07-22-2016, 11:47 PM
#941
2018 30' Classic
Ivins
, Utah
I was experiencing the same problem. I added the sway bracket jackets, the copper tube and extra bolt, but what ultimately solved it for me was drilling a hole in each L-pin and press-fitting a roll pin into it. The roll pin prevents the L-pin from binding on the sway bar. The brackets have not moved at all since I added the roll pins 3 years ago. You will find this solution somewhere earlier in this thread.
07-22-2016, 11:56 PM
#942
Salem
, Oregon
Hi, on page three, post twenty nine, you will see my roll pin modification in the "L" pins. I also use the Bracket Jackets.
Pictures are dated 4-2-2011
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-23-2016, 07:10 AM
#943
Summerville
, South Carolina
LAWBC,
Your 1000lbs bars may be too light for your tongue weight, so you have to adjust the L brackets up to level your rig. Your bars should be parallel with the frame, if they are at an angle they put a side load on the brackets causing them to move.
I also have an FB and have to use 1200 bars to compensate for tongue weight.
If you want more information, PM me and I will share with what I did with my rig.
Henry
07-23-2016, 08:06 AM
#944
I'm In
, Kentucky
Originally Posted by sheriff1
Try a Kirkland water bottle from I think it's the 48 pack. Properly cut there is a ridge that will hold it on the ball when not towing. I stick it in with the propane tanks for travel.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
Thanks for the idea
I think Kirkland comes from Costco and that (I think) requires a membership. We have other bottled water brands, I'll try some of those.
Good idea because the paper cups don't fit well and can blow off when I'm not pulling the AS. I usually take the hitch off except between home and the storage lot. In the garage I need some kind of cover for the ball, this might be a better solution.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
07-23-2016, 08:38 AM
#945
I'm In
, Kentucky
Originally Posted by richw46
Thanks for the idea
Wal-Mart Great Value 16.9 oz (48 pack) fits pretty good. If you cut it off just under the label and use the bottom part, it's snug enough for the narrow portion of the bottle to squeeze over the ball. It's loose but I don't think the wind can take it off. Great in the garage, for sure
-Rich
Rich & Yvonne
07-23-2016, 09:01 AM
#946
2016 25' Flying Cloud
Jupiter
I bought a box of 100 nitrile gloves from Amazon for $10 and I just use of one those stretched over the ball. I can get a couple of uses at least out of one glove. I also use the gloves while dumping the tanks.
07-23-2016, 10:49 PM
#947
TinCan
2016 30' Classic
Apache Junction
I think I got it at campingworld a rubber ball cover. Works quite well. I also got a rubberized sleeve to fit over my electrical connection. Keeps the rain out of the TV plug.
TinCan
07-25-2016, 05:53 PM
#948
Displaced Beach Bum
2016 30' International
Texas Airstream Harbor
Originally Posted by LAWBC
I have the 1000 lb. bars on my 27 FB for 3 years using the same truck and just lately am experiencing a shift in the L brackets on the frame approx.. 1/2" shift forward.
I went to a RV shop the other day and had them realigned and tighten. That night I left the truck hitched while staying one night with the bars hooked up . Lifted the truck approx. 6" to level . This morning I see the damn brackets had shifted again.
Could it be leaving the rig hitched and elevated made the brackets to shift ?
Should I have freed the bars before leveling the trailer ?
I have lifted the rig in the past on one night stay overs without any problems , and carry the same loads .
😱I can't imagine staying hitched and raising 6" that would be a hell of a lot of stress as the bars are pushing down on the brackets.😱
We drag Mitzi a 2016 International 30 w/Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
07-25-2016, 06:58 PM
#949
2019 30' International
Pennsylvania
, Pennsylvania
We have a flying cloud 25a with an equalizer hitch. My hitch bars were terribly difficult to move off the j brackets, couldn't budge 'em, had to kick 'em to move em in, and yank like crazy to pull em out, and I'm 6'1" and 192 pounds, not young, but ain't worn out yet either......and the hitch was creaking and banging and just raising a ruckus on our last trip. I had the socket bolts torqued to 60 lbs.
I say we have around 2,500 miles on the hitch setup. I think the paint rubbing off, the grease, road grime, you name it, all gunked up in there, was causing issues.
So, I removed the sockets from the hitch head, cleaned everything up, put a little grease on the surfaces, pounded the sockets back in with a rubber mallet, and torqued the bolts to 45 lbs.
Then we towed 30 miles or so to a local state park, and she was quiet as a mouse.......not a squeak, bang, clunk, or creak.....amazing.
While at the state park, I ran the torque on the socket bolts up to 50 lbs, and the bars were able to be moved up on the j brackets with ease, using the lift tool. Yep, the bars are now able to move back and forth with relative ease, and with the bracket jackets on there, the whole setup was quiet.
On a side note, a good ole boy pulled in while we were leaving with a 6,000 lb. dry weight camper, being towed by a new chevy colorado, hitched up right to ball, no sway control, weight distribution, or any other such nonsense, straight towing that puppy
07-25-2016, 07:42 PM
#950
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
Bay Area Airstream installed ours. Perfectly quiet and very easy to hitch/unhitch. No regrets!
07-25-2016, 08:47 PM
#951
2018 23' Flying Cloud
Huntsville
, Alabama
Originally Posted by ROBERTSUNRUS
Hi, go back to page one and post thirteen. My extra bolt and copper pipe modification has never slipped.
I second that. After seeing the copper pipe mod. I did use a small piece of PVC pipe instead of copper but the concert works for me.
Ron
07-25-2016, 10:08 PM
#952
2002 30' Classic S/O
Fleming Island
The brackets on my 25 slipped no matter what I did until I did Bob's copper pipe mod. Solid as a rock afterwards. Be sure not to overtighten the bolts and to tighten them evenly. If the bracket bows out due to one or both bolts being overtightened it reduces the contact are with the frame and actually increases the probability of slippage.
Al
08-07-2016, 03:58 PM
#953
Longview
Help with bar selection
We're waiting on arrival of our 2017 FC26U. We'll be towing with a F-250.
The dealer is a 'bigger is better' advocate.
What bar rating should we be using?
08-07-2016, 05:07 PM
#954
Salem
, Oregon
Hi, no more than 1,000 lb. bars and no less than 600 lb. bars. Hopefully someone towing with an F-250 will chime in.
08-09-2016, 09:30 PM
#955
2018 30' Classic
Ivins
, Utah
Yep, 1000 lb bars are working well on my 27FB and F250. Adequate weight transfer to the steer axle, and a smooth ride. Well except on California freeways, but that's no fault of the hitch ;-)
08-10-2016, 07:06 AM
#956
2020 16' Nest
Saint Augustine
08-10-2016, 07:35 AM
#957
2013 30' Classic
Greenwood
, Mississippi
An "anti-rattle" device or hitch tightener will solve that.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
08-10-2016, 08:39 AM
#958
TinCan
2016 30' Classic
Apache Junction
Yep, 1000lbs bars here. 30' Classic, F250. I did go with the larger 2.5" hitch rather then use the reducer.
TinCan
08-10-2016, 09:24 AM
#959
2020 16' Nest
Saint Augustine
I do have a stowaway hitch tightener. The L brackets were at the same level but I had to raise the tounge to get the other bar on.
08-13-2016, 04:16 PM
#960
2016 26' Flying Cloud
Southlake
Just got our 26u a few months ago and have been following the Equil-i-zer thread. Just went out to see if my L-brackets had moved on our just completed 2,000 mile trip. No movement at all BECAUSE now there is no space between the upper and lower bolts and the A-frame and there is a second (even thicker) steel plate on the outside of the A-frame. I guess the hitch guys have been listening!
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
