any noise at all. They have no friction type sway control, it is all done thru geometry. The Hensley's don't either.
I currently have a Reese SC, and it IS a friction type sway control hitch, and it makes no noise either, but it is not metal on metal.
I've had an Equal-I-zer, and they do make noise from the bars sliding on the "A" frame brackets BECAUSE they are metal on metal. The loud popping noise they make when turning is the "L" brackets binding, again metal on metal.
Sheeesh, I thought everyone knew about the noise made by the Equal-I-zer hitches, especially the owners. Maybe you are playing the radio so loud that you don't hear yours.
Regards,
Steve
Old 06-05-2014, 09:52 PM   #13
m.hony's Avatar
2013 30' Classic
Yel. System on blast.
All the more reason to buy a ProPride.
My Equal-i-zer makes more or less noise depending on lubrication.
It is no louder than my EazLift, in fact it seems quieter to me.
Squeeeeeeeeeeeeeak.
TAC #MS-10
Airforums #70955
Old 06-05-2014, 09:55 PM   #14
SteveH's Avatar
Have you had your hearing checked lately?
Regards,
Steve
Old 06-05-2014, 10:59 PM   #15
Salem , Oregon
Images: 18
Ok, ok, ok.
Hi, you are both right, sort-of. The spring bars riding on the "L" brackets, metal to metal, make a lot of noise. The "Bracket Jackets" do make the hitch much quieter. I have felt no loss of friction, but I'm sure there is some. I travel long distances and when the spring bar sockets get dry, there is a lot of moaning and groaning. On most long trips, I clean, lube, and adjust/torque my hitch at home, and do it again at the turn around or half way mark of my trip.
2005 Safari 25-B
Old 06-06-2014, 12:17 AM   #16
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
What?
We just had an incredibly noisy experience with our Equal-i-zer, which was resolved by applying grease to the "L" brackets on the trailer's A-frame. We've never had problems with sway, nor did we have problems after lubricating those "L" brackets. In fact, we rode side by side with a tractor-trailer rig for enough miles to be annoying but not once did we have sway issues. I credit the AS design for that, I guess. We were much happier with our load balancing hitch after we greased those brackets and quieted things down.
Old 06-06-2014, 07:50 PM   #17
m.hony's Avatar
2013 30' Classic
Eeeeeeeeerr
Aaaaaaawwwwww
Tick tick
Pop
Eeeeeeeerrrrrrrrrrrreeeeeeer
"I thought I heard that camper comin'"
Squeeeeeeeeeeeak
Squeeeeeeeallll
Clunk bump
TAC #MS-10
Airforums #70955
Old 06-06-2014, 07:53 PM   #18
m.hony's Avatar
2013 30' Classic
"That expensive trailer and it sounds like a hunk o' junk."
TAC #MS-10
Airforums #70955
Old 06-06-2014, 07:56 PM   #19
m.hony's Avatar
2013 30' Classic
I know a guy who puts wax paper on the L brackets.
TAC #MS-10
Airforums #70955
Old 06-06-2014, 08:25 PM   #20
SteveH's Avatar
I've known people who put wax paper on the hitch ball. Wax is a good lubricant, and it won't get your pants dirty.
Regards,
Steve
Weight distribution hitches Reese Pullrite Equal-I-zer Blue Ox Hensley Air Ride markdoane Hitches, Couplers & Balls 2 09-04-2014 09:57 AM
Equal-i-zer + add on sway control? DaAairstream Hitches, Couplers & Balls 23 04-22-2012 12:44 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 09:28 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 07:17 AM
