Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 03-08-2016, 02:38 PM   #901
interstateflyer's Avatar
2017 25' International
Los Osos , California
Sway Jacket Pads. Which way should I install them, vertically "A" or horizontally "B"?
ID:	258404   Click image for larger version
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 03-08-2016, 02:48 PM   #902
Rich W's Avatar
I'm In , Kentucky
Slide them on like 'A', then drop them down like 'B'. The spring arm will ride on the nylon pad. That cut in the center is to allow the pin to go through it into the L-bracket.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 03-08-2016, 03:10 PM   #903
That's what I thought. My Airstream dealer's service manager and mechanic, both of who had formal Equalizer training, insisted that they remain vertical, "A".
They claim that the friction at the bottom resting point of the bar is what creates the ant-sway protection, so advocate position "A", vertical.
Old 03-08-2016, 03:16 PM   #904
subfan1's Avatar
2019 23' International
La Habra , California
Ask yourself why they would put a slot on the sway jacket. B
2019 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 03-08-2016, 03:31 PM   #905
Yes.....I indeed asked that question of the mechanics. They said it gives you the option of two positions, one of which (the horizontal) keeps things quieter but inhibits sway control.
Old 03-08-2016, 06:00 PM   #906
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Pretty sure they are wrong about position "A". We always use our sway bracket jackets in position "B" and we're very happy with the results.
Old 03-08-2016, 06:07 PM   #907
Rich W's Avatar
I'm In , Kentucky
That's true, the friction is what gives it the sway control. I have the dual axles and sway isn't a problem, even after the pad installation. I just got really tired of the noise and the grease (to stop the noise). There is still noise but I don't need to grease the spring arms, just the spring arm sockets, and that doesn't last long before they start squeaking.
If you have dual axles, I think you'll be OK. Put them on and go for a test drive on a windy day and see if you have any problems with sway. Use caution, of course.
-Rich
Rich & Yvonne
Old 03-08-2016, 06:17 PM   #908
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, in position "A", in my opinion, the pads are useless. In position "B", in-which Equal-I-zer shows where they go, they are quieter. Also in my opinion, and with my experience, The sway jackets create more friction than the original metal to metal design.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 03-10-2016, 05:01 PM   #909
garylind's Avatar
2016 23' Flying Cloud
San Mateo , California
Equal-i-zer for 2016 23Flying Cloud FB??
About to purchase this new trailer and wondered what model is best. The dealer seems to think that a SwayPro is more than adequate.
garylind is offline   Reply With Quote
Old 03-10-2016, 07:14 PM   #910
Rocinante's Avatar
That's a topic guaranteed to stir up a kerfuffle. Use whatever WD / Sway control hitch works best for you and your TT/TV combo. We like our Equal-I-zer, but there are plenty of folks out there who use other things.
Old 03-10-2016, 07:46 PM   #911
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale , Arizona
Agree - very personal and often emotional. We went with the Equal-i-zer!
cactusjk is offline   Reply With Quote
Old 03-11-2016, 09:53 AM   #912
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
There is no such thing as the "best" hitch. Often depends on the tow combination and your pocketbook. Spending more probably doesn't provide a linear increase in value. I tried one hitch first, didn't like it and sold it. Am content with the Equal-i-zer, warts and all.
kscherzi is offline   Reply With Quote
Old 03-11-2016, 10:33 AM   #913
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I like the Equal-i-zer, also liked the EZ lift, hated the dual-cam, haven't tried the rest.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 03-11-2016, 11:13 AM   #914
CruizinDux's Avatar
Washington , Missouri
[richw46 Quote:
......... There is still noise but I don't need to grease the spring arms, just the spring arm sockets, and that doesn't last long before they start squeaking.]
Wow, just discovered this thread. Seems I have some reading to catch up on.
We have an equalizer and our 20 tows sweet including during a recent drive down I5 at Black Butte/Castle Crags with horrendous rain & extremely gusty winds.
I realized that when I got to San Diego, that I needed to be a bit more attentive on the head grease vs just a putty knife reapplication of Marine grade grease.
I removed the sockets yesterday and cleaned everything well and started fresh on the grease I discovered that (probably during the storm above) the grease attracted a lot of grit that needed to be removed. Thanks for posting pics, as I've been contemplating the addition to the L brackets.
Longer trips I'm thinking of maybe removing the socket weekly or so to start fresh. It's really simple and I already have the torque wrench handy for the wheels, and it's the same size socket as the WH plug...which is always in my tool bag of often needed tools etc. anyway.
CruizinDux is offline   Reply With Quote
Old 03-11-2016, 11:41 AM   #915
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Bob: I take the head on our Equalizer apart at the end of each season. I see no wear on it and I only grease it because I think it must need to be done. The noise is an issue, but I close the windows. We do about 10,000-15,000 each year.
I also carry all kinds of tools, torque wrench for the wheels as well as the hitch and an extra ball as the one Equalizer uses is somewhat odd in it's very short shank.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 03-11-2016, 11:44 AM   #916
My dealer sold us a Huskey WDS for our first Airstream. What a horrible system. That was the brand that they pushed on their customers.
I'd probably trust the collective experience of AirForum members more than most dealers, there are exceptions of course.
Old 03-11-2016, 12:21 PM   #917
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Do you recall, specifically was it a Husky Centerline?
GCinSC2 is offline   Reply With Quote
Old 03-11-2016, 12:28 PM   #918
No, it was not a Centerline. It was a previous model. I've actually heard the Centerline is better. Didn't mean to pass judgment on the whole Huskey line.
Equalizer was a huge improvement over the Huskey chain style WSD that we were sold.
Old 03-11-2016, 01:11 PM   #919
dznf0g's Avatar
Oswego , Illinois
I used to use an EQ, so I'l throw in my learnings. The nylon pads are supposed to be in the horizontal position with the bars riding on them. It does reduce friction a bit, but per my conversation with EQ, that area isn't the primary friction surface and does little for sway control. The primary friction surface is the head saddle area where the front ends of the bars are bolted to the head and swing in turns. That's why the torque on those bolts needs frequent attention.
-Rich-
Old 03-11-2016, 01:31 PM   #920
GCinSC2's Avatar
I've checked mine several times and the torque required to rotate the sway bar (not the bolt) varied greatly with where the bar socket is. Worn area, loose ish. Outside the primary work area tight ish. Observed quite a bit of wear on the bar socket surface of the head.
