04-16-2014, 01:46 PM
#301
2007 23' International CCD
cary
, North Carolina
Sounds like the average guy (me) has probably gotta take this hitch to Camping World to get any adjustments made.
04-16-2014, 01:51 PM
#302
2013 30' Classic
Greenwood
, Mississippi
Yep.
I asked Chris Burch at the Airstream service center if they could get mine tightened up while we are there for service work in September. He said they could git-r-dun.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
04-16-2014, 05:55 PM
#303
Salem
, Oregon
Hi, I changed my bolts to grade 8 and trimmed the ends off because they were a bit too long. As for torqueing the bolts, I turned my hitch up-side-down, in my receiver, used a deep impact six point socket on a 1/2" breaker bar and stood on it. That's 200 lbs plus the leverage of the breaker bar. I also put a bottle jack under the hitch to hold it solid while doing this. It has never come loose. [my torque wrench only goes to 250 lbs]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
04-16-2014, 08:16 PM
#304
2013 30' Classic
Greenwood
, Mississippi
It 's the L-brackets that I can't get tight enough.
TAC #MS-10
Airforums #70955
04-16-2014, 08:18 PM
#305
2013 30' Classic
Greenwood
, Mississippi
I have thought about using a cheater on my torque wrench or a lug wrench and standing on it.
I have also thought about taking it to our mechanic shop and using air.
TAC #MS-10
Airforums #70955
04-16-2014, 09:07 PM
#306
Salem
, Oregon
Hi, my "L" brackets have never come loose after my copper tubing modification. This was done many years ago. [see page 1 of this thread]
04-16-2014, 09:12 PM
#307
2013 30' Classic
Greenwood
, Mississippi
I have thought about a similar modification with electrical conduit.
TAC #MS-10
Airforums #70955
04-16-2014, 09:16 PM
#308
Salem
, Oregon
Hi, that might work too; I used copper tubing because 1/2" pipe size fits the bolts good and it allows for a little crush.
04-16-2014, 09:37 PM
#309
2013 27' FB International
El Dorado Hills
My bolts turn when torquing one side. I use a big crescent wrench to hold the other end, but then I have too pound it loose to get it free. This loosens things a bit. The lock washers are tight, so I'm assuming its okay. Its a bit of a hassle as I've been adding washer combinations after Cat Scale weights and follow-ups.
#310
2012 25' Flying Cloud
Battle Lake
I found my brackets were moving even though I strongly tightened them. I noticed they had curved very slightly from tightening so most of the contact was only on the edges of the frame. So I took the brackets off and reversed them. Then when I tightened them the slight curve went out and they gripped the frame strongly from top to bottom. They never moved again (well, until I removed the hitch).
Doug and Cheryl
04-16-2014, 09:51 PM
#311
Salem
, Oregon
Hi, I use a trailer ball wrench [to hold the head of the bolt] that is double boxed end; You can buy them a Wal-Mart and several other places where the sell trailer parts.
04-16-2014, 09:57 PM
#312
Salem
, Oregon
Hi, that was the problem with the "L" brackets. Not tight enough and they slipped. Too tight and they bowed and slipped. Never found the happy medium, so that led to my modification.
04-17-2014, 06:18 AM
#313
Oswego
When I had mine....after they were bowed with overtightening, I did not manually straighten them. I turned them over and tightened until they were just flat again. They never moved again.
-Rich-
04-17-2014, 06:51 AM
#314
2013 30' Classic
Greenwood
, Mississippi
I will turn the bent "link plates" around as well. This was suggested by customer service at Equal-i-zer.
TAC #MS-10
Airforums #70955
04-17-2014, 09:14 PM
#315
Salem
, Oregon
Hi, the outer plates can bow too and you can't turn them backwards. I, at first, bolted the brackets [off of the frame] face to face with a piece of metal in-between, and bowed them slightly in the opposite direction. But that was only a temporary fix.
04-17-2014, 09:51 PM
#316
2018 30' Classic
Ivins
, Utah
Best solution for the slippage problem for me was from Equalizer support - When I installed the link plates, with the top bolt resting on the top of the A-frame, there was about 1/8" gap between the bottom of the A-frame and the lower bolt. Support recommended i insert a shim to fill that gap.
I found a pair of 1/8" mending plates at the hardware store - they are small square pieces of steel, used to secure two pieces of wood together in a butt joint. It was about 1 1/2" square, and 1/8" thick, with 4 holes for wood screws. It even had some dimples, which serve very well to insure that the shim would not slip out. It filled the gap perfectly, and completely stopped the slippage.
04-18-2014, 12:19 PM
#317
2013 30' Classic
Greenwood
, Mississippi
I will try the "mending plates" idea.
TAC #MS-10
Airforums #70955
04-19-2014, 05:07 PM
#318
1977 31' Excella 500
Berkeley Springs
, West Virginia
I had the same problem, covered it in a thread long ago (you can find it with a search on Equal-I-Zer setup or similar).
The link plates are too flexible. If your tongue frame is smooth (as it should be), they can slide around. I welded my link plates to 1/2" thick steel plate doublers, then put a piece of rubber between the link plate and the frame. Rubber has high friction (it's why they make tires out of it) and so between the stiffness of the thicker plate steel and the higher friction of the rubber, it totally fixed the problem. I had to get longer bolts to bolt it all together, but that was fairly cheap. I used Grade 8.
The Equal-I-Zer is a great hitch. The only problem I've ever had was the link plates slipping. That is an easy fix. You fix that, you'll love the hitch.
See ya on the road,
- Jim
04-19-2014, 05:18 PM
#319
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
On Wednesday we'll have our dealer, who sold us the hitch along with the trailer, check its configuration. The trailer is pretty close to dead level when hooked up to the truck, but the truck feels a little heavy in back and light in front. So, we're going to start by doing the yardstick test to see how much the truck squats down front vs. rear when we hook up the trailer (e.g. is the ratio of distance from truck to Earth the same before and after we hitch up the trailer?) Once they've taken care of that we'll weigh the rig per standard recommendations now that we've de-winterized and put water in the fresh tank. Need to see where all that water weight has settled and ensure the hitch is properly transferring enough poundage to the truck's front axle.
04-19-2014, 08:46 PM
#320
2013 30' Classic
Greenwood
, Mississippi
I have thought about cutting rubber from an old inner tube to put between the link plates and a-frame. Welding more steel to the link plates sounds like a good idea, too. Another thought was to weld a couple of beads on the a-frame to stop the movement. Maybe I will have time this week to experiment with all these ideas. In October I raised everything up to see if it rode any better/different. The weight bars are no longer parallel to the a-frame. I want to lower it all back to where it was so the weight bars will be parallel to the a-frame. That in itself should help the link plates from shifting because the weight bars will just slide back and forth with no up and down. This will be the third attempt. Hopefully the third time will be a charm, not a strike out.
TAC #MS-10
Airforums #70955
