Old 06-18-2014, 10:14 PM   #29
2015 25' FB Flying Cloud
Huntley , Illinois
What areas of an equilizer do you lube?
cegardner is offline   Reply With Quote
Old 06-18-2014, 10:20 PM   #30
Huntley , Illinois
we get a great bounce with our equalizer and 22 'FB sport. We have the lightest bars, 6000 lbs and trailer is 4500 max. Lot of bounce. no sway though. Do we need a different hitch?
Old 06-18-2014, 10:53 PM   #31
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you only need to lube the ball and the top and bottom of the spring bar sockets. Remove the bolts holding the spring bar sockets in place, clean and lube where they meet. [top and bottom]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-18-2014, 10:56 PM   #32
Salem , Oregon
Images: 18
Hi, make sure that your "L" brackets are at the maximum distance from the ball center on the coupler. [32"] This will give the spring bars more leverage and more flexibility.
2005 Safari 25-B
Weight distribution hitches Reese Pullrite Equal-I-zer Blue Ox Hensley Air Ride markdoane Hitches, Couplers & Balls 2 09-04-2014 08:57 AM
Equal-i-zer + add on sway control? NewbieAndy Hitches, Couplers & Balls 23 04-22-2012 11:44 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
