06-06-2014, 07:33 PM
#21
2013 30' Classic
Greenwood
, Mississippi
I like it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-06-2014, 07:37 PM
#22
Common Sense
I tried wax paper on the ball with a small trailer once. It lasted almost two miles.
Regards,
Steve
06-06-2014, 07:41 PM
#23
2013 30' Classic
Greenwood
, Mississippi
Even when the paper falls away a little wax residue is left behind.
TAC #MS-10
Airforums #70955
06-06-2014, 10:26 PM
#24
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
I like the wax paper idea if it works, especially on the L-brackets. I now have a pair of "trailer pants" due to bumping my knees on those brackets while working around the front storage compartment of our 27FB.
06-06-2014, 10:52 PM
#25
Slowpoke
2012 27' Flying Cloud
Portland
, Oregon
I immediately drop the greasy ends of the bars into ziploc freezer bags and zip 'em up tight to the shanks. Manage to keep myself clean.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
06-14-2014, 06:27 AM
#26
2013 30' Classic
Greenwood
, Mississippi
It gets louder after every rain. I guess the lubrication wears off. Another reason to get a ProPride...
TAC #MS-10
Airforums #70955
06-14-2014, 06:47 AM
#27
Common Sense
Not saying it would definitely work, but if I still had an Equal-I-zer hitch, I would try some Door-Eaz on the "L" brackets where the bars ride. If wax paper helps, it should also as it is a thick, waxy type lubricant.
Regards,
Steve
06-14-2014, 09:04 AM
#28
2013 30' Classic
Greenwood
, Mississippi
Wax paper from the Kuntry Boy sausage package- it has sausage grease, too!
My "link plate" on the curb side is bent. Justin Andrew said to turn it around. It just bent the other way...
If the link plate was as thick as the L bracket...
TAC #MS-10
Airforums #70955
06-18-2014, 10:14 PM
#29
2015 25' FB Flying Cloud
Huntley
What areas of an equilizer do you lube?
06-18-2014, 10:20 PM
#30
Huntley
we get a great bounce with our equalizer and 22 'FB sport. We have the lightest bars, 6000 lbs and trailer is 4500 max. Lot of bounce. no sway though. Do we need a different hitch?
06-18-2014, 10:53 PM
#31
Salem
, Oregon
Hi, you only need to lube the ball and the top and bottom of the spring bar sockets. Remove the bolts holding the spring bar sockets in place, clean and lube where they meet. [top and bottom]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-18-2014, 10:56 PM
#32
Salem
, Oregon
Hi, make sure that your "L" brackets are at the maximum distance from the ball center on the coupler. [32"] This will give the spring bars more leverage and more flexibility.
