Old 04-06-2017, 05:55 PM   #1065
richw46's Avatar
Lexington , Kentucky
Originally Posted by Mollysdad View Post
Help me out here, you seem knowledgeable about the parts.
The reviews on Amazon says you can't use the nylon pads AND the spring clip retainers at the same time. Have you found this to be true?
Also you say the new spring clip retainers help keep grease off your hands. I didn't think one was to grease any parts on the trailer end of the hitch. What say you?
This makes my 3rd attempt at replying. I have a video to attach and every time I do and click post, IE crashes. I even copied my reply and somehow that got removed from the clipboard.
OK, one more time, and I'll copy my reply to a text editor before clicking anything else. (gotta love the Interweb and IE )
In the attached video I made for another post, you can see the spring arm sitting on the pad, on the L bracket with the L pin inserted and the square spring deployed. No issues, i don't know what the Amazon people are saying. (The spring arm is not inserted into the hitch head. I was just showing the play in the L bracket)
Using the retainer pin with spring that goes into the hitch head (not shown in the video) to put the spring arm in, I hold the spring part, insert the pin through the hitch head, spring arm and out the other side. Then, still holding the spring part, I slip it over the end of the pin. When I used the cotter pin I was always getting grease from the hitch arm. Now, almost nothing.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-06-2017, 05:59 PM   #1066
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Agreed. Much easier and cleaner. I never liked the cotter pin solution that came with the hitch when I bought it.
SeaLevel is offline   Reply With Quote
Old 04-06-2017, 08:43 PM   #1067
Mollysdad's Avatar
Third time's a charm! Success.
Thanks.
Old 04-23-2017, 05:05 PM   #1068
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Equal-i-zer Hitch Thread.
How many tow miles do you normally get from the swing arm retainer pins and L pin that goes over swing arm? After 10,000 miles mine are starting to show serious wear and some gouging.
Cispook is offline   Reply With Quote
Old 04-23-2017, 05:08 PM   #1069
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
For some reason when I switched d to the L-pins with the flip-over bail that wear and gouging stopped.
I've heard of others drilling another hole for the pin to stop some of the movement.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-25-2017, 01:45 PM   #1070
Cispook's Avatar
Chillicothe , Ohio
You see much wear and tear on the socket pins?
Old 04-30-2017, 04:33 PM   #1071
m.hony's Avatar
2013 30' Classic
No wear anywhere really after 5 years of continuous use.
TAC #MS-10
Airforums #70955
Old 05-01-2017, 04:17 PM   #1072
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
New Equalizer Hitch Question
Greetings,
I just upgraded my tow vehicle to a 2015 Toyota Tundra, from a VW Touareg. I am towing a 2010 Flying Cloud 23' FB. My truck is about 2" taller than the VW when not hooked to the trailer and my Equalizer hitch flange is too short. My question is, if anyone is using this combination, what length flange to I need to get the correct hight and not scrape the ground. The current one is 81/2 inches. I see they make a 12". Will that do?
Thanks in advance for your thoughtful responses. Cameron
curnes is offline   Reply With Quote
Old 05-01-2017, 04:18 PM   #1073
m.hony's Avatar
2013 30' Classic
Excellent choice!
TAC #MS-10
Airforums #70955
Old 05-01-2017, 04:24 PM   #1074
curnes's Avatar
We also got the silver Tundra and it looks terrific. What length flange to you use with your equalizer hitch so it is level with your trailer?
Old 05-01-2017, 04:43 PM   #1075
curnes's Avatar
That should have been shank length, not flange. Don't know what I was thinking.
Old 05-01-2017, 05:45 PM   #1076
Mollysdad's Avatar
I measured my Tundra receiver height (17.75) and plugged the numbers into Equ-i-lizer's calculator, and it recommended the standard shank in the bottom hole.
http://www.equalizerhitch.com/About%...shanksizes.php
Old 05-01-2017, 05:58 PM   #1077
m.hony's Avatar
2013 30' Classic
I think my shank may be about 8" long.
TAC #MS-10
Airforums #70955
Old 05-01-2017, 09:33 PM   #1078
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Mine's closer to nine.
sheriff1 is offline   Reply With Quote
