Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 03-18-2003, 12:28 PM   #15
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Sorry guys.
I am having a full moon monday.
Indeed, Equalizer hitches do not have chains.
I meant to say Eaz-Lift.
I will go back and edit my previous post.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-18-2003, 12:40 PM   #16
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally posted by Inland RV Center, In
Sorry guys.
I will go back and edit my previuos post.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Good Lord Andy I should say you are! It's Tuesday! LOL.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 03-18-2003, 05:19 PM   #17
Gene Wissink
Profile:
What is better in the Reese WD? Round bar or trunion. The old hitch is the square one ( trunion) I am getting confused, The Easyrider will build the hitch to match the bars. I looked at the HP sway control, it looks easier to install and adjust for center.
Gene Wissink is offline   Reply With Quote
Old 03-18-2003, 07:40 PM   #18
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Originally posted by Ira Iburg
You will ot be sorry with a Reese Dual Cam hitch. I have used one on our 31 ft Airstream for 32 years and over 100 thousand mile, they are great.
Ira and others,
Do they really last that long?
I have the one that came with my Overlander and am wondering if they ever wear out. It does have wear in the trunnion areas and at the areas at the ends of the load bars, the places where they lock in and slide out of the notches.
Chas
Chas is offline   Reply With Quote
Old 03-18-2003, 08:58 PM   #19
femuse
Profile:
TO: Gene Wissink
We too are most certainly going to buy an Easy Rider Air Hitch.
In your case, I do not thing it will hurt, but you may be wasting your money.
It will not improve the ride of your tow vehicle, just the ride of the trailer. Unless your wife rides in the trailer she will not benefit from it.
You may want to check if it will not make it worse on your vehicle ride.
femuse is offline   Reply With Quote
Old 03-19-2003, 06:17 AM   #20
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
While the Easy Rider hitch is designed to transmit less shock to the trailer, based on the material I have read, it also gives an easier ride on the vehicle. Even the 5th wheel designs on other sites state that there is less bounce on the vehicle.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Reese Friction Control or Dual Cam? donreitz Hitches 34 06-24-2004 12:43 PM
Is dual cam better than friction sway control? Fogducker Hitches 6 02-12-2004 09:37 PM
Reese dual cam sway - fit??? Craig Hitches 4 06-18-2003 04:50 AM
friction vs. dual cam sway Craig Hitches 8 04-29-2003 11:30 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
